IFI AUDIO AC iPurifier Active mains filter with phase and ground detection
iFi Audio's AC Purifier is an intelligent solution for treating EMI/RFI pollution locally at the power source for greater efficiency. It can thus process some or all of its products on a power line with one or more active and non-passive modules.
4.7 / 5
Reference : 12526
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 07-04-2026.
Mains power is the essence, the source that powers an audio system. And, whether clean or polluted, it has a major impact on the quality of all Hi-Definition Hifi systems.
The iPurifier AC is the latest iFi Audio processor. Technologically advanced, it is an active and non-passive processing device, which goes beyond traditional sector filters and removes far more noise and distortion over a wider frequency range than other existing fixed-frequency band devices.
This graph compares the AC iPurifier (green line), which is ON, with generic sector filters (red line) which are generally passive.
The effective noise reduction difference is also different between night and day.
The graph shows that the AC Purifier offers a constant noise reduction over a wide frequency range where a conventional passive filter is only effective in high frequencies.
The iPurifier AC is designed to accurately process any AC powered audio system. It is particularly effective in processing modern audio systems that have an abundance of generic, linear and varied switch-mode power supplies.
Wireless purification System
The Wireless Purification System (WPS) is a complex circuit that reduces power line noise without any audible or measured side effects. This is important because such solutions, while trying to reduce noise, also hinder dynamics. This is not the case with the iPurifier AC which keeps all the essence of every inflection that make music.
Modular Design supress Noise
In many modern audio systems, there is usually a plethora of power outlets one after the other, cascading their own unwanted noise additions and polluting the final power supply to the speakers.
The design of the iPurifier AC is such that it is even more effective if several are used judiciously to "contain" the problem at the source.
You can insert it into the AC wall outlet that powers the audio system or insert it into the audio system's power extension block. Try both places to find out which ones have the greatest impact on improved sounds.
The figure shows the treatment possibilities with one or more iPurifer CAs at the same time.
Earth intelligence system
There are a small number of AC cleaning devices that add an additional ground/mass, but only the iPurifier AC has an "intelligent ground". You can purchase the optional additional 4mm grounding cable as an option to give the audio system the best possible ground/ground quality. (if it detects the absence of ground, it will not create a ground loop). The connector is standard 4mm banana plug.
Intelligent Polarity automatically informs you of the incorrect orientation of the mains phase by switching to a red LED. The second mistake is the absence of Earth. In a system where there may or may not be a lack of earth, simply insert the iPurifier AC into the system and it will tell you one way or the other. When both LEDs (below) turn green, everything is in order!
Automatic Surge protection
Last but not least, in the rare cases where there is an overvoltage spike (caused by a power surge or lightning strike for example), the iPurifier AC will automatically turn off and shut off the electricity to pass through your system. This should protect your valuable and highly sensitive mains equipment from overvoltages.
Technical specification :
  • Active Noise Cancelation® : AMR Audio low level technology  -40dB
  • Surge protection : max. 30000 A @ 1000V / 10Us
  • Voltage capabilities  : 90V - 265V
  • weight : 128g
  • Dimension : 115 x 40mm
InputType E / F Main Plug
OutputSchuko
ColorOther
ColorWhite
Output voltage (V)NC
Output current (A)NC
Input voltage (V)115.0
Power SupplyPower supply filter
38 reviews
Indispensable
Effet immédiat. Amélioration de la scène sonoreet plus. A essayer et à adopter. Je prévois d'en racheter un autre. Belles écoutes à tous.
This review has been posted for IFI AUDIO AC iPurifier Active mains filter with phase and ground detection
Très satisfait
Très efficace. j'en ai acheté plusieurs pour mes 2 installations
Efficace
Installé sur ma barrette ANSUZ avec câblage ANSUZ, système Aesthetix/Lumin/Apertura. Recul du bruit de fonds = scène sonore plus large, plus d’information et plus précise, davantage de dynamique. Encore plus efficace avec 2. Je recommande
Magique !
Sans aucun doute, l’un des accessoires le plus étonnant et le plus performant pour améliorer sa chaîne. Plutôt que de changer de convertisseur ou de câble, essayez cet appareil redoutable.
Tout est plus net, plus propre avec un rythme insoupçonné et des timbres plus réalistes. Avec deux appareils, un sur la prise murale et un sur la nourrisse entre les amplis et le DAC, c’est magique !
Pas de notice en français
Helas,pas de notice en français alors que le produit est vendu de France
iFi Audio's AC Purifier is an intelligent solution for treating EMI/RFI pollution locally at the power source for greater efficiency. It can...
