By buying this product you get 179 loyalty points
The Keces P14 is a high-quality regulated linear power supply. This power supply will provide your HiFi audio system with a clean and stable electrical signal. The Keces P14 benefits from a totally analogue design and high-quality components such as a very powerful toroidal transformer. Each of the 4 output channels has a separate ground. The quality of this power supply's design results in an ultra-low noise signal and eliminates any noise at 50Hz and at maximum load. For this P14 power supply, Keces has also chosen to use Quantum Resonance technology, which enables electromagnetic components to resonate in the same time to improve coherence and synchronisation. It also incorporates OCP protection in the event of overcurrent, and OTP protection in the event of overheating (over temperature protection).
The Keces P14 power supply must be placed in a well-ventilated area. In addition, it must not be positioned above or below any other HiFi equipment.
In addition to these 3 power supply outputs, the Keces P14 has a USB isolator with a USB-B input and a USB-A output (5V 2A). This USB isolator will allow you to enjoy your digital signal sources such as a computer while protecting the signal from noise generated by the source device. The isolator supports PCM sampling rates up to 24bit 96kHz and DSD up to DSD64.
1 | USB-A isolator output |
2 | USB-B isolator input |
3 | ZONE II: DC output 12V / 15V / 19V / 24V 6A |
4 | ZONE III: DC output 5V / 9V 2A |
5 | Output voltage selection ZONE III: 5V/9V |
6 | ZONE I: DC output 5V / 7V / 9V / 12V 4A |
7 | Starting mode selection |
8 | Input/Output 12V trigger Jack 3.5mm |
9 | Power plug IEC C14 |
10 | Fuse slot |
11 | Switch on/off |
Product type | Ultra low-noise regulated linear power supply |
Input voltage (switchable) | AC 110V-120V 60Hz (T3A Fuse) AC 220V-240V 50Hz (T1.5A Fuse) |
Output voltage and current | Zone I: 5V / 7V / 9V / 12V, 4A Zone II: 12V / 15V / 19V / 24V, 6A Zone III: 5V / 9V, 2A Zone IV: USB 5V, 2A |
Ripple noise | < 100µV at full power < 10µV at 60% load |
USB isolator | Support low and full speed data rate for 1.5Mbps and 12Mbps |
Body material | Aluminum |
Power consumption | Standby: 0.5W Maximum: 350W |
Dimensions | 300*279*66mm |
Color | Black |
Weight | 7kg |
Package | 1* Keces P14 1* Power cable 2* Jack DC 5.5/2.5mm cable 1* Jack 3.5mm cable |
Input | Jack 3.5mm |
Input | USB |
Input | IEC C14 |
Output | USB |
Output | Jack DC 5.5/2.5mm |
Output | Jack 3.5mm |
Color | Black |
Output voltage (V) | 19.0 |
Output voltage (V) | 7.0 |
Output voltage (V) | 24.0 |
Output voltage (V) | 12.0 |
Output voltage (V) | 15.0 |
Output voltage (V) | 9.0 |
Output voltage (V) | 5.0 |
Output current (A) | 4.0 |
Output current (A) | 6.0 |
Output current (A) | 2.0 |
Input voltage (V) | 230.0 |
Input voltage (V) | 115.0 |
Power Supply | Regulated Linear Power Supply |
