HiVi SWANS M6a Loudspeaker Serial / Medium Aluminum-Magnesium 6.5 "
Reference : 4790
71,00 €tax incl.
59,17 € tax excl.
https://www.audiophonics.fr/images2/Swans_Logo.gif
The "M" series speakers were introduced for the first time through the "DIVA" range of the speaker manufacturer Swans.
The success of this collaboration was immediate, and the speakers were awarded for their exceptional quality / price ratio at the Home Entertainment Show of 2000.
The design of the M6a has been optimized to deep and dynamic exploration of low frequencies in a loadbass-reflex of reduced size .
Ultra rigid cone made of an alloy of aluminum and magnesium coated on the surface with a damping material that promotes dynamic stability
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
Can be used as a severe / medium unit on a 2-way system , or as a medium loudspeaker on a 3-way system more sophisticated.
https://www.audiophonics.fr/images2/4782_SWANS-HIVI-M6a_1.jpghttps://www.audiophonics.fr/images2/4782_SWANS-HIVI-M6a_2.jpg
https://www.audiophonics.fr/images2/4782_SWANS-HIVI-M6a_3.jpg
Specifications:
  • Nominal Impedance:8Ω
  • Resonant Frequency: 44Hz
  • Rated Power:45W
  • Maximum Power Output:90W
  • Sensitivity (2.83v / 1m): 88dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 25mm
  • Length Coil:14.5mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: Ferrite
  • Magnetic Shielding:/ Strong>Yes
  • BL:7.6
  • Hey :6.0mm
  • XmaX:4.3mm
  • Cms:811
  • Qms:2.47
  • Qes:0.49
  • Qts:0.40
  • Mms:15.8g
  • Sd:0.0139m2
  • Vas:20.4L
  • Recommended Type of Load: Bass Reflex
  • Recommended Load Volume: 15L
  • Recommended Cut-Off Frequency -3dB: 44Hz
  • Weight:2.0Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4782_SWANS-HIVI-M6a_4.jpg
HiVi M6a:Dimensions
https://www.audiophonics.fr/images2/4782_SWANS-HIVI-M6a_5.jpg
HiVi M6a:Frequency Response
https://www.audiophonics.fr/images2/4782_SWANS-HIVI-M6a_6.jpg
HiVi M6a:Impedance Curve
Speaker TypeMidbass
