En charge avec un préamplificateurs phono Pro-Ject Tube Box DS3 B, l'alim. monte à 52°C avec 26 °C dans le local....Je pense placer des dissipateurs thermiques.
This LHY Audio LPS25VA regulated linear power supply is ideal for any high-quality audiophile project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will pair perfectly with your HiFi equipment operating at 18V.
This power supply includes a Talema transformer coupled with an OPA 177 for even greater voltage stabilization and control. EMI filtering is also included to eliminate interference created by alternating current (AC). Furthermore, a set of three CLC filters positioned at the input and output of the power supply ensure efficient filtering and guarantee a noise-free signal. Last but not least, a bridge rectifier ensures reliable current stabilization, even during prolonged use. The result is a stable output signal with a noise level not exceeding 200uV when used to its full capacity.
The power supply features an aluminum alloy case for efficient heat dissipation and two DC 5.5/2.1mm jack output. Finally, you can adjust the output voltage on the back of the device by ±0.5V if required.
Input voltage | 220-240V |
Output Voltage / current | 18V 1A |
Outputs | 2x Jack DC 5.5/2.1mm |
Input | IEC |
Case material | Aluminium alloys |
Dimensions | 110mm x 155mm x 63mm |
Weight | 1.114kg |
Package | 1x LHY Audio LPS25VA 1x DC 5.5/2.1mm male/male jack cable 80cm 1x Power supply cable |
Input | IEC C14 |
Output | Jack DC 5.5/2.1mm |
Color | Black |
Output voltage (V) | 18.0 |
Output current (A) | 1.0 |
Input voltage (V) | 230.0 |
Input voltage (V) | 240.0 |
Input voltage (V) | 220.0 |
Power Supply | Regulated Linear Power Supply |
Average votes 3.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Alain B.
