FURUTECH FI-06 NCF (R) IEC Inlet Rhodium plated Pure Copper Ø3.5mm
Reference : 11108
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 09-06-2026.
A novelty of the famous firm, this affordable IEC base is equipped with pure copper conductors Rhodium treated according to the processes of the brand.
Ca new version called NCF (Nano Crystal Formula) incorporates into the insulating body an active material generating negative ions which eliminate static discharges by converting them into thermal energy in the infrared spectrum.
Furutech combines this crystalline material with ceramic particles and carbon powder with electric Piezo damping properties.
Conjugation with the Nano Formula Crystal and the piezo ceramic particles provides the ultimate electrical outlet, a long culmination of Furutech's know-how in this field.
NCF technology:
Incorporated in the new series of Furutech products, the NCF (Nano Crystal² Formula) consists of a special crystalline material that has two "active" properties.
TFirst, it generates negative ions that eliminate static electricity, but it also converts thermal energy into far infrared (LIR) whose wavelength varies from (50 μm to 5 mm).
Furutech combine then this remarkable material with nanometric ceramic particles and carbon powder for their "Piezo Effect" (damping properties).
The resultant Nano Crystal² (NCF) is the ultimate electrical and mechanical damping material - (Only available inFurutech products!).
Features:/ Strong>
  • Pure Copper conductors Rhodium-plated copper treated with the "Furutech Alpha α" anti-magnetism process
  • Case: Nylon / Fiberglass
  • NCF: Addition of antistatic nano crystalline particles in the carbon ceramic body
  • This socket adapts to a conductor diameter up to 3.5mm
  • To screw
Dimensions:
  • 50.5x23.9x33.5mm
  • 250V 15A
Max cable diameter (mm)3.5
Mounting typeTo screw
ConnecticMale
ConnectorIEC C14
Rated current (A)15.0
7 reviews
Du NCF accessible
En remplacement de l'IEC FI-06 d'origine d'une barrette MPC5 Stealth, cet upgrade est très facile à réaliser.
Cette IEC est légèrement plus profonde que la FI-06.
Les améliorations du rhodium et du NCF sont tout de suite évidentes.
La scène sonore s'élargit, le son semble gagner en précision.
Le rodage est très long, au moins 400 h.
À moins de 50 €, c'est une aubaine.
This review has been posted for FURUTECH FI-06 NCF (R) IEC Inlet Rhodium plated Pure Copper Ø3.5mm
Que du bon
En remplacement de la fiche d'origine d'un streamer/dac/préamp améliore la spatialisation, la séparation des instruments et renforçant la sensation de silence.
Amélioration évidente.
Cette embase IEC apporte des améliorations similaires à l'embase schuko cuivre rhodium de la même marque...
Timbres riches et nuancés, extension et beauté des graves, scène sonore étendue et mieux organisée, silence et douceur, plus de détails sur tout le spectre sonore.
Dommage que sa grande soeur l'IEC fi-09 soit si chère car elle va probablement plus loin encore.
Ne pas hésiter
en remplacement de l’embase d’origine sur un NAD C638, l’apport est sans conteste, tout est mieux et surtout les graves sont plus définis.
jm
Upgrade Esoteric
En remplacement de la fiche d'origine (furutech rhodium) cette fiche est de construction plus robuste et surtout les résultats sont bien supérieurs en terme de présence sonore.
