EARACOUSTICS OSHUN LTD In-Ear Monitors
The EarAcoustic Oshun LTD are in-ear monitors featuring a dynamic driver designed to deliver an extended and structured response across the entire frequency spectrum. They rely on a titanium diaphragm combined with a carbon suspension, along with an opposed dual magnet architecture and dual acoustic cavity, allowing the driver behavior to remain stable while maintaining controlled bass and transient response.
Reference : 22043
149,00 €tax incl.
124,17 € tax excl.
EarAcoustic Oshun LTD In-Ear Earphones IEM Dynamic 26 Ohm 110dB 20Hz-20kHz
EarAcoustic Oshun LTD: Front view
Designed for versatile listening, they articulate a slightly elevated low-end, a linear midrange, and a progressive treble, enabling a clear and airy reproduction of musical content.
EarAcoustic Oshun LTD: Titanium dynamic driver
The EarAcoustic Oshun LTD integrate a dynamic driver whose titanium diaphragm combines high rigidity with controlled mass, allowing deformation during transient response to be minimized while maintaining accurate micro-detail reproduction. This approach is extended by a carbon suspension, whose elasticity and damping properties effectively control parasitic movements, stabilizing diaphragm excursion across the usable range.
Beyond materials, the opposed dual magnet architecture structures a more homogeneous magnetic field around the voice coil, which linearizes the driving force while reducing distortion linked to flux variations. This configuration is part of a dual acoustic cavity design, allowing internal pressure and driver loading behavior to be adjusted, resulting in improved bass control.
EarAcoustic Oshun LTD: driver
EarAcoustic Oshun LTD: Frequency response
The frequency response features a slight boost of approximately +2 dB between 20 Hz and 200 Hz, providing a perceptible low-end foundation while maintaining controlled energy levels, which helps prevent fatigue during extended listening sessions. This base extends into a linear response between 200 Hz and 2 kHz, ensuring clear and well-structured midrange reproduction without masking effects.
Continuing upward, a gradual rise between 2 kHz and 20 kHz, with a peak around 9 kHz, enhances airiness and detail perception while maintaining balance that limits aggressiveness. The overall result is a presentation that remains both readable and extended, suitable for a wide range of musical styles.
EarAcoustic Oshun LTD: frequency response curve
EarAcoustic Oshun LTD: Aluminum housing
The aluminum housing provides a rigid structure that limits parasitic resonances while offering stable support for the driver. This structure is extended by a crystalline-textured finish, which fragments light and reveals evolving reflections depending on the viewing angle.
Beyond its mechanical role, this surface treatment places the earphones within a jewelry-inspired visual approach, where material work and light interplay contribute to the identity of the object, allowing it to extend beyond pure audio function into a product with strong visual presence.
EarAcoustic Oshun LTD: Silver-plated OCC copper cable
The Oshun LTD come with a CIEM to 3.5mm jack cable made of silver-plated OCC (Oxygen-Free Copper), ensuring high-quality signal transmission to fully exploit the performance of your earphones.
EarAcoustic Oshun LTD: Cable
Product typeIn-ear earphones
Drivers1x Dynamic driver Ø8.3mm
Impedance26Ω
Sensitivity110dB
Frequency response20Hz-20kHz
Total harmonic distortion (THD)<0.5%
CableDetachable
Earphone connectors0.78mm 2 pins
Cable termination3.5mm jack
Cable materialSilver-plated OFC copper
ColorSilver
Package contents1x EarAcoustic Oshun LTD
1x 3.5mm jack to 0.78mm 2 pins cable
1x Carrying pouch
6x Pairs of ear tips
ColorSilver
Impedance (Ω)26
Efficiency / Sensitivity (dB)110
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
EARACOUSTICS OSHUN LTD In-Ear Monitors IEM Dynamic 26 Ohm 110dB 20Hz-20kHz
The EarAcoustic Oshun LTD are in-ear monitors featuring a dynamic driver designed to deliver an extended and structured response across the entire...
