HIDIZS MK12 TURRIS In-Ear Monitors Jack 3.5mm Black
The Hidizs MK12 Turris are single dynamic driver in-ear headphones designed to deliver balanced and accurate sound reproduction. They feature a large 12mm driver with a 91% magnesium diaphragm, combined with a 1.5 Tesla magnetic circuit. This design aims to optimize diaphragm rigidity while reducing harmonic distortion.
Reference : 21225
179,00 €tax incl.
149,17 € tax excl.
Hidizs MK12 Turris Écouteurs Intra-Auriculaires IEM Dynamique Jack 3.5mm Noir
Hidizs MK12 Turris
The Hidizs MK12 Turris are single dynamic driver in-ear monitors designed to deliver balanced and accurate sound reproduction. They feature a large 12mm driver with a 91% magnesium diaphragm, combined with a 1.5 Tesla magnetic circuit. This design aims to optimize diaphragm rigidity while reducing harmonic distortion.
Hidizs MK12 Turris: Optimized architecture, meticulous design
The 12mm dynamic transducer is based on an M-shaped magnesium alloy diaphragm, a material chosen for its lightness and internal damping capacity. The dual magnetic circuit provides a flux density of 1.5T, enabling a fast response to transients and better extension at the lower end of the spectrum.
The whole thing is housed in a CNC-machined aluminum alloy shell, whose geometry is inspired by the Turritopsis dohrnii jellyfish. This enclosure has a semi-open structure, promoting a more airy soundstage while limiting internal resonances.
Hidizs MK12 Turris: Interchangeable acoustic filters
The MK12 Turris incorporates a system of interchangeable acoustic filters, allowing you to modify the sound signature:
  • Red filter: accentuation of the upper end of the spectrum, improved ventilation and clarity.
  • Silver filter: balanced response, neutral profile.
  • Black filter: Slight emphasis on low frequencies, warmer sound.
Each filter acts on the acoustic pressure at the transducer vent, thereby modifying the response curve and the perception of the sound stage.
Hidizs MK12 Turris: Silver-plated OFC copper cable
The supplied cable features silver-plated OFC copper conductors, terminated with 0.78mm 2-pin CIEM connectors on the earphone side. On the source side, this model features an asymmetrical 3.5mm jack connector.
Hidizs MK12 Turris: Perfect ergonomics
The metal shells feature an ergonomic three-point support profile, ensuring good passive isolation without excessive pressure. Silicone ear tips are provided in several sizes. Low impedance and high sensitivity allow for easy control from a smartphone, compact USB DAC, or portable HiFi player.
Hidizs MK12 Turris: Frequency response curve
Product typeIn-ear monitors
Speaker driver typeDynamic 12mm
Driver diaphragmMagnesium, M-Shaped
Magnet strength1.5T
Cable conductors materialSilver plated OFC copper
Cable length1.2m
Earphones connectorsCIEM 0.78mm 2 pins
Frequency response10Hz - 45kHz
Sensitivity111dB
Impedance32Ω
Earphones shell materialCNC machined aluminum alloy
Weight~ 19g
Package1x Hidizs MK12 Turris
1x Storage pouch
1x Jack 3.5mm cable
9x Pairs of silicone ear tips (Bass / Vocal / Balanced)
3x Pairs of filters (High frequencies / Balanced / Low frequencies)
Impedance (Ω)32
Efficiency / Sensitivity (dB)111
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
HIDIZS MK12 TURRIS In-Ear Monitors IEM Dynamic Jack 3.5mm Black
The Hidizs MK12 Turris are single dynamic driver in-ear headphones designed to deliver balanced and accurate sound reproduction. They feature a...
