LETSHUOER ASTRALIS In-Ear Monitors IEM
The Letshuoer Astralis are planar magnetic in-ear monitors designed to deliver precise and responsive sound reproduction. They feature a 15.5mm driver combined with a balanced magnetic architecture, allowing for precise control of the diaphragm’s movement to maintain linear reproduction across the entire frequency range.
Reference : 21764
189,00 €tax incl.
157,50 € tax excl.
Letshuoer Astralis In-Ear Monitors IEM Planar Magnetic 12 Ohm 104dB 20Hz-40kHz
Letshuoer Astralis : Front view
Letshuoer Astralis: 15.5mm planar magnetic driver
The Astralis features a 15.5mm planar magnetic driver, whose circular diaphragm ensures uniform air displacement, thereby delivering a fast transient response and extended reproduction. This design is complemented by a voice coil positioned on either side of the diaphragm, allowing for a symmetrical distribution of electromagnetic force, whilst two sets of four N52 magnets stabilise the magnetic flux to maintain linear control of the movement, thereby reducing distortion at high volumes.
Letshuoer Astralis : Cross-section of the driver
Letshuoer Astralis : Silver-plated copper cable
Letshuoer Astralis: Silver-plated copper cable
The Astralis come with a silver-plated copper cable, which optimises conductivity whilst minimising high-frequency signal loss. This design is complemented by an interchangeable 3.5 mm or 4.4 mm termination, allowing the earphones to be easily adapted to different sources without the need for an adapter.
Product typeIn-ear monitors (IEM)
DriversPlanar magnetic
Impedance20Ω
Sensitivity104dB
Frequency response20Hz-40kHz
Chassis materialsAluminum
Earphone connectorsCIEM 0.78mm 2 pins
Cable terminationJack 3.5mm
Jack 4.4mm
Cable materialsSilver-plated copper
ColorSilver
Package1x Letshuoer Astralis
1x Storage box
1x Earphone cable
1x 3.5mm jack termination
1x 4.4mm jack termination
5x Pairs of ear tips
ColorSilver
Impedance (Ω)20
Efficiency / Sensitivity (dB)104.0
WirelessNo
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
LETSHUOER ASTRALIS In-Ear Monitors IEM Planar Magnetic 12 Ohm 104dB 20Hz-40kHz
The Letshuoer Astralis are planar magnetic in-ear monitors designed to deliver precise and responsive sound reproduction. They feature a 15.5mm...
