MOONDROP ARMATURE ART 12 In-Ear Monitors
The Moondrop Armature Art 12 are in-ear headphones featuring a fully balanced armature design, engineered to structure sound reproduction around a strict frequency division. They feature 12 drivers arranged in a 4+4+4 configuration, utilising a 3-way crossover to ensure controlled distribution of the frequency ranges, thereby limiting unwanted interactions between registers and stabilising tonal consistency.
By buying this product you get 87 loyalty points
Reference : 21952
879,00 €tax incl.
732,50 € tax excl.
Moondrop Armature Art 12 In-Ear Monitors IEM Balanced Armature 5 Ohm 121dB 6Hz-34kHz
Moondrop Armature Art 12 : Front view
The Moondrop Armature Art 12 are in-ear monitors featuring a fully balanced armature design, engineered to structure sound reproduction around a strict frequency division. They feature 12 drivers arranged in a 4+4+4 configuration, utilising a 3-way crossover to ensure controlled distribution of the frequency ranges, thereby limiting unwanted interactions between registers and stabilising tonal consistency.
Moondrop Armature Art 12: Frequency response
The Moondrop Armature Art 12 are in-ear headphones featuring balanced armature drivers, designed to structure the sound reproduction around precise frequency separation. They feature 12 drivers arranged in a 4+4+4 configuration, utilising a 3-way crossover to assign each frequency range a dedicated operating band, thereby minimising phase interference. This arrangement maintains a consistent frequency response whilst ensuring clear reproduction of subtle details across the entire spectrum.
Moondrop Armature Art 12 : Frequency response curve
Moondrop Armature Art 12: Quick bass response
The bass range is driven by four balanced armature drivers with stainless steel diaphragms, whose open-back design allows the diaphragm to move more freely. This design reduces internal compression effects, enabling a fast transient response whilst maintaining a noticeable extension in the low frequencies. Beyond sheer impact, this approach prioritises the clarity of textures, particularly with complex signals or sustained bass.
Moondrop Armature Art 12 : Balanced armature drivers
Moondrop Armature Art 12: Structured medium
The midrange reproduction is handled by two sets of two balanced armature drivers featuring aluminium-magnesium composite diaphragms, whose controlled rigidity minimises distortion during dynamic playback. The integration of a Y-shaped acoustic structure organises the convergence of sound waves, thereby aligning the phases and stabilising the central soundstage. This configuration results in a well-defined reproduction of vocals and instruments, whilst maintaining tonal continuity with adjacent registers.
Moondrop Armature Art 12: Extended treble range
The high frequencies are handled by a 4-in-1 balanced armature module, incorporating aluminium-magnesium alloy diaphragms to combine lightness with rigidity. This modular design ensures consistent performance across the transducers in the extreme high frequencies, reducing response variations between individual units. The result is a smooth extension at the top of the spectrum, allowing for the reproduction of subtle harmonics without localised accentuation.
Moondrop Armature Art 12: Optimised acoustic cavity
The internal cavity is precisely engineered to control acoustic volumes and propagation paths, directly influencing the overall signal coherence. Its manufacture using DLP (Digital Light Processing) 3D printing allows for the faithful reproduction of complex internal structures, ensuring dimensional repeatability and acoustic stability. This approach results in better management of internal resonances, contributing to the linearity of the sound reproduction.
Moondrop Armature Art 12: Interchangeable termination cable
The copper cable features a Litz-type structure, which minimises skin effect and high-frequency losses, thereby preserving the integrity of the transmitted signal. In addition to its high conductivity, it incorporates a system of interchangeable terminations, supplied with 3.5 mm and 4.4 mm jack connectors, allowing for direct connection to various sources.
Product typeIn-ear monitors
Drivers12x Balanded Armature
Impedance5Ω ±15% @1kHz
Sensitivity121dB
Frequency response6Hz-34kHz
Total harmonic distortion more noise (THD+N)≤0.6% @ 1kHz 94dB
Earphone connectorsCIEM 0.78mm 2pin
Cable terminationDetachable : Jack 4.4mm / Jack 3.5mm
Conditionnement1x Moondrop Armature Art 12
1x Modular cable termination
1x Jack 4.4mm termination
1x Jack 3.5mm termination
3x Pairs of eartips (S/M/L)
Impedance (Ω)5
Efficiency / Sensitivity (dB)121.0
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
MOONDROP ARMATURE ART 12 In-Ear Monitors IEM Balanced Armature 5 Ohm 121dB 6Hz-34kHz
The Moondrop Armature Art 12 are in-ear headphones featuring a fully balanced armature design, engineered to structure sound reproduction around a...
