MOONDROP LAN II POP In-Ear Monitor
With the LAN II, Moondrop presents stainless steel in-ear monitors featuring a 10mm dynamic driver with a glass diaphragm. These headphones are unique in that they are available in two versions with different frequency responses: POP and REF. Here, the POP version offers more accentuated low-mids, perfect for pop music.
Reference : 21192
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 17-11-2026.
Moondrop LAN II POP Dynamic In-Ear Monitor IEM Ø10mm 30Ω 118dB 12Hz-60kHz
Moondrop Lan II POP : Vue de face
Moondrop LAN II POP: Glass composite membrane
The Moondrop LAN II features a brand new composite membrane with a glass dome. This solid glass dome, only 0.05mm thick, is manufactured using a high-precision mould coupled with a specialised manufacturing process. It has an ultra-high Young's modulus and exceptional internal resistance coefficient, which together provide high-frequency extension and resolution that traditional diaphragms cannot achieve.
This glass diaphragm is accompanied by a custom-designed suspension system designed to provide the most linear deformation possible over a long stroke. This combination results in ultra-low distortion, a wide dynamic range and high-frequency resolution of rare quality.
Moondrop Lan II POP : Glass composite membrane
Moondrop Lan II POP : stainless steel housing
Moondrop LAN II POP: Stainless steel housing
The Moondrop LAN II also features a stainless steel body obtained through a MIM (metal injection moulding) metallurgical process, resulting in a highly precise finish with a richly detailed texture. The design is enhanced by laser engraving that echoes the iconic Lan series design for a look that is both understated and classy.
Moondrop LAN II POP: Frequency response
The LAN II headphones are available in two versions with different frequency responses. This POP version benefits from a setting that emphasises the low-mid range, offering a final result that highlights vocals and more atmospheric sounds, ideal for pop music.
Moondrop Lan II POP : Frequency response curve
Moondrop LAN II POP: OFC Copper Cable
The LAN II comes with a 4.4mm to 0.78mm 2-pin jack cable and a 4.4mm to 3.5mm jack adapter, both made of OFC copper to ensure high-quality signal transmission.
Moondrop Lan II POP : écouteurs avec leurs câble
Product typeIn-ear monitors (IEM)
Speakers1x Dynamic driver
Dynamic driver diaphragmØ10mm glass
Impedance30Ω ±15% @ 1kHz
Sensitivity118dB @ 1kHz
Total harmonic distortion (THD)≤0.08 @ 1kHz 94dB
Frequency response12Hz-60kHz
CableDetachable
Headphone connectors0.78mm 2 pins
Cable terminationJack 4.4mm
Cable materialOFC Copper
Headphone body materialStainless steel
ColorSilver
Package1x Moondrop LAN II POP
1x 4.4mm to 0.78mm 2-pin jack cable
1x 4.4mm to 3.5mm jack adapter
ColorSilver
Impedance (Ω)30
Efficiency / Sensitivity (dB)118.0
WirelessNo
Phone call featureNo
Noise reductionNo
MOONDROP LAN POP Dynamic In-Ear Monitor IEM Ø10mm 30 Ohm 118dB 12Hz-60kHz
With the LAN II, Moondrop presents stainless steel in-ear monitors featuring a 10mm dynamic driver with a glass diaphragm. These headphones are...
