ROSESELSA x AAV CJ20 In-Ear Monitors IEM
The Roseselsa CJ20 are in-ear earphones with planar magnetic drivers, designed in collaboration with Andy (AndyAudioVault). They feature a 14.2mm driver to ensure precise transient response and low distortion, thereby preserving the clarity and coherence of the sound across the entire frequency range.
Reference : 21703
149,00 €tax incl.
124,17 € tax excl.
Roseselsa x AAV CJ20 In-Ear Monitors IEM Planar Magnetic 24 Ohm 102dB 20Hz-20kHz
Roseselsa CJ20 : Front view
Roseselsa CJ20: Planar magnetic transducer
The Roseselsa CJ20 features a 14.2mm planar magnetic driver designed to ensure a fast transient response, whilst minimising distortion to preserve signal clarity across the entire frequency spectrum. This design, in addition to its intrinsic responsiveness, delivers a smooth, natural sound, ensuring listening comfort without auditory fatigue during long listening sessions.
Roseselsa CJ20 : Planar magnetic transducer
Roseselsa CJ20 : All-metal chassis
Roseselsa CJ20: All-metal body frame
The all-metal chassis is built on a rigid structure that effectively absorbs the mechanical stresses of everyday use, whilst minimising unwanted vibrations that could distort the audio signal. Beyond durability, this structural mass acts as a passive dampener of internal resonances, resulting in reduced background noise and improved separation of detail. This design is therefore not merely an aesthetic choice, but forms part of a strategy for vibration control, helping to stabilise sound reproduction in a variety of listening environments.
Roseselsa CJ20: Graphene-coated OCC cable
The CJ20 features a graphene-coated OCC single-crystal copper cable, whose high conductivity helps minimise signal transmission losses. This core design is complemented by interchangeable modular connectors in Jack 3.5mm and Jack 4.4mm sizes, allowing the headphones to be easily adapted to both single-ended and balanced sources without any changes to the setup.
Roseselsa CJ20 : Graphene-coated OCC cable
AndyAudioVault
Roseselsa CJ20: Developed in collaboration with AndyAudioVault
The CJ20s have been tuned in collaboration with Andy (AndyAudioVault), with a tonal character designed for rock music, taking into account the dynamic range and clarity requirements specific to this type of recording. This tuning is accompanied by two sets of silicone ear tips – wide and narrow – allowing you to adjust the frequency balance and bass response to suit your needs.
Product typeIn-Ear Monitors
Drivers1x 14.2mm planar magnetic driver
Impedance24Ω
Sensitivity102dB
Total harmonic distortion (THD)≤ 3% @ 1kHz
Frequency response20Hz-20kHz
Cable conductorGraphene-coated OCC copper
Earphone connectorsCIEM 0.78mm 2 pins
Termination connectorsJack 3.5mm
Jack 4.4mm
Package1x Roseselsa CJ20
1x CIEM cable
1x 3.5mm jack termination
1x 4.4mm jack termination
1x Carrying bag
8x Pairs of ear tips
Impedance (Ω)24
Efficiency / Sensitivity (dB)102.0
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
ROSESELSA x AAV CJ20 In-Ear Monitors IEM Planar Magnetic 24 Ohm 102dB 20Hz-20kHz
The Roseselsa CJ20 are in-ear earphones with planar magnetic drivers, designed in collaboration with Andy (AndyAudioVault). They feature a 14.2mm...
