AUDIO-GD MASTER 10 BYPASS PREAMP 2019 EDITION Class-A Balanced Amplifier ACSS 2x 500W 4 Ohm with Preamplifier Bypass
The Audio-GD Master 10 is an impressive, symmetrical Class A amplifier that delivers great power to accompany the most demanding lousdspeakers. In this version, the Master 10 offers a bypass input group preamplifier to take advantage of an external preamplifier to transform the Master in pure power amplifier.
KEY FEATURES :
  • Amplificateur intégré
  • Class A
  • Symmetricall
  • ACSS
  • 2 x 250W 8 Ohms / 2 x 500W 4 Ohms
  • Preamplifier Bypass
By buying this product you get 227 loyalty points
Reference : 12438
2 279,00 €tax incl.
1 899,17 € tax excl.
AUDIO-GD MASTER 10 Edition 2015
Integrated Amplifier / Class A Symmetrical ACSS / Preamplifier Bypass
Audio-GD Master 10 edition 2015
2019 Edition
Linear Fidelity & Non Negative Feedback
For this 2019 Edition of its Master 3, Audio-GD has updated its Class A amplifier to allow it to offer ever better audio measurements. The brand thus integrates Linear Fidelity technologies into the output circuits and Non-Negative Feedback into the amplifier in general. This particular design allows to obtain a linear response curve as well as a very low distortion level, for a sound reproduction of a very high transparency and this whatever the output level and the reproduced frequency.
An integrated amplifier of high power ...
Audio-GD introduces us once again to the quintessence of the audio technology with this Master 10 amplifier with more than neat and clean architecture.
The famous brand of high-fidelity audio offers here an amplifier in the most accomplished form possible with outstanding performance: it delivers 2x 250W under 8 Ohm, and 2x 500W under 4 Ohm.
Every product of the brand is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzer 2700 Series from Audio Precision. The bypass is located on the IN 4 serigraphed connector.
A Master 10 with Preamplifier Bypass
The Master 10 offers a complete system with preamplification and amplification. In addition, for those who would like to take advantage of an external preamplifier, Audio-GD includes in this version a Bypass Pre-Amplifier input group, making it possible not to use the preamplifier section. Only the amplifier power part function In this way, you can benefit from an extremely flexible system. It's especialy made for Home theater system to.
Extremely efficient clean connections
The Master 10 has 5 analog inputs: 2x RCA / 2x XLR / 1x ACSS. The output is of course on 2 HP terminals, where you just have to connect your speakers to enjoy. The unit also has a bypass mode for not using the preamp section, which is located on the IN4 serigraphed connector.
The result is unmatched: great musicality, thanks to an exceptional dynamic and a rich sound extremely detailed in all points. You can tell you that you are approaching - see attPerfect with this HiFi device.
audio-gd master 10 edition 2015
An unusual amplifier
Class A Symmetric / R-Core / ACSS / Integrated
This Master 10 is equipped with no less than 4 transformers including 2 R-Core for a total of 1500W, 140,000uF of very high-end Nover capacitors, and 24 very high performance MJL1302 / 3281 transistors for the output stage .
This amplifier is also designed around a purely symmetrical discrete circuit of Class A ACSS, with separate power supply to avoid any interference or electromagnetic disturbances on the signal.
ACSS
Audio-GD has its own technology signature called ACSS for "Audio-GD Current System Signal". Thanks to the firm's expertise and know-how, this technology offers a less colorful, detailed soundt unparalleled neutrality.
Every professional engineer of the brand is, in addition to being experienced, a passionate of HiFi and Audio like you and us. That is, when the ACSS output is used, the XLR and RCA outputs go to MUTE.
Class A
A class A amplifier has the particularity of having all its active components always in conduction. They fully amplify the input signal, thereby limiting harmonic distortion on the output signal. The outgoing signal of the Master 10 is therefore of excellent quality, due to the absence of this famous distortion of crossing of the alternations of the sinusoids.
Signal Noise ratio> 115dB
Voltage Ouput58V
Sensibility voltage input0.775Vrms (RCA) / 1.55Vrms (XLR) / 2mA rms (ACSS)
Frequency Reponse20Hz - 20kHz (0.01dB)
Ouptut2x Binding post output for loudspeakers
input2x RCA
2x XLR
1x ACSS
(Bypass on the IN4 connector)
Input impedance47KΩ (RCA) / 94KΩ (XLR) / < 10Ω (ACSS)
Crosstalk> -120dB
Power Output2x250W  8Ω / 2x500W  4Ω
Preamplifier bypass Yes
Divers
Consumption130W
Power supply device4 Transformers with 2 R-Core for 1600W
WeightEnviron 40kg
Enclsoure material100% Aluminium
ColorNoir
Dimensions480 x 440 x 190mm
AccessorysMetal remote and IEC power cord
InputACSS
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)250.0
2 reviews
AUDIO GD MASTER-10 BYPASS PREAMP
J'ai eu Accupphase, Audio Research et c'est du même acabit !
Allucinant de précision, de puissance, de facilité d'emploi ! J'ai mis deux paires d'enceintes dessus car j'ai un très grand salon deux Triangles Antal ESW et deux Focal 948 et alors là c'est royal ! Je conseil vraiment ce matériel de très haute qualité et de belle finition. Le son est pur, d'un naturel et d'une netteté rarement égalé, de plus aucun bruit parasite et pas un souffle.
This review has been posted for AUDIO-GD MASTER 10 BYPASS PREAMP 2019 EDITION Class-A Balanced Amplifier ACSS 2x 500W 4 Ohm with Preamplifier Bypass
Fantastique
Sur les forums tout a été dit sur cette marque excellente au rapport qualité prix hallucinant.vous pouvez acheté les yeux fermés.la seule chose qui me chagrine ,c'est au bout de 2ans de garantie,il faut renvoyé l'appareil chez le constructeur en cas de panne ,et vu le poids,c'est surement plusieurs centaines d'euros en frais d’expédition.
The Audio-GD Master 10 is an impressive, symmetrical Class A amplifier that delivers great power to accompany the most demanding lousdspeakers. In...
