Class D Amplifier TPA3116 2x50W
The A10 is the very first amplifier proposed by Loxjie. It uses a TPA3116 chip from TI, combined with an intelligent and neat architecture and a perfectly adjusted amplification circuit.
At the heart of this A10 with its unique format is a high-performance TPA3116D2 TI chip, capable of developing a power of 2x50W while offering a beautiful sound richness and excellent precision. Its Class D architecture also allows it to benefit from a high efficiency of at least 90% but also a low distortion. It can therefore be combined with many speakers, including demanding models, without showing any sign of weakness.
For the connectivity of this A10, Loxjie has chosen to go straight to the point by offering the essential and focusing on the quality of the connectors. Thus, there is a stereo RCA input and speaker terminal block outputs, accepting banana plugs. Each connector is gold plated, for good signal conductivity and oxidation resistance.
Loxjie has developed a custom power supply to ensure an efficient energy supply to the entire system. The power supply stage thus contributes to providing an impressive transient response for this type of device! In addition, the A10 includes a memory function to store its on or off state. Thus, if you unplug the unit when it is turned on, it will automatically turn on again when you plug it back in. Conversely, if you disconnect it when it is turned off, then the unit will be turned off the next time it is connected.
The components of the A10 are integrated in a beautiful CNC machined Aluminium housing. A compact and minimalist housing with a particular form factor, since the latter is triangular. An originality that will attract everyone's attention.
| Specifications | |
| Product type | Amplifier |
| Amplification type | Class D |
| Amplification chip | TPA3116 |
| Power | 2x50W @ 4Ω |
| Input | 1x RCA |
| Output | Speaker terminal |
| THD+N | 0.08% |
| SNR | 75dB |
| Channels separation | 65dB |
| General | |
| Case material | CNC Machined Aluminium |
| Color | Black |
| Consumption | 40W |
| Standby consumption | 0.5W |
| Dimensions | 193 x 84 x 58mm |
| Weight | 475g |
| Power supply included | - |
| Input | RCA |
| Color | Black |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TPA3116D2 |
| Power (W) | 60.0 |
