LOXJIE A10 Class D Amplifier TPA3116 2x50W / 4 Ohm Black
The A10 is the very first amplifier proposed by Loxjie. It uses a TPA3116 chip from TI, combined with an intelligent and neat architecture and a perfectly adjusted amplification circuit.
Reference : 13828
85,00 €tax incl.
70,83 € tax excl.
Loxjie A10
Loxjie A10 Amplificateur Class D TPA3116 2x60W
High Fidelity Class D Amplification
At the heart of this A10 with its unique format is a high-performance TPA3116D2 TI chip, capable of developing a power of 2x50W while offering a beautiful sound richness and excellent precision. Its Class D architecture also allows it to benefit from a high efficiency of at least 90% but also a low distortion. It can therefore be combined with many speakers, including demanding models, without showing any sign of weakness.
Quality connectivity
For the connectivity of this A10, Loxjie has chosen to go straight to the point by offering the essential and focusing on the quality of the connectors. Thus, there is a stereo RCA input and speaker terminal block outputs, accepting banana plugs. Each connector is gold plated, for good signal conductivity and oxidation resistance.
Custom power supply
Loxjie has developed a custom power supply to ensure an efficient energy supply to the entire system. The power supply stage thus contributes to providing an impressive transient response for this type of device! In addition, the A10 includes a memory function to store its on or off state. Thus, if you unplug the unit when it is turned on, it will automatically turn on again when you plug it back in. Conversely, if you disconnect it when it is turned off, then the unit will be turned off the next time it is connected.
Minimalist design
The components of the A10 are integrated in a beautiful CNC machined Aluminium housing. A compact and minimalist housing with a particular form factor, since the latter is triangular. An originality that will attract everyone's attention.
Product typeAmplifier
Amplification typeClass D
Amplification chipTPA3116
Power2x50W @ 4Ω
Input1x RCA
OutputSpeaker terminal
THD+N0.08%
SNR75dB
Channels separation65dB
Case materialCNC Machined Aluminium
Consumption40W
Standby consumption0.5W
Dimensions193 x 84 x 58mm
Weight475g
Power supply included-
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)60.0
The A10 is the very first amplifier proposed by Loxjie. It uses a TPA3116 chip from TI, combined with an intelligent and neat architecture and a...
