DOUK AUDIO A5 Integrated Amplifier
The Douk Audio A5 integrated amplifier is a small amplifier based on audiophile components with a singular aesthetic. It relies on a TPA3255 amplifier chip and OPA NE5532 to deliver up to 2x120W under 4 ohm with the supplied power supply. Its PFFB circuit reduces distortion and greatly improves frequency response for accurate, authentic sound reproduction. In addition, an adjustable 30-200Hz high-pass filter limits low-frequency interference for fine, clear mids and highs.
4.5 / 5
Reference : 20709
124,00 €tax incl.
103,33 € tax excl.
Shipping date: 14-04-2026.
Douk Audio A5 Integrated Amplifier PFFB TPA3255 NE5532 2x120W 4 ohm
Photo of Douk Audio A5
The Douk Audio A5 integrated amplifier is a small amplifier based on audiophile components with a singular aesthetic. It relies on a TPA3255 amplifier chip and OPA NE5532 to deliver up to 2x120W under 4 ohm with the supplied power supply. Its PFFB circuit reduces distortion and greatly improves frequency response for accurate, authentic sound reproduction. In addition, an adjustable 30-200Hz high-pass filter limits low-frequency interference for fine, clear mids and highs. Furthermore, the OPAs are DIP 8 mounted for quick and easy replacement. In terms of design, an attractive transparent cover makes it possible to perform the operation without dismantling the unit. This glass also allows use of the RGB LED display, which sublimates the amplifier circuit and can be adjusted via DIP switch. On the rear panel, you'll find all the essentials in terms of connectors, with an RCA input, a speaker output and a 3.5mm AUX output, offering the possibility of setting up a 2.1-channel system with an active subwoofer, for example.
Douk Audio A5 set-up
Douk Audio A5: a powerful amplifier with PFFB circuit
The Douk Audio A5 features a TPA3255 chip coupled with NE5532 OPAs. A PFFB (Post-Filter Feedback) circuit greatly enhances the amplifier's performance. With the 48V 5A power supply supplied, the A5 is able to deliver up to 2x120W of power under a 4 ohm load. This power reserve makes it possible to provide sound for a relatively large space.
The power of the Douk Audio A5 amplifier
DOUK A5 power table
Power supplyImpedanceOutput power
32V 5A
78W+78W
71W+71W
65W+65W
36V/6A
107W+107W
100W+100W
94W+94W
48V/5A
120W+120W
110W+110W
102W+102W
48V/10A
250W+250W
210W+210W
185W+185W
Douk Audio A5: High-pass filter
A 30-200Hz high-pass filter, adjustable by means of a potentiometer on the front panel of the Douk Audio A5, minimizes low-frequency interference for clearer sound reproduction.
The Douk Audio A5 high-pass filter
DIP8 mounted OPA NE5532
Douk Audio A5: Interchangeable DIP8 OPAs
The NE5532 OPAs are DIP8-mounted, making them easy to replace. This is made even easier by the tempered glass window on the top of the amplifier. Here's a non-exhaustive list of OPAs that can replace NE5532s: 2134/2604/5532/2068/muse02 etc.
Douk Audio A5: RGB LED system
In terms of aesthetics, the A5 benefits from a tempered glass top and DIPSWITCH-adjustable LEDs.
Douk Audio A5 RGB LED system
Douk Audio A5 overview
DOUK AUDIO A5 overview
1Potentiometer for setting high-pass filter 30-200Hz
2Volume adjustment potentiometer
3Analog RCA stereo input
4AUX jack 3.5mm output
5Speaker terminal
6Power supply 24-48V via jack DC
Douk Audio A5 test par Audio Science Review
" Our journey into these pocket/desktop amps started around this $100 price range but without PFFB feature. Douk A5 disrupts this market by providing PFFB at the $100 price mark. There is a bit of high frequency distortion penalty there but otherwise, the rest of tests show excellent engineering, put a big smile on my face! I am happy to recommend the Douk Audio A5 stereo amplifier. "
Logo ASR
Product typeIntegrated amplifier
Amplification chipTPA3255
OPAOPA5532
Input1x RCA input
OutputSpeaker terminal
1x Jack 3.5mm AUX output
Output power2x120W @ 4 ohm (48V 5A)
THD+N0.002%
SNR≥ 114dB
Frequency response20Hz-20kHz (±0.7dB)
Low-pass filter30Hz-200Hz
Input sensitivity2V
3.5mm jack output level3.7V
Power supplieDC 24-48V (48V 5A power supplie included)
Dimensions95 x 92 x 50mm
Weight506g
ColorNoir
Package1x Douk Audio A5
1x 48V 5A mains adapter
OutputJack 3.5mm
Channel2.1
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)120.0
2 reviews
VRAIMENT MUSICAL...
On retrouve avec ce Douk Audio A5 une transparence typique des amplis de classe D, transparence que j'ai pu aussi trouver sur certains amplis à transistors ou à lampes valant autour des 2000 euros. A la sortie du carton, le petit Douk manque singulièrement de puissance bien qu'alimenté par un bon bloc 48V 10A! en fait après une trentaine d'heures de rodage, la puissance de sortie s'accroît quelque peu, mais en aucun cas on obtient les valeurs (très exagérées) indiquées par le constructeur. Il est vivement conseillé de remplacer les deux AOP d'origine par de meilleurs composants: l'AOP discret SX52B d'origine chinoise s'accouple parfaitement avec le DOUK A5 alors qu'il est incompatible avec mon Aiyima A07 ou le Douk A5 pro (allez comprendre!). On peut aussi, si on est un peu bricoleur, souder un petit condensateur MKP de 1 microF aux pates du condensateur chimique de 3300 microF manière de compenser un peu l'inductance parasite des chimiques. Avec les quelques modifications précitées, musicalement ce petit DOUK s'avère être une belle surprise: définition et transparence sont à-même de révéler tous les détails de vos fichiers audio avec pour revers de révéler aussi tous les défauts d'une prise de son à condition que votre DAC et vos enceintes en soient capables bien sûr. Les timbres sont d'une beau réalisme, sans maigreur comme je l'avais constaté avec mon Aiyima A07 MAX et sans grossissement non plus; les extinctions de notes très convaincantes, mais ce qui est le plus réjouissant c'est l'imagerie stereo, véritablement holographique avec une extension en profondeur fort appréciable, qui vous transporte littéralement dans la salle d'enregistrement. Sur un plan purement pratique, les leds lumineuses vert/rouge/bleu qui éclairent les circuits sont parfaitement inutiles (on peut heureusement les désélectionner) et la vitre facilitant les changement des ampli ops ne tient que par miracle (bande adhésive), là aussi on aurait pu se passer d'un tel gadget. En résumé: un petit ampli peu coûteux, éminemment musical, qui mérite un bon DAC et des câbles de modulation soignés.
This review has been posted for DOUK AUDIO A5 Integrated Amplifier PFFB TPA3255 NE5532 2x120W 4 Ohm
Etonnant petit ampli A5
Essayé d'abord dans un ensemble cohérent : iPhone (avec un câble QED Reference) et des Klipsch 81MKII, ce qui donne une chaine abordable aux qualités musicales déjà plus qu'acceptables sur tout style de musique. Neutre, grave tenu, dynamique.
Puis essais avec un DAC Music Hall 25.3 (ECC88 Siemens N.O.S), câbles RCA Taralabs RSC Axiom, câbles enceintes Ecosse MS 2.3 sur des Audio Physic Tempo 25 et aussi Sonus Faber Concerto.
Étonnant arrive à rivaliser avec mon Thule IA150B (valeur 1800€ dans les années 2000) et distancé d'une courte tête par mon ampli à lampes (Optimisé et Full N.O.S). Au début j'avais mis un simple câble enceinte OFC 4mm2 et je le trouvais mat, avec une scène contenu entre les enceintes peu haute et peu profonde, manquant de richesse harmonique, de couleurs sur les cuivres, ainsi que de luminosité dans le haut du spectre. Le changement de câble a tout remis en place. Mon ampli à lampes le dépasse en aération, définition de la scène sonore, finesse, mais il fait plus de 30 fois son prix !
Cet ampli A5 est d'un RQP imbattable, musical, neutre et si vous prenez soin de la source, des câbles, il pourra déjà vous amener très loin.
Dans un second temps je vais essayer de changer les OP Amp par des LHY Audio (pour rester cohérent en prix) et voir ce dont il est capable... Mais c'est déjà une énorme surprise !
The Douk Audio A5 integrated amplifier is a small amplifier based on audiophile components with a singular aesthetic. It relies on a TPA3255...
