The Dynavox DA-300 is a Class D amplifier capable of delivering a 2x100W output power, providing a device with powerful and precise sound reproduction.
In terms of connectivity, the DA-300 is designed to be both comprehensive and efficient. It features a stereo RCA input, along with coaxial and optical inputs, as well as a USB input allowing the use of a USB drive up to 32GB. Outputs consist of banana-compatible screw speaker terminals for connecting stereo speakers and an HDMI ARC output. The whole is complemented by Bluetooth connectivity allowing audio streaming input.
Control of the device is handled both via the front panel knob integrated into the aluminum chassis and via the included remote control, allowing adjustment of volume, treble and bass, as well as source selection.
Technical specifications
| Specifications | |
| Product type | Integrated amplifier |
| Amplification type | Class D |
| Inputs | 1x Stereo RCA 1x Coaxial 1x Optical 1x USB-A (for USB storage device, max 32GB) Bluetooth 5.0 |
| Outputs | Speaker terminals 1x HDMI ARC |
| Rated output power | 2x100W @ 4 Ohm |
| Impedance | 4-8 Ohm |
| Frequency response | 20Hz-20kHz |
| SNR | > 90dB |
| THD | 0.1% |
| Input sensitivity | 500mV @ 1kHz, THD 1% |
| Supported USB formats | MP3, WMA, FLAC, APE |
| General | |
| Power supply voltage | DC 18V 3A |
| Dimensions | 180 x 50 x 140mm |
| Weight | 1.2kg |
| Package contents | 1x Dynavox DA-300 1x Power supply 1x Remote control 1x Bluetooth antenna |
| Input | USB |
| Input | SPDIF |
| Input | Bluetooth |
| Input | RCA |
| Input | Optical |
| Output | HDMI ARC |
| Output | Screw terminals |
| Color | Black |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | N/A |
| Power (W) | 100.0 |
| Remote Control | Yes |
