FOSI AUDIO BT20A PRO-48V Amplifier
The Fosi Audio BT20A PRO is a compact and powerful Class D amplifier, offered at a very resonable price. Its amplifier stage uses a TI TPA3255 chips, capable of developing a power of 225W under 4Ω per channel.
4.0 / 5
Reference : 21696
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 24-11-2026.
Fosi Audio BT20A PRO-48V
Class D amplifier 2x220W 4 Ohm - Bluetooth 5.0
Fosi Audio BT20A Amplificateur
For its connections, the BT20A PRO is simple and efficient, with stereo RCA or Bluetooth 5.0 input, and plated speaker terminals output as well as a 3.5mm jack pre-output.
On its front, the BT20A PRO has a tone control allowing you to adjust the level of bass and treble, in order to adapt the reproduction of the device to your audio system and your preferences. In addition, a bluetooth pairing history deletion function is now available by holding down the volume button for a long time.
A Bluetooth code may be requested to connect to the amplifier, it is "0000" or "1234".
FOSI AUDIO BT20A Pro Amplificateur Class D 2x TPA3255 Bluetooth 5.0 2x300W 4 Ohm
A high-end amplifier chip
Its amplification stage uses a high-end TI TPA3255 amplification chip, capable of developing a power of 220W under 4Ω per channel. All while providing clear and detailed sound reproduction.
Customization of operational amplifiers
The DIP8 format OP-AMP NE5532 chip is easily replaceable. This can allow you to get your favorite sound signature.
Front and back view of the BT20A PRO
1Power indicator
2Power switch
3Treble control
4Bass control
5Volume control / Erasing Bluetooth pairing history
6RCA Stereo input
7Jack 3.5mm pre-out
8Speaker terminal
9Power plug
10Bluetooth antenna
Technical characteristic
Product typeAmplifier stereo
Amplification typeClass D
Input1x RCA stere'o
Bluetooth 5.0
OutputSpeaker terminal
Pre-out jack 3.5mm
Amplifier chipTI TPA3255
Output power2x 220W / 4 Ohm @ 48V (RMS)
2x 259W / 4 Ohm @ 48V (Max)
2x 110W / 8 Ohm @ 48V (RMS)
2x 129W / 8 Ohm @ 48V (Max)
2x 100W / 4 Ohm @ 32V (RMS)
2x 125W / 4 Ohm @ 32V (Max)
2x 50W / 8 Ohm @ 32V (RMS)
2x 62W / 8 Ohm @ 32V (Max)
Accepted impedances2-8Ω
Frequency response20 Hz-20 kHz (± 1,2 dB)
THD0.005%
SNR≥ 108dB
Bluetooth CodecsACC
SBC
Tone controlBass / Treble with midpoint
Power supply voltage24V-48V DC (AC adaptateur included)
Dimensions (L*P*H)166x105x35mm
Net Weight547g
ColorBlue
Package1x Fosi Audio BT20A PRO
1x Power supply 48V 5A
ColorBlue
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)220.0
Amplificateur compact et efficace !
Amplificateur adapté à mes enceintes d'extérieur ; seul bémol : l'envoi d'un produit qui semble reconditionné (emballage et conditionnement pas neufs).
This review has been posted for FOSI AUDIO BT20A PRO-48V Class D Amplifier TPA3255 Bluetooth 5.0 2x220W 4 Ohm
The Fosi Audio BT20A PRO is a compact and powerful Class D amplifier, offered at a very resonable price. Its amplifier stage...
