FX-AUDIO L07 Amplifier MA5332MS
The FX-Audio L07 amplifier completes the series, following in the footsteps of the R07 headphone amplifier and the DS07 DAC. Featuring the same form factor, it is particularly well matched to the latter. The L07 features a balanced architecture and an Infineon MA5332MS amplification chip, enabling it to develop substantial power up to 2x 200W @ 4 ohm.
Reference : 19230
159,00 €tax incl.
132,50 € tax excl.
FX-AUDIO L07 Class D Amplifier Infineon MA5332MS 2x 200W @ 4 ohm / 1x 400W BTL @ 8 ohm
FX-AUDIO L07 picture
The FX-Audio L07 amplifier completes the series, following in the footsteps of the R07 headphone amplifier and the DS07 DAC. Featuring the same form factor, it is particularly well matched to the latter. The L07 features a balanced architecture and an Infineon MA5332MS amplification chip, enabling it to develop substantial power up to 2x 200W @ 4 ohm. This amplifier also features a mono bridge mode (BTL) via its XLR and RCA left-channel analog inputs for power up to 1x 400W @ 8 ohm. A front-mounted potentiometer allows easy adjustment of output volume, and an internal protection circuit protects your speakers.
FX-AUDIO L07: MA5332MS amplifier chip
This Infineon MA5332MS amplifier chip offers high output power and 95% efficiency. Reliable, it integrates a dual-channel PWM controller as well as a high-voltage gate driver and no fewer than 4 MOSFETs. All features that make it the chip of choice for FX-Audio's powerful L07 amplifier.
Photo de la puce d'amplification MA5332MS
FX-AUDIO L07: Stereo configuration
The L07 features 2x 200W @ 4 ohm in classic stereo configuration. This means you can directly connect a source with analog output, such as a DAC, CD player, Bluetooth receiver or streamer, and then amplify your signal to bookshelf or passive floorstanding speakers.
FX-AUDIO L07 stereo configuration
FX-AUDIO L07: Bridge mono configuration (BTL)
In BTL mode, the L07 delivers 400W @ 8 ohm. So you can choose to combine two amplifiers to obtain 2x 400W @ 8 ohm power and sonorise a large space.
BTL mono configuration of FX-AUDIO L07
L07 overview
FX-AUDIO L07 overview
1Volume control potentiometer
2Input selection
3LED indicator (POWER - UNBAL - BAL)
4XLR balanced stereo input
5RCA stereo input
6Mono BTL input via left channel RCA or XLR
7Stereo/BTL mode selection
8Left channel speaker terminal
9BTL+/BTL- output
10Right channel speaker terminal
11IEC power supply
12Power switch
Product typeAmplifier
Amplification chipMA5332MS
Inputs1x RCA stereo
1x XLR balanced stereo
OutputSpeaker terminals
Output powerStereo: 2x 200W @ 4ohm / 2x 100W @ 8 ohm @1kHz THD+N<10
BTL : 400W @ 8 ohm @1kHz THD+N<10%
THD+N< 0.008%
Frequency response10Hz-24kHz(±0.3dB)
SNR98dB
Chassis materialAluminum
Grneral
Weight1.56kg
Dimensions278 x 222 x 182mm
Package1x FX-Audio L07 amplifier
1x Power supply cable
InputXLR
Channel2 (Stereo)
Channel1 (Mono)
Amplifier chipInfineon MA5332M
Power (W)400.0
Power (W)200.0
Très bon achat
Alors impression des premières secondes : c'est boomy !
Les basses sont clairement mises en avant.
Mais l'équilibre général du spectre sonore reste préservé, et c'est très important (je ne suis pas trop porté sur les basses). Et puis elles sont bien définies, assez sèches, ne bavent pas. On s'en rend compte sur les morceaux riches.
Les médiums sont excellents. Nullement étouffés par les basses, ils demeurent au premier plan. Chaleureux, vivants, pas fatiguants. Les hauts particulièrement. En opéra, les sopranos s'écoutent plein volume sans fatigue.
Les hautes fréquences passent bien également. Saxophones et violons sont soyeux, bien définis, pas de brillance.
L'ensemble de l'écoute ne manque pas de détails. Sur Whole outta love de Led Zepp il ne manque rien.
Il parvient également à sublimer les morceaux mal enregistrés, et ça c'est éloquent je pense.
Mais éventuellement le seul petit reproche c'est un léger manque de délié sur la restitution quand la scène est très chargée.
Mais bon, je sors d'un Topping PA5 qui excellait dans le domaine je trouve...
Bref : un ampli très musclé (on ressent bien la réserve de watts), généreux sur les basses sans déséquilibrer le spectre sonore, avec du détail et une scène stéréo large, mais un chouilla en retrait sur le délié lors d'informations sonores saturées.
Il vaut largement son prix cependant.
J'espère que mon charabia vous aura été intelligible
 (3)
This review has been posted for FX-AUDIO L07 Class D Amplifier Infineon MA5332MS 2x 200W 4 Ohm / 1x 400W BTL 8 Ohm
The FX-Audio L07 amplifier completes the series, following in the footsteps of the R07 headphone amplifier and the DS07 DAC. Featuring the same...
