SMSL A300 Class D Amplifier Infineon MA5332MS USB Bluetooth 5.0 Subwoofer 2x160W 4 Ohm
SMSL offers with the A300 a compact but powerful and efficient Class D amplifier, based on a Infineon MA5332MS amplifier chip. These allow it to deliver a comfortable power of 2x160W. Practical, the A300 in addition to its standard connectivity, provides a Bluetooth reception, allowing to broadcast and control simply its music remotely, from a smartphone for example. Other features, the A300 provides a BTL mode to enjoy more power with a second unit and a subwoofer output for the integration of a 2.1 audio system.
4.9 / 5
Reference : 16514
215,00 €tax incl.
179,17 € tax excl.
Shipping date: 16-06-2026.
SMSL A300
SMSL A300 Amplificateur Class D 2x Infineon MA12070 USB Bluetooth 5.0 Subwoofer 2x160W 4 Ohm
BTL Mode
Need more power? The A300 can work in BTL mode by associating a second unit. It has a BTL output, allowing to redirect the right channel to a second A300. The power is thus doubled, each unit being able to provide 330W.
Sortie subwoofer
Besoin de plus de puissance ? L'A300 peut fonctionner en mode BTL en associant une seconde unité. Il dispose d'une sortie BTL, permettant de rediriger le canal droit vers un second A300. La puissance est ainsi doublée, chaque unité étant capable de fournir 330W.
Bluetooth 5.0
The Bluetooth 5.0 chip embedded in the SMSL A300 allows you to broadcast your music wirelessly extremely easily, from a smartphone or a tablet for example.
1Screen
2IR Receiver
3Multi-function button
4Input selection
5Menu button
6ON/OFF button
7Analog input 2
8Analog input 1
9BTL Mode right channel output
10USB-A input
11Bluetooth antenna
12Right channel output
13Left channel output
14Power supply
15Subwoofer output
Product typeAmplifier
Amplifier typeClass D
Amplification chipMA5332MS
InputsBluetooth 5.0
2x Stereo RCA inputs
1x USB-A
OutputsSpeaker terminals
1x BTL output
1x Subwoofer output
Output power2x 165W @ 4Ω
2x 85W @ 8Ω
BTL Mode : 1x 330W @ 4-8Ω
THD+N0.004%
SNR103dB
Channel separation85dB
Cut-off frequency (high pass mode)50Hz
Input sensitivity280mV
Input impedance22kΩ
Consumption40W
Dimensions210.5 x 198 x 41mm
Weight1.3kg
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Amplifier chipInfineon MA5332M
Power (W)160.0
Remote ControlYes
9 reviews
De la dynamique
J’ai acheté cet ampli pour ma télé mais j’ai immédiatement été frappé par la qualité de l’écoute . Alors je l’ai branché sur mes focal Kenya et surprise , le son est supérieur à un ampli classe À qui coûte 10 fois son prix . En plus le Bluetooth est super qualitatif, jamais entendu ça jusqu’alors . Le Dac est de super qualité . Bref, je la laisse pour mon gros système et j’ai acheté un autre petit ampli pour ma télé . Je recommande totalement !
This review has been posted for SMSL A300 Class D Amplifier Infineon MA5332MS USB Bluetooth 5.0 Subwoofer 2x160W 4 Ohm
excellent rapport qualité prix
Apres un mois d'utilisation je suis extrêmement satisfait. S'accorde parfaitement a mes enceintes jbl es20. Le son est de meilleur qualité que mon ancien ampli, les aiguës et medium sont très détaillés. Je compléterai par un caisson de basse actif et ce sera grandiose en terme de profondeur de basse. Merci a l'équipe pour la qualité de vos sélections.
Je m'arrache les cheveux
J'ai repris un deuxième A300 pour profiter du mode BTL. J'ai suivi les instructions à la lettre, mais rien à faire, j'ai uniquement du son sur la sortie droite de l'ampli maître, sur l'ampli esclave aucun son. Quelqu'un pourrait-il m'aider à résoudre ce problème. Merci à tous
 (3)
Ça m'énerve qu'il soit bon !
En attendant la réparation de mon top ampli classe A haut de gamme, il me fallait un truc pas cher pour patienter.
J'ai écouté des PURIFI et autres "classe D" qui ne m'ont pas du tout plu. Froid et plat a mon gout.
Bien, je sors le truc tout léger de sa boîte, c'est joli. Je branche. Je lis le mode d'emploi (nécessaire) et je teste.
Sur l'option SDB, effet "loudness" comme j'aime le son, je suis très énervé de m'avouer que le son est la.
La scène est plus petite qu'avec mon ampli habituel. Je lui ai trouve quand même un défaut. Na !
Pour le reste, c'est le premier classe D qui me séduise en plus du prix ridiculement bas (20 fois moins que mon ancien ampli).
Je recommande vivement. Même aux audiophiles.
 (4)
2eme avis
Suite à mon avis du 14/10/22 basé sur l' écoute en bluethoot uniquement . Je me suis rendu compte qu' en installant un récepteur bluetooth extérieur aptx Qualcomm on atteint des sommets.Dommage que cet ampli ne soit pas équipé d'un bluthoot à la hauteur vu la qualité de l'amplification proposé. Mérite un câble de secteur de hdg ainsi que des câbles de modulation hdg. N hésiter pas à mettre plus cher en câble que le prix de l' ampli , il vous le rendra au delà de vos espérances .Allimente des panneaux magnepan mg 1.7 avec bonheur.
SMSL offers with the A300 a compact but powerful and efficient Class D amplifier, based on a Infineon MA5332MS amplifier chip. These allow it to...
