SMSL AS400 Amplifier 2.1 Phono Preamplifier Black
New
The SMSL AS400 is an extremely versatile integrated amplifier. It offers numerous advantages, such as a phono input, an HDMI ARC input, a preamplified output for active subwoofers, and two headphone outputs. It also features an audiophile chipset allowing it to support sampling rates up to PCM 32-bit 768kHz and DSD256 while delivering up to 2x 165W of power under a 4-ohm load via its speaker terminals.
By buying this product you get 27 loyalty points
Reference : 21040
279,00 €tax incl.
232,50 € tax excl.
SMSL AS400 Amplifier 2.1 Phono Preamplifier Bluetooth LDAC aptX HD MA5332MS 2x 165W 4 Ohm Black
Photo of the SMSL AS400
The SMSL AS400 is an extremely versatile integrated amplifier. It offers numerous advantages, such as a phono input, an HDMI ARC input, a preamplified output for active subwoofers, and two headphone outputs. It also features an audiophile chipset consisting of a CS43131 DAC chip coupled with an XMOS XU-316 USB interface, an MA5332MS amplifier chip, and an NJW1194A volume control chip. This allows it to support sampling rates up to PCM 32-bit 768kHz and DSD256 while delivering up to 2x 165W of power under a 4-ohm load via its speaker terminals. On top of that, it features Bluetooth with support for high-res aptX-HD and LDAC codecs for reliable and stable wireless transmission. On the front panel, there's also a nice display that shows info about what's playing, and you can control the AS400 intuitively and conveniently with an IR remote. In terms of connectivity, as mentioned above, the AS400 has numerous inputs and outputs, allowing you to enjoy a 2.1-channel system or listen with headphones.
Key features of the SMSL AS400
SMSL AS400: A high-performance chipset
The SMSL AS400 combines a DAC chip and XMOS XU-316 USB interface to support sampling rates of up to 32-bit 768 kHz and DSD256, allowing you to enjoy high-definition files on streaming platforms or locally. The MA5332MS amplifier chip delivers up to 2x 165W of power at 4 ohms and 2x 85W at 8 ohms with a THD+N of only 0.003% for clean sound in small to medium-sized spaces.
Photo of the DAC chip CS43131
Photo of the MA5332MS amplification chip
Photo of the XMOS XU-316 USB interface
SMSL AS400: High-definition Bluetooth
The SMSL AS400 features a Bluetooth input that supports high-definition aptX-HD, and LDAC codecs for reliable and stable wireless transmission. This allows you to quickly enjoy various streaming platforms via your phone or tablet, for example.
Bluetooth functionality of the SMSL AS400
SMSL AS400 MM phono input
SMSL AS400: MM phono input
The MM phono input will delight vinyl enthusiasts and collectors, who will be able to enjoy high-quality listening from their music library by connecting their turntable directly to the SMSL AS400 amplifier.
SMSL AS400: HDMI ARC input and 2.1-channel output for a home theater setup
The combination of an HDMI ARC input and a preamplified output for an active subwoofer makes it easy to set up a 2.1-channel system for a home theater setup. Resolutely versatile, the AS400 will enhance the soundtrack and action scenes of your favorite movies with the help of an active subwoofer.
Home cinema setup with the SMSL AS400
SMSL AS400 overview
Overview of SMSL AS400
1Display
2IR receiver
3Multifunction button
4Balanced 4.4mm headphone output
5Single-ended 6.35mm headphone jack output
6Phono input
7Line input
8Coaxial input
9Subwoofer output (preamp)
10HDMI ARC input
11USB-C input
12Bluetooth antenna
13Toslink optical input
14Speaker terminal outputs
15100-240V AC power port
Product typeIntegrated amplifier
DAC chipCS43131
Amplification chipMA5332MS
USB interfaceXMOS XU-316
Inputs1x USB-C
1x RCA line (AUX)
1x Toslink optical
1x Coaxial
1x HDMI ARC
1x MM phono
Bluetooth
Outputs1x Speaker terminal output
1x Line output for active subwoofer (RCA)
1x Balanced 4.4mm headphone jack output
1x Single-ended 6.35mm headphone jack output
Supported sampole ratesUSB: PCM up to 32bit 768kHz, MQA
Toslink optical and coaxial: PCM up to 24bit 192kHz, DSD DoP64
Supported Bluetooth CodecsSBC, AAC, aptX-HD, LDAC
Output power (Wrms)165W x2 @ 4 ohm
2x 85W @ 8 ohm
Input sensitivity280mV/22Kohm
THD+N0.003%
SNR107dB
Channel separation98dB
Bit depth1bit, 16-32Bit
USB transmissionAsynchronous
USB compatibilityWindows 7/8/8.1/10/11, Mac OSX, Linux
Power supply100-240V AC
Power consumption40W (Volume normal)
Weight1.568kg
Dimensions210.4 x 46 x 254mm
Package1x SMSL AS400
1x HDMI cable
1x Remote control
1x Power cord
InputHDMI ARC
InputPhono
OutputJack 6.35mm
OutputJack 4.4mm
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Amplifier chipInfineon MA5332M
Power (W)165.0
Remote ControlYes
The SMSL AS400 is an extremely versatile integrated amplifier. It offers numerous advantages, such as a phono input, an HDMI ARC input, a...
