TOPPING MINI300 Balanced Integrated Amplifier Class D White
The Topping MINI300 is a Class D stereo amplifier delivering 2 × 125 W into 4 Ω in a fully symmetrical, high-efficiency design. Its 124 dB SNR, background noise below 15 µV and -106 dB crosstalk ensure faithful reproduction of the original sound. Housed in an aluminium chassis and equipped with a 12 V trigger, it combines performance, compactness and reliability, with built-in protection against overheating and overload.
Reference : 21262
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 27-05-2026.
Topping MINI300 Balanced Integrated Amplifier Class D 2x125W 4 Ohm White
Topping MINI300 : Front view
The Topping Mini300 is a Class D stereo amplifier delivering 2x125 W into 4Ω in a fully balanced, high-efficiency design. Its 124dB SNR, background noise below 15µV and -106dB crosstalk ensure faithful reproduction of the original sound. Housed in an aluminium chassis and equipped with a 12V trigger, it combines performance, compactness and reliability, with built-in protection against overheating and overload.
Topping Mini300: A balanced Class D amplifier
The Topping Mini300 is a compact stereo amplifier delivering 2x125 W into 4Ω, designed to offer controlled power in a small format. Its Class D topology ensures high energy efficiency and excellent thermal stability, while the fully balanced design guarantees rigorous channel separation and reduced background noise.
The aluminium chassis enhances heat dissipation and protects the internal circuits from electromagnetic interference. A 12V trigger input also facilitates the integration of the Mini300 into an existing music system or home cinema.
Topping MINI300 : White, black and grey version
Topping Mini300: Outstanding audio performance
The architecture of the Mini300 is based on a selection of low-distortion components, optimised for transparency and precision. The amplifier has a signal-to-noise ratio of 124dB, background noise of less than 15µV and a harmonic distortion rate of < 0.0005%, ensuring faithful reproduction at any volume level.
Topping MINI300 : THD+N
The -106dB crosstalk ensures clear channel separation, preserving the stereo image and spatial coherence of the recording. This performance reflects an approach focused on neutrality and stability, without sound colouration.
Topping MINI300 : GX output and connector
Topping Mini300: Protection and reliability
Designed for long-term use, the Mini300 incorporates several protection circuits against overheating and overcurrent, ensuring stable operation over time, even during prolonged listening at high volumes.
Its combination of performance, compactness and quiet operation makes it an amplifier that is precise, efficient and easy to integrate into a modern hi-fi system.
Topping Mini 300 test by Audio Science Review
"The Topping Mini 300 offers meticulous workmanship with excellent implementation of Class D chip-based amplification. For an affordable price, you get a stereo amplifier that produces a lot of power while taking up very little space. It certainly breaks the cliché that you have to spend a lot of money to get good performance. I highly recommend the Topping Mini 300 stereo amplifier."
Technical specifications
Product typeAmplificateur intégré
Inputs1x Single-ended stereo RCA
1x Balanced stereo Jack 6.35mm
OutputSpeaker terminal
Output power2x140W @ 4Ω THD+N<10%
2x125W @ 4Ω THD+N<1%
2x85W @ 8Ω THD+N<10%
2x65W @ 8Ω THD+N<1%
Load impedance4-8Ω
12V trigger
Single-ended input specifications
Total harmonic distortion more noise (THD+N)< 0.0006% @ 4Ω 5W
< 0.0008% @ 8Ω 5W
Signal-to-noise ratio (SNR)121dB
Dynamic range121dB
Frequency response20Hz-40kHz (±0.3dB)
Output level65Vpp @ 4Ω
68Vpp @ 8Ω
Noise< 15uVrms
Crosstalk-90dB
Input sensitivity1.3Vrms
Gain25dB
Channel balance0.1dB
Balanced input specifications
Total harmonic distortion more noise (THD+N)< 0.0005% @ 4Ω 5W
< 0.0004% @ 8Ω 5W
Signal-to-noise ratio (SNR)124dB
Dynamic range124dB
68Vpp @ 8Ω
Noise< 15uVrms
Crosstalk-106dB
Input sensitivity2.6Vrms
Gain19.2dB
Power supply voltage38V DC
ColorWhite
Package1x Topping Mini300
1x 38V mains adapter (2-pin GX connector)
Topping MINI300 : Measures
InputJack 6.35mm
ColorWhite
Channel2 (Stereo)
Amplifier chipN/A
Power (W)125.0
TOPPING MINI300 Balanced Integrated Amplifier Class D 2x125W 4 Ohm White
The Topping MINI300 is a Class D stereo amplifier delivering 2 × 125 W into 4 Ω in a fully symmetrical, high-efficiency design....
