WIIM VIBELINK AMP Amplifier Gray
The WiiM Vibelink Amp, marks the brand's first foray into non-connected integrated amplifiers, designed to pair with WiiM Mini, WiiM Pro, WiiM Pro+ and WiiM Ultra streamers. This audiophile amplifier integrates an ES9039Q2M DAC chip, a TI TPA3255 amplifier chip and six OPA1612 OPAs, all within a PFFB (Post-Filter Feedback) structure.
By buying this product you get 36 loyalty points
Reference : 20685
369,00 €tax incl.
307,50 € tax excl.
Shipping date: 10-06-2025.
WiiM Vibelink AMP Amplifier Class D PFFB TPA3255 2x200W 4 Ohm Gray
Photo of WIIM VIBELINK AMP
The WiiM Vibelink Amp, marks the brand's first foray into non-connected integrated amplifiers, designed to pair with WiiM Mini, WiiM Pro, WiiM Pro+ and WiiM Ultra streamers. This audiophile amplifier integrates an ES9039Q2M DAC chip, a TI TPA3255 amplifier chip and six OPA1612 OPAs, all within a PFFB (Post-Filter Feedback) structure. It supports sampling rates up to PCM 24bit 192kHz via its Toslink optical and coaxial inputs, while delivering 2x200W output power at 4Ω. A notable advantage is bit-perfect playback, preserving the integrity of the signal from source to digital-to-analog conversion stage. A pure RCA analog input is also available, bypassing any ADC conversion for optimum fidelity of vinyl and CD sources. The Vibelink Amp benefits from advanced thermal management and a 12V trigger for a pleasant user experience. Affordable and high-performance, this WiiM amplifier is sure to win over audiophiles.mise en situation du WIIM VIBELINK AMP
WiiM Vibelink AMP: High-quality audiophile components
The Vibelink Amp's digital-to-analog conversion stage is based on an ESS ES9039Q2M chip, supporting sampling rates up to PCM 24bit 192kHz via optical and coaxial inputs. Amplification is provided by a TEXAS Instruments TI TPA3255 chip, renowned for its performance, and six OPA1612 AOPs, delivering up to 2x200W output power at 4Ω. This combination of premium components guarantees low distortion and noise over a wide dynamic range, for rich, detailed sound reproduction.
The WIIM VIBELINK AMP chipset
WiiM Vibelink AMP: PFFB circuit for consistent sound quality
The Vibelink Amp incorporates a PFFB (Post-Filter Feedback) circuit that minimizes load dependency through constant dynamic adjustment. This reduces distortion and noise levels, ensuring optimum, stable sound quality, even with speakers of different impedances.
The WIIM VIBELINK AMP PFFB circuit
WiiM Vibelink AMP: Bit-perfect playback and pure analog input for maximum sonic fidelity
The Vibelink Amp's analog RCA input bypasses any analog-to-digital conversion (ADC), enabling authentic, audiophile sound reproduction that preserves the integrity of high-fidelity analog sources such as vinyl and CD. For digital sources, the Toslink optical and coaxial inputs offer bit-perfect playback up to 24bit 192kHz, guaranteeing lossless audio fidelity to the original source.
WIIM VIBELINK AMP a bit-perfect amplifier
WiiM Vibelink AMP: Advanced thermal management for sustainable performance
Despite its high amplification power, the WiiM Vibelink Amp maintains optimum operating temperature thanks to an advanced thermal management system. This cooling system includes a copper heat pipe and an aluminum radiator that ensure rapid heat transfer from the main components and efficient dissipation. PID control regulates temperature in real time for stable, long-lasting performance.
WIIM VIBELINK AMP heat dissipation
Additional WIIM VIBELINK AMP functions
WiiM Vibelink AMP: Intelligent features for intuitive operation
The WiiM Vibelink Amp is packed with additional features to enhance the user experience. It includes a 12V trigger via a 3.5mm jack connector, as well as an automatic sleep mode that switches the device off after 30 or 60 minutes of inactivity.
WiiM Vibelink AMP: Perfect integration into the WiiM ecosystem
The Vibelink Amp is designed to integrate seamlessly with WiiM network players, whether via digital or analog connections, offering a consistent, high-performance audio solution.
The WiiM ecosystem
WiiM Vibelink Amp overview
Aperçu du WIIM VIBELINK AMP
1Power input
212V jack 3.5mm trigger input
3Optical Toslink input
4Coaxial input
5RCA input
6Speaker terminals output
Product typeAmplifier
Amplification typeClass D
DAC chipESS ES9039Q2M
Amplification chipTPA3255
OPA6x OPA1612
CircuitPFFB
Inputs1x Stereo RCA
1x Optical Toslink
1x Coaxial
OutputSpeaker terminals
Supported sampling ratesPCM up to 24bit 192kHz
Output noise2x100W @ 8Ω
2x 200W @ 4Ω
SNR120dB
THD0.0005%
Frequency response20Hz-20kHz ±0.5dB
Impedance3-8Ω
ColorGray
Dimensions200 x 63 x 200mm
Weight2.05kg
Package1x WiiM Vibelink AMP
4x 4mm banana plug to bare wire adapter
1x Power cable
ColorGray
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)200.0
WIIM VIBELINK AMP Amplifier Class D PFFB TPA3255 2x200W 4 Ohm Gray
The WiiM Vibelink Amp, marks the brand's first foray into non-connected integrated amplifiers, designed to pair with WiiM Mini, WiiM Pro, WiiM...
