The Mogami 3316 is an ultra-thin interconnect cable designed to be both resistant and flexible. Originally developed by the Japanese firm as a made-to-measure cable for computer magnetic heads, it is now proving highly effective in an audiophile DIY context.
This 3368 unbalanced modulation cable from Mogami features an OFC copper conductor with a cross-section of 0.565mm² (AWG20). It features PE insulation and double carbon shielding.
The Neotech NECE-1001 is an IEM cable featuring 4 silver UP-OCC conductors with Litz multi-strand design. This design greatly optimizes signal transmission, while the Litz wire structure insulates each strand with a polyvinyl chloride coating.
The Neotech NECE-3001 MKIII is a headset and IEM cable with 4 multi-stranded Litz UP-OCC copper conductors. Each conductor is insulated with a transparent PVC jacket.
The Neotech NECE-3200 III is an IEM cable featuring a 4-conductor Litz multi-strand design in silver-plated UP-OCC copper. This design greatly optimizes signal transmission, while the Litz wire structure insulates each strand with a polyvinyl chloride coating.
The Neotech NEI-1001 II is a balanced modulation cable made of 2 Silver UP-OCC conductors with a cross section of 1.17mm². Each conductor is composed of 4 strands of different sizes. The conductors are kept equidistant thanks to the use of PE tubes. The cable is covered by a PVC-jacket and covered with a nylon braided jacket.
The Neotech NEI-1002 II cable retains the high-quality design of its predecessor, with effective shielding and two UP-OCC silver conductors, but this time plated with a mixture of UP-OCC silver and gold.
Neotech's NEI series is a range of high-end cables. The NEI-2002 cable features two pure silver single-core conductors, both with a diameter of 0.58mm (AWG 23). NEI-2002 features a triple shielding layer with microporous PTFE, AL-Mylar and silver-plated OFC braiding.
Neotech NEI-3001G is a balanced interconnect cable incorporating 4 UP-OCC copper conductors 99.99998% pure. It benefits from a top-of-the-range design with two single-core and two multi-strand conductors. In addition, graphene is used to greatly improve the conductivity of this cable's UP-OCC copper conductors.
The Neotech NEI-3002G is a balanced interconnect cable utilising two G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor represents a significant breakthrough, both in terms of research and industrial applications. Indeed, the addition of graphene improves the stability of electrical signal transmission at high...
Neotech's NEI-3004G modulation cable is a symmetrical modulation cable incorporating 2 G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high...
The NEMOI series from the manufacturer Neotech is the result of extensive research in the field of audio cable. The Neotech NEMOI-1220 modulation cable, combining PTFE insulation and UP-OCC Silver conductors with rectangular cross-section, has a special architecture that significantly reduces the inductance and capacitance effect.
The NEMOI series from the manufacturer Neotech is the culmination of long research in the field of audio cables.The Neotech NEMOI 3220 modulation cable, combining PTFE insulation and OCC pure copper conductors with a rectangular section, has a special architecture allowing a strong reduction in the effect of inductance and...
The Ramm Audio E72 modulation cable offers excellent design quality for perfect signal transmission. It features two conductors, each consisting of three 0.5mm OCC copper strands, combined with four PP tubes filled with air as dielectric and an aluminum-mylar shield. The E72 also has a drain wire, composed of three 0.65mm OFC copper strands.
The Ramm Audio Elite8 is designed to provide the best possible analog connection to preserve the integrity of the transmitted signal. The result is a very low level of distortion and noise for a very transparent reproduction.
This ELITE-XTRA interconnect cable from RAMM AUDIO is a top-of-the-range interconnect cable. It incorporates components carefully selected for their properties and performance, such as pure OCC copper conductors cryogenically treated for excellent signal conductivity.
This Sommercable SC-Cicada SO-D14 is a microphone modulation cable with a cross-section of 2x 0.14mm². Its conductors are made of pure OFC copper for optimum signal transmission. This modulation cable is particularly appreciated for its high flexibility and durability, thanks to a number of protective features.
The SC-Kolorith 1 from Sommercable is a hybrid cable designed to transmit both audio data and power in a single line, making it an ideal solution for demanding installations in studios, architectural lighting, home automation, or smart sound systems.
This Peacock MKII Sommercable cable can be used to design stereo microphone cables, or to create Cinch or Y patch cables. This Peacock MKII benefits from excellent insulation, each cable being 95% independently protected by a thick spiral sheath. In addition, the cable has 4 OFC copper conductors to ensure excellent signal conductivity.
This Sommercable SC-Silver balanced interconnect cable is a microphone cable with a cross-section of 2x0.22mm². Its conductors are made of pure OFC copper, silver-plated for optimum signal transmission. Furthermore, to protect against electromagnetic interference, SC-Silver has a copper spiral shield. All this is encased in a soft PVC sheath, giving...
The Sommercable Sinus can also be used in a home HiFi system or for Car Audio. This one enjoys an excellent reputation from connoisseurs for its unbeatable quality/price ratio. It is particularly appreciated by Car Audio enthusiasts since the cable incorporates an effective shielding composed of a Copper mesh and an Aluminium / Polythophene sheet that...
