The Hifiman RE800 are exceptional in-ear headphones that we offer in their 24k Gold Edition. They provide exceptional sound reproduction.
KEY POINTS:
In-Ear Headphones
If the brass used for the body of this EMI greatly improves its acoustics, it is otherwise for audio output.
Thus, the RE800 24k Gold Edition uses an electrolytic plating giving this brilliant shine.
Hifiman uses advanced technology to improve the sound reproduction of the RE800. With its "Topology Driver" Hifiman greatly improves the control and precision of its headphones, resulting in great clarity, a high level of detail and sharp nuances, while maintaining a coherent sound.
The topological driver refers to the nano-particle-based plating of the diaphragm, applied to reproduce geometric patterns. By varying this pattern the spectrum can be manipulated to provide adays better.
The idea behind this technology is inspired by the thesis of Dr. Fang Bian's Ph.D., arguing that "different nano-materials have different structures and each of these materials has its own properties." Thus, by carefully controlling the structure of the surface of the diaphragm, you obtain acoustic results that were previously unattainable. Moreover, the distortion is greatly reduced and the dynamics improved.
After the creation of numerous prototypes and the constant realization of user tests, HifiMan has worked to offer you exceptional audio quality.
With these RE800s, Hifiman redefined the structure of its IEMs, offering an industrial design combining design and comfort. Offering a size designed for comfort and optimized insulation, these headphones push the listening experience to the highest. What's more, the cable is detachable and changeable, to adapt to all your desires.
Frequency Response | 20Hz - 20kHz |
impedance | 60 Ohms |
<sensitivity/ Td> | 105dB |
Type of diaphragm | topological |
connector | 3.5mm Jack |
Driver Type | Dynamic 9.2mm |
Plating | Gold 24k |
Cable material | Copper plated Silver |
Weight | 27g |
Color | Gold |
Impedance (Ω) | 60 |
Efficiency / Sensitivity (dB) | 103.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 20000 |
