Max cable diameter (mm)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
2 - 5
Mounting type
TUNG-SOL 6SN7GT
I bought the TUNG-SOL 6SN7 on recommendation and it worked well, they fit perfectly with my KT 88 Genalex Gold Lion power...
TUNG-SOL 6SL7GT
I bought the TUNG-SOL 6SL7 on recommendation and it worked well, they fit perfectly with my KT 88 Genalex Gold Lion power...
Joseph C.
Belle acquisition
Vezzoso
J’utilise l’unité depuis 3 jours et le “plumage “ est incroyable : 6,5 kg usiné dans un bloc d’aluminium joliment...
Jack Plugs
We offer a very wide range of Jack connectors. Jack plugs are essential in the audio world, and are available in different formats, materials, plating, or in different ways: crimping, soldering, or clamping. Among our numerous jack connectors, discover the recognized brands such as Furutech, Elecaudio, Neotech, or 1877PHONO.
  • Jack 3.5mm
    Jack 3.5mm
    Discover our range of 3.5mm jack connectors, for the design of your HiFi analog audio cables.
  • Jack 6.35mm
    Jack 6.35mm
    Discover our range of 6.35mm jack connectors for the design of your analog audio cables.
  • Jack 2.5 mm
    Jack 2.5 mm
    Discover our range of 2.5mm jack connectors, for the design of your balanced analog audio cables.
  • Jack 4.4mm
    Jack 4.4mm
    Discover our range of 4.4mm jack connectors for the design of your balanced analog audio cables.
