Rythmik Audio DS1200 12 "+ Amplifier A370PEQ3 DIY KIT
By buying this product you get 99 loyalty points
Reference : 7641
990,00 €tax incl.
825,00 € tax excl.
Rythmik Audio DS1200 CI 12 "+ Amplifier A370PEQ3 DIY KIT
This kit allows the realization of a subwoofer resolutely "Audiophile" contains everything necessary for its implementation except carpentry.
Equipped with a Direct Servo technology and a common power, it is the indispensable complement to any system worthy of the name.
Focus on Direct-Servo technology:
  • Thethe effects ofcompressionthermalare eliminated in normal operation.
  • allowsgreater efficiency whowould normally require a more powerful amplifier.
  • Thethe extension of the lowbe made using a pilotof low masswithan unparalleled transient response.
  • Theememory ffets mechanical and thermal nnt reduced , which improves the transient response.
  • The actual valueQ0.3allows controlmuch tighter and more accurate than conventional models.
  • maximumof thenegative feedback of bassinside u caisson
Main Features :
  • HP: Driver DS1200 12"(30 cm)high excursionwith patented Direct Servo system
  • : Bowl and cone Aluminum, rubber suspension
  • Amplifier370WRMSClass AservoB/patented control
  • response frequency: 14 to 200 Hz(-2dB@14 Hz)with entries LFEinA370PEQ3 / XLR2 / XLR3
  • response frequency: 14 to 100 Hz(-2dB@14 Hz) withinputs LINE IN on all models
  • Recovery slopeof 12 or 24dB/ octave(PEQand versionsXLR)
  • Filtered(low pass): 25 -100 Hz
  • Filtered ( high pass): 20Hz 18 dB / octave
  • Phase phase response <90 degrees at 20 Hz
  • Phase adjustment from 0 to 180 degrees - continuous variation
  • F low damping actor: high parameters (Q = 0.5), means (Q = 0.7) and low (Q = 1.1)
Contents of the kit:
  • Amplifier module: A370PEQ3 (370W RMS)
  • Speakers: DS1200 12lass = "hps atn"> "30 cm
  • Special subwoofer: 135 x 85 cm
  • Downloadable diagrams for the realization of a closed or low reflex box
Speaker Details:
  • Rigid Cone -aluminum cone black anodized
  • highlinear excursion - 1.2 "peak to peak (15mmgo only)xmax
  • highexcursionmechanical -1.8 "peak to peak (xmech)to reduce the risk oftailgating
  • Lowmass in motion- 24ohmscoilultraslimof detection for operationsubservient
  • Fthey driverswoven -prevents clatterduring the excursionhigh
  • Spring Terminals plated goldfor connectioneasy cables seamless
https://www.audiophonics.fr/images2/7641/7641_kit_DS1200CI_thumbs.jpg
https://www.audiophonics.fr/images2/7641/7641_kit_DS1200CI_7.jpg
https://www.audiophonics.fr/images2/7641/7641_kit_DS1200CI_6.jpg
https://www.audiophonics.fr/images2/7641/7641_kit_DS1200CI_4.jpg
https://www.audiophonics.fr/images2/7641/7641_kit_DS1200CI_1.jpghttps://www.audiophonics.fr/images2/7641/7641_kit_DS1200CI_2.jpg
https://www.audiophonics.fr/images2/7641/7641_kit_DS1200CI_3.jpg
AmplifierA370PEQ3
https://www.audiophonics.fr/images2/7641/7641_kit_DS1200CI_5.jpg
