DAYTON AUDIO PCS10-4 Subwoofer Speaker
The Dayton Audio PCS10-4 is a 25.4cm (10") paper cone subwoofer with a 4 Ω impedance, designed for subwoofer projects and multi-way speakers requiring extended bass reproduction. Its 33 Hz resonance frequency, 88.8 dB sensitivity and 150 W RMS power handling define a balance suited to compact to medium enclosures, as well as to moderate power amplifiers.
Reference : 22531
59,90 €tax incl.
49,92 € tax excl.
DAYTON AUDIO PCS10-4 Subwoofer Speaker 150W 88.8dB 4 Ohm 30Hz-1kHz
DAYTON AUDIO PCS10-4: Front view
The Dayton Audio PCS10-4 is a 25.4cm (10") paper cone subwoofer, with a 4 Ω impedance, designed for subwoofer projects and multi-way speakers requiring extended bass reproduction. Its 33 Hz resonance frequency, 88.8 dB sensitivity and 150 W RMS power handling define a balance suited to compact to medium enclosures, as well as to moderate power amplifiers.
Its paper cone treated with a grey polymer coating, its inverted dust cap and its wide-roll rubber surround combine controlled excursion with a refined finish. The low-profile stamped steel basket makes for easy integration, while vents in the motor, voice coil former and spider area promote air circulation and limit heat build-up during extended listening. With a maximum linear excursion of ±5.6 mm and a rated frequency response of 30 to 1,000 Hz, it can be used in subwoofer enclosures or in some multi-way speakers.
The PCS10-4 is also the direct replacement speaker for the Dayton Audio CS1000 active subwoofer. Its 10-inch format and 4 Ω impedance make it an option for replacing a worn transducer or building a new audio project, provided the enclosure and amplifier compatibility is verified.
DAYTON AUDIO PCS10-4: Dimensions and measurements
Technical specifications
Product typeSubwoofer
Impedance4Ω
Sensitivity88.8dB 2.83V/1m
Frequency response30Hz-1kHz
Voice coil diameter3.5cm (1.4")
Nominal diameter25.4cm (10")
PowerRMS: 150W
MAX: 300W
Thiele-Small parameters
Resonance frequency (Fs)33Hz
Cone surface area (Sd)328cm²
Voice coil inductance (LE)1.9mH
DC resistance (Re)4Ω
Mechanical quality coefficient (Qms)4.91
Electromagnetic quality coefficient (Qes)0.73
Total quality coefficient (Qts)0.64
Force factor (BL)9.1T·m
Total moving mass + air load on cone (Mms)72.7g
Mechanical compliance of suspension (Cms)0.32mm/N
Compliance equivalent volume (Vas)1.73ft³
Max linear excursion (Xmax)5.6mm
Mounting informations
Cutout diameter23.17cm (9.125")
Depth12.38cm (4.875")
Number of mounting holes8
Total external diameter27.62cm (10.875")
Materials
DiaphragmTreated paper
MagnetFerrite
FrameSteel
SurroundRubber
Voice coil wireCopper
Recommended Enclosure Volume
Sealed Volume28.31L (1ft³)
Sealed F346Hz
Vented Volume42.47L (1.5ft³)
Vented F333Hz
Weight2.3kg
PackageSold individually
Speaker Power (W RMS)150.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)254.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)88.8
Max Linear Excursion (Xmax) (mm)5.6
Lowest frequency (Hz)30
Highest frequency (Hz)1000
The Dayton Audio PCS10-4 is a 25.4cm (10") paper cone subwoofer with a 4 Ω impedance, designed for subwoofer projects and multi-way...
