DAYTON AUDIO PRO ODEUM 18F Subwoofer
The Dayton Audio Pro 18F is a professional 45.7cm subwoofer designed for sound reinforcement systems requiring a high output level and stable bass reproduction. Its 1200W RMS power handling, ferrite motor and 4-inch voice coil allow it to reach a sensitivity of 96.4dB, while ensuring a maximum linear excursion of 10.6mm to strengthen the impact and reach of the bass.
By buying this product you get 32 loyalty points
Reference : 22418
329,91 €tax incl.
274,92 € tax excl.
Dayton Audio Pro Odeum 18F Subwoofer Speaker 1200W 8Ω 96.4dB 35Hz-1kHz Ø45.7cm
Photo du DAYTON AUDIO PRO ODEUM 18F Subwoofer Speaker 1200W 8Ohm 96.4dB 35Hz-1kHz 45.7cm
The Dayton Audio Pro Odeum 18F is a professional 45.7cm subwoofer designed for sound reinforcement systems requiring a high output level and stable bass reproduction. Its 1200W RMS power handling, ferrite motor and 4-inch voice coil allow it to reach a sensitivity of 96.4dB, while ensuring a maximum linear excursion of 10.6mm to strengthen the impact and reach of the bass.
Its ribbed paper cone favors a compromise between rigidity and lightness, while the aluminum demodulation ring reduces distortion and power compression. The ventilation located under the spider and at the rear of the perimeter improves the thermal dissipation of the voice coil, which maintains the speaker's behavior during extended use. With a frequency range of 35Hz to 1kHz and an impedance of 8Ω, the Odeum Pro 18F fits into many sound reinforcement enclosures, for the design, replacement or upgrade of a professional system.
Dayton Audio Pro Odeum 18F: Technical specifications
Product typeSubwoofer
Nominal diameter45.7cm (18")
PowerRMS: 1200W
Max: 2400W
Impedance8Ω
Frequency response35Hz-1kHz
Sensitivity96dB @ 2.83V/1m
Voice coil diameterØ101.6mm (4")
Thiele-Small parameters
DC resistance (Re)6.5Ω
Voice coil inductance (Le)2.25mH @ 1kHz
Resonance frequency (Fs)32Hz
Mechanical quality coefficient (Qms)8.97
Electromagnetic quality coefficient (Qes)0.42
Total quality coefficient (Qts)0.40
Total moving mass + air load on cone (Mms)193.6g
Mechanical compliance of suspension (Cms)0.13mm/N
Cone surface area (Sd)1200cm²
Force factor (BL)24.44Tm
Compliance equivalent volume (Vas)287.7 litre
Max linear excursion (Xmax)10.6mm
Mounting informations
Total external diameter462mm (18.19")
Cutout diameter413.8mm (16.29")
Depth192.8mm (7.59")
Number of mounting holes8
Materials
ConePaper
MagnetFerrite
FrameAluminum
Voice coil wireCopper
Weight15.74kg
Package1x Dayton Audio Pro Odeum 18F
Speaker Power (W RMS)1200
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)462.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)96.0
Max Linear Excursion (Xmax) (mm)10.6
Lowest frequency (Hz)35
Highest frequency (Hz)1000
DAYTON AUDIO PRO ODEUM 18F Speaker Driver Subwoofer 1200W 8Ohm 96.4dB 35Hz-1kHz Ø45.7cm
The Dayton Audio Pro 18F is a professional 45.7cm subwoofer designed for sound reinforcement systems requiring a high output level and stable bass...
