This section presents all our midrange, midbass and full range speakers. Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
The Monacor SPX-200WP full-range driver offers excellent sound quality, with a wide frequency response. It reveals a very slight accentuation in the high frequencies, with nevertheless deep bass reproduction. It features a low-resonance polypropylene cone and rubber suspension. Ideal for installation in a load-closed cabinet.
The Purifi PTT8.0X04-NAB-02 is a 20.32 cm (8") speaker with a nominal impedance of 4Ω, designed to reproduce mid-range frequencies while maintaining usable extension in the bass and treble ranges. With its 350W power handling capacity and extremely low distortion level, even at full power, the PTT8.0X04-NAB-02 is the ideal choice of full-range...
The PURIFI PTT8.0X04-NAB-02 is an 8-inch (20.32 cm) loudspeaker with a nominal impedance of 8Ω, designed to deliver accurate midrange reproduction whilst maintaining a usable extension in the bass and treble ranges. With a power handling capacity of 300W and extremely low distortion, even at full power, the PTT8.0X04-NAB-02 is the ideal choice of...
With the 215 Héritage, Supravox offers a new French high-fidelity loudspeaker, in the tradition of the famous T 215 SRTF, an essential reference from the 1960s to the 1980s. With this model, the brand perpetuates and develops this standard of sound quality by improving its performance. Each loudspeaker (100% of the production) is measured individually in...
This Tang-Band T1-2121SD wideband loudspeaker module integrates both an active loudspeaker with a diameter of Ø46mm and a passive radiator. This design allows it to cover a wide frequency range, from 78Hz to 20kHz, while keeping a compact format.
Tang Bang's W3-871SC full-range driver offers extensive sound reproduction thanks to its 93mm-diameter diaphragm. It has a power handling capacity of 12W, a silver paper diaphragm and a Santoprene suspension for optimum performance.
Tang Bang's W4-2142 full-range driver offers extensive sound reproduction thanks to its 12.55cm-diameter diaphragm. It has a power handling capacity of 25W, a paper diaphragm and a Santoprene suspension for optimum performance.
Tang Band's W4-2315 coaxial driver offers extensive sound reproduction thanks to its Ø11.4cm full-range diaphragm and Ø2cm tweeter. It has a power handling capacity of 30W, a bamboo fibre cone for the full-range driver, an aluminium-magnesium alloy cone for the tweeter and a rubber suspension for good performance.
