By buying this product you get 169 loyalty points
The Diluvio™ AQ339-100 underwater speaker from Clark Synthesis is the only underwater speaker in the world to offer full frequency and total fidelity. Private pool enthusiasts, amateur swimmers, and competitive swimmers agree that the Diluvio™ transforms any pool experience into something truly spectacular. The Diluvio™ brings water to life, allowing music and sounds to be heard through the body beneath the surface of the water. It requires an amplifier to operate. Clark Synthesis recommends a stable 4-ohm amplifier capable of delivering 125-150 watts at 4 ohms (per speaker).
| Specifications | |
| Product type | Aquasonic underwater speaker |
| Nominal diameter | 20.32cm (8") |
| Power handling | RMS: 135W Max: 400W |
| Impedance | 4 ohm |
| Tactile frequency response | 10-800Hz |
| Frequency response | 20Hz-17kHz |
| Transduction force | 2.8 lb-ft/watt |
| Tactile force peak | 378 lb-ft |
| Height | 5.08cm (2.25") |
| Cable | 30.48m of 16-2 cable approved for underwater use |
| General | |
| Weight | 4.6kg (10.1LBS) |
| Package | 1x Clark Synthesis Diluvio AQ339-100 underwater speaker |
| Speaker Power (W RMS) | 135.0 |
| Speaker Type | Full range |
| Impedance (Ω) | 4 |
| Loudspeaker diameter (mm) | 20.0 |
| Diaphragm type | N/A |
| Efficiency / Sensitivity (dB) | N/A |
| Max Linear Excursion (Xmax) (mm) | N/A |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 17000 |
