DAYTON AUDIO CF50N-4 Speaker Driver Midrange
The Dayton Audio CF50N-4 midrange speaker combines a 2-inch carbon fiber dome with a high-energy neodymium motor to deliver accurate midrange response from an incredibly compact enclosure.
Reference : 21238
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 24-11-2026.
Grantie 5 ans
Dayton Audio CF50N-4 Speaker Driver Midrange Carbon Fiber 50W 4 Ohm 91.5dB 500Hz-6KHz
DAYTON AUDIO CF50N-4 picture
The Dayton Audio CF50N-4 midrange speaker combines a 2-inch carbon fiber dome with a high-energy neodymium motor to deliver accurate midrange response from an incredibly compact enclosure. The lightweight yet rigid diaphragm has been optimized for wide dispersion and controlled response across the entire bandwidth. A rubber surround keeps the dome centered while damping the edge of the diaphragm to eliminate unwanted resonance outside the bandwidth. Offering low distortion and a smooth response from 500 to 6000Hz, this midrange driver is perfect for small 3-way designs and car audio installations.
Dayton Audio CF50N-4 Key Benefits in brief :
  • Woven carbon fiber dome and rubber suspension provide accurate response.
  • Powerful neodymium motor allows for compact size and delivers high efficiency.
  • The damped rear chamber reduces resonance frequency (Fs) and contributes to a smoother response.
  • The vented aluminum voice coil former helps dissipate heat to reduce power compression.
  • The rigid cast aluminum faceplate provides a solid, airtight mounting flange.
  • The integrated grille protects the dome from foreign objects.
DAYTON AUDIO CF50N-4 measurements
Product typeSpeaker
Speaker typeMedium
Nominal diameterØ92mm
Membrane materialCarbon fiber
Handling power50Wrms
Impedance4Ω
Frequency response500Hz-6kHz
Sensitivity91.5dB 2.83V/1m
Thiele-Small parameters
Resonance frequency (Fs)345Hz
DC resistance (Re)3 ohms
Coil inductance (Le)0.06 mH @ 10 kHz
Mechanical quality coefficient (Qms)4.09
Electrical quality factor (Qes)0.82
Total quality coefficient (Qts)0.68
Membrane surface area (Sd)19.6cm²
Voice coil diameterØ50mm
Package1x Dayton Audio CF50N-4
Speaker Power (W RMS)50.0
Speaker TypeMidrange
Impedance (Ω)4
Loudspeaker diameter (mm)90.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)91.5
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)500
Highest frequency (Hz)6000
DAYTON AUDIO CF50N-4 Speaker Driver Midrange Carbon Fiber 50W 4 Ohm 91.5dB 500Hz-6KHz
The Dayton Audio CF50N-4 midrange speaker combines a 2-inch carbon fiber dome with a high-energy neodymium motor to deliver accurate midrange...
