DAYTON AUDIO CE53N-4 Speaker Driver Full Range
The Dayton Audio CE53N-4 is a 5.08cm (2") full-range speaker, with an impedance of 4 Ω and a power handling of 10 W, designed for compact installations and budget-conscious projects. Its neodymium magnet and anodized aluminum diaphragm contribute to a clear and balanced reproduction, while keeping the transducer's footprint small.
Reference : 22536
13,90 €tax incl.
11,58 € tax excl.
Grantie 5 ans
Dayton Audio CE53N-4 Full-Range Speaker 10W 4 Ohm 87dB 200Hz-20KHz Ø5.08cm
DAYTON AUDIO CE53N-4: Front view
The Dayton Audio CE53N-4 is a 5.08cm (2") full-range speaker, with an impedance of 4Ω and a power handling of 10W, designed for compact installations and budget-conscious projects. Its neodymium magnet and anodized aluminum diaphragm contribute to a clear and balanced reproduction, while keeping the transducer's footprint small.
Intended for commercial applications as well as DIY builds, it fits into small sound systems for shops, restaurants or professional showrooms. Its 4Ω impedance makes it easy to pair with various amplifiers, allowing its use in installations where available space and component cost are important constraints.
DAYTON AUDIO CE53N-4: Dimensions and measurements
Technical specifications
Product typeFull-range speaker
Impedance4Ω
Sensitivity87dB 2.83V/1m
Frequency response200Hz-20kHz
Nominal diameter5.08cm (2")
PowerRMS: 10W
MAX: 20W
Thiele-Small parameters
Resonance frequency (Fs)197Hz
Diaphragm surface area (Sd)8.55cm²
Voice coil inductance (LE)0.07mH
DC resistance (Re)3.47Ω
Mechanical quality coefficient (Qms)5.4
Electromagnetic quality coefficient (Qes)1.3
Total quality coefficient (Qts)1
Force factor (BL)1.71T·m
Total moving mass + air load on diaphragm (Mms)0.87g
Mechanical compliance of suspension (Cms)0.75mm/N
Compliance equivalent volume (Vas)0.0053ft³
Max linear excursion (Xmax)2mm
Mounting informations
Cutout diameter4.7cm (1.85")
Depth3.3cm (1.3")
Number of mounting holes4
Total external diameter6.7cm (2.65")
Materials
DiaphragmAluminum
MagnetNeodymium
FrameSteel
SurroundRubber
Weight100g
PackageSold individually
Speaker Power (W RMS)10.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)50.8
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)200
Highest frequency (Hz)20000
DAYTON AUDIO CE53N-4 Speaker Driver Full Range 10W 4 Ohm 87dB 200Hz-20KHz Ø5.08cm
The Dayton Audio CE53N-4 is a 5.08cm (2") full-range speaker, with an impedance of 4 Ω and a power handling of 10 W, designed for...
