DAYTON AUDIO CE81PF-8 Speaker Driver Full Range
New
The Dayton Audio CE81PF-8 is a 7.62cm (3") full-range speaker with an impedance of 8 Ω and a power handling of 15 W, designed for installations where space and budget are limited. Its compact format allows integration into small enclosures, while its full-range design ensures signal reproduction without requiring filtering between multiple drivers.
Reference : 22532
14,90 €tax incl.
12,42 € tax excl.
Dayton Audio CE81PF-8 Full-Range Speaker 15W 8 Ohm 84dB 80Hz-18kHz
DAYTON AUDIO CE81PF-8: Front view
The Dayton Audio CE81PF-8 is a 7.62cm (3") full-range speaker, with an impedance of 8 Ω and a power handling of 15 W, designed for installations where space and budget are limited. Its compact format allows integration into small enclosures, while its full-range design ensures signal reproduction without requiring filtering between multiple drivers.
Intended for DIY projects as well as commercial applications, it can be used for background sound reinforcement in stores, small-scale installations, or vocal reinforcement in a meeting room. It is thus a compact option for manufacturers and integrators looking for a versatile driver for uses where footprint and cost must remain under control.
DAYTON AUDIO CE81PF-8: Dimensions and measurements
Product typeFull-range
Impedance8Ω
Sensitivity84dB 2.83V/1m
Frequency response80Hz-18kHz
Voice coil diameter1.98cm (0.78")
Nominal diameter7.62cm (3")
PowerRMS: 15W
MAX: 30W
Thiele-Small parameters
Resonance frequency (Fs)97Hz
Cone surface area (Sd)28.3cm²
Voice coil inductance (LE)0.14mH
DC resistance (Re)6.7Ω
Mechanical quality coefficient (Qms)7.92
Electromagnetic quality coefficient (Qes)0.9
Total quality coefficient (Qts)0.81
Force factor (BL)3.72T·m
Total moving mass + air load on the cone (Mms)3g
Mechanical compliance of suspension (Cms)0.889mm/N
Compliance equivalent volume (Vas)0.03ft³
Max linear excursion (Xmax)2.7mm
Mounting informations
Cutout diameter2.7"
Depth2"
Number of mounting holes4
Total external diameter3.75"
Materials
DiaphragmPaper
MagnetFerrite
FrameSteel
SurroundRubber
Recommended Enclosure Volume
Sealed Volume1.69L (0.06ft³)
Sealed F3107Hz
Vented Volume3.96L (0.14ft³)
Vented F357Hz
Weight550g
PackageSold individually
Speaker Power (W RMS)15.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)76.2
Diaphragm typePaper
Efficiency / Sensitivity (dB)84.0
Max Linear Excursion (Xmax) (mm)2.7
Lowest frequency (Hz)80
Highest frequency (Hz)18000
DAYTON AUDIO CE81PF-8 Speaker Driver Full Range 15W 8 Ohm 84dB 80Hz-18kHz
The Dayton Audio CE81PF-8 is a 7.62cm (3") full-range speaker with an impedance of 8 Ω and a power handling of 15 W, designed for...
