DAYTON AUDIO CE65W-8 Full Range Speaker Driver
The Dayton Audio CE65W-8 is a compact 2-1/2" (Ø63.5 mm) full-range speaker designed for applications requiring extended sound reproduction in a reduced form factor.
Reference : 22311
10,90 €tax incl.
9,08 € tax excl.
DAYTON AUDIO CE65W-8 Full-Range Speaker 7W 8 Ohm 83dB 105Hz-16kHz Ø6.35cm
The Dayton Audio CE65W-8 is a compact 2-1/2" (Ø63.5 mm) full-range speaker designed for applications requiring extended sound reproduction in a reduced form factor. It features a woven fiberglass diaphragm providing a wide frequency response, combined with a rubber surround and a large flat spider ensuring good mechanical durability. Its shielded magnetic motor allows use near sensitive electronic equipment, while its optimized magnetic structure ensures efficient diaphragm control and dynamic sound reproduction. With a nominal impedance of 8Ω, an RMS power handling of 7W, a sensitivity of 83dB (2.83V/1m), and a frequency response ranging from 105Hz to 16kHz, the CE65W-8 is a suitable solution for compact speakers, multimedia systems, embedded audio devices, and DIY projects requiring a versatile and space-saving full-range transducer.
DAYTON AUDIO CE65W-8: A compact and versatile design
With its 2-1/2" nominal diameter and compact form factor, the Dayton Audio CE65W-8 easily integrates into numerous small audio projects. Its robust design combines a woven fiberglass diaphragm, a rubber surround, and a large flat spider to ensure reliable mechanical performance and stable reproduction across a wide frequency range.
DAYTON AUDIO CE65W-8: Full-range speaker with shielded motor
The CE65W-8 features a shielded magnetic structure allowing use near displays or other sensitive electronic components. Its large motor contributes to improved diaphragm control and transducer efficiency, while its 20mm voice coil allows a maximum linear excursion of 2mm.
DAYTON AUDIO CE65W-8: Ideal for compact audio applications
Thanks to its 105Hz to 16kHz frequency response, 8Ω impedance, and 7W RMS power handling, the CE65W-8 is perfectly suited for compact speakers, multimedia audio systems, DIY electronic projects, and other applications requiring an affordable and high-performance full-range speaker.
Technical specifications
Product typeFull-range speaker
Nominal diameterØ6.35cm (2-1/2")
PowerRMS: 7W
Max: 15W
Impedance8Ω
Frequency response80Hz - 17000Hz
Sensitivity82dB 2.83V/1m
Voice coil diameterØ19.05mm (0.75")
Thiele-Small Parameters
Resonant frequency (Fs)112Hz
DC resistance (Re)6.9Ω
Voice coil inductance (Le)0.15mH
Mechanical quality factor (Qms)4.27
Electromagnetic quality factor (Qes)0.95
Total quality factor (Qts)0.78
Equivalent air volume of the moving mass compliance (Vas)0.021ft³
Mechanical compliance of the suspension (Cms)1.01mm/N
Force factor (BL)3.2T·m
Moving mass + air load on diaphragm (Mms)2g
Maximum linear excursion (Xmax)2mm
Diaphragm surface area (Sd)20.1cm²
Materials
Diaphragm materialFiberglass
Surround materialRubber
Voice coil wire materialCopper
Basket / frame materialSteel
Magnet materialFerrite
Mounting information
Overall external diameterØ83.31mm (3.28")
Cutout diameterØ58.93mm (2.32")
Depth45.21mm (1.78")
Number of mounting holes4
Mounting circle diameterØ73.66mm (2.9")
Recommended enclosure volume
Sealed enclosure1.13L (0.04ft³)
F3 Sealed enclosure127Hz
Bass reflex enclosure2.83L (0.1ft³)
F3 Bass reflex enclosure68Hz
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)63.0
Diaphragm typeGlass fiber
Efficiency / Sensitivity (dB)83.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)80
Highest frequency (Hz)17000
DAYTON AUDIO CE65W-8 Full Range Speaker Driver 7W 8 Ohm 83dB 105Hz-16kHz
The Dayton Audio CE65W-8 is a compact 2-1/2" (Ø63.5 mm) full-range speaker designed for applications requiring extended sound...
