TANG BAND W4‑1052SDF Full-Range Speaker
The Tang Band W4‑1052SDF is a 10.16cm (4") full-range speaker designed to cover extended spectrum from single transducer, facilitating architectures without complex filtering. It leverages structured polypropylene diaphragm combined with wide temperature-range rubber suspension, enabling stabilization of resonance frequency (F0) despite thermal and mechanical variations. This configuration promotes regular response over time while maintaining predictable behaviour in varied operating environments.
Reference : 22269
56,57 €tax incl.
47,14 € tax excl.
Shipping date: 11-11-2026.
Tang Band W4‑1052SDF Full-Range Speaker 20W 4 Ohm 87dB 70Hz-17kHz Ø10.16cm
Tang Band W4‑1052SDF : Front view
Intended for compact home cinema systems, multimedia installations and embedded integrations, it exploits stamped steel chassis ensuring rigid structure while controlling footprint and integration cost. This approach extends to broad compatibility with different load volumes, enabling integration in both sealed and bass-reflex enclosures while preserving homogeneous restitution suited to versatile daily applications.
Tang Band W4‑1052SDF : Dimensions and frequency response
Product typeFull-range speaker
Nominal diameterØ10.16cm (4")
PowerRMS : 20W
Max : 40W
Impedance4Ω
Frequency response70Hz-17kHz
Sensitivity87dB
Voice coil diameter25.4mm
Thiele & Small Parameters
Resonance frequency (fS)70Hz
DC resistance (RE)3.8Ω
Electrical quality factor (QES)0.46
Mechanical quality factor (QMS)4.80
Total quality factor (QTS)0.42
Equivalent suspension air volume (VAS)5.21L
Maximum impedance (Zmax)45Ω
Voice coil inductance (LE)0.077mH
Force factor (B·l)4.10T·m
Moving mass (MMD)4.61g
Diaphragm area (SD)0.0057m²
Maximum linear excursion (Xmax)2.6mm
Materials
Diaphragm materialStructured polypropylene
Suspension materialRubber
Magnet materialFerrite
DimensionsØ116.0 x 64mm
PackageSold individually
Speaker Power (W RMS)20.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)101.6
Diaphragm typePolypropylene
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)2.6
Lowest frequency (Hz)70
Highest frequency (Hz)17000
TANG BAND W4-1052SDF Full-Range Speaker 20W 4 Ohm 87dB 70Hz-17kHz Ø10.16cm
The Tang Band W4‑1052SDF is a 10.16cm (4") full-range speaker designed to cover extended spectrum from single transducer, facilitating...
