DAYTON AUDIO PC68-4 Full-range speaker 20W 4 Ohm 86dB 120Hz - 17kHz Ø6.3 cm
A compact wideband loudspeaker with beautiful finishes. Ideal for building/repairing a small audio system.
3.3 / 5
Reference : 13163
14,30 €tax incl.
11,92 € tax excl.
Shipping date: 23-04-2026.
Grantie 5 ans
PC68-4
wide band speaker 4Ω / 20W / 120Hz-17000kHz
Front View Dayton Audio Pc68
A loudspeaker compact wideband and beautiful finishes. Ideal for building / repair a small audio system or as a basis for more complex assemblies requiring multiple speakers of the same type.
Despite its small size, the PC68-4 2 "gives a good sound reproduction and is suitable for many uses. It gives excellent results when used alone (one speaker per channel), making it a candiat of choice for the design / repair of portable speakers, for line arrays. It will be as effective in more complex configuration such as sound bars or any other configuration requiring high networking speaker.
PC68-4 compact design and natural signal
HP dayton
The cone is fiberglass with a thought form to comply with the natural way signal. The coil and the pole are drilled to better handle high powers. The enclosure PC105-8 4 "is equipped with a magnet of high energy ferrite for high performance and increased efficiency. A smooth response and a true reproduction of the broad spectrum make it an ideal speaker for simple mono-hp systems.
TypeFull-range speaker
Nominal diameter635mm
PowerRMS : 20W
Max : 40W
Impedance4 Ohms
Frequency response120 - 17000Hz
Sensitivity86.1dB @ 2.83V/1m
reel diameter19.05mm
Resonance Frequency117.1HzFs
DC resistance3.8Re
Indutance Coil0.29mHThe
Mechanical Quality Factor2.49Qms
Electrical Quality Factor0.87Qes
Total Quality Factor0.65qts
Volume equivalent Compliance0.02ft²you
Compliance suspension1.07mm/NCms
Mobile mass1.7gMms
maximum linear excursion2mmXmax
membrane emissive surface21.2cm²sd
MembranePoly / composite
ContoursGomme
wiringCCA
FormerAluminum
StructureSteel
MagnetFerrite
overall external diameter608mm
Drilling diameter640mm
Depth370mm
Bolt diameter734mm
Number of mounting holes4
Speaker Power (W RMS)20.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)63.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)120
Highest frequency (Hz)17000
3 reviews
content
expédition rapide et j'ai placé ce haut parleur dans barre de son ....MERCI
This review has been posted for DAYTON AUDIO PC68-4 Full-range speaker 20W 4 Ohm 86dB 120Hz - 17kHz Ø6.3 cm
The sound is clear, but it does not have any low frequencies due to its size. Good choice without much demands on its sound!
petit haut parleur large bande
Ce type de hp que l'on peut retrouver chez Tivoli Audio.Belle finition, va intégrer des enceintes satellites tv (arrière) en cours de réalisation.Et comme le VAS n'est pas trop important petites enceinte suffiront.
