TANG BAND W6-2144 Full-Range Speaker
The Tang Band W6‑2144 is a 16.51cm (6.5") full-range speaker designed to ensure extended and coherent restitution from single transducer. It delivers 89dB sensitivity (1W/1m) with Qts of 0.45, leveraging underhung motor architecture combined with ferrite magnet and aluminium phase plug to stabilize magnetic field and control dispersion in upper spectrum. This configuration effectively reduces second and third-order harmonic distortion, guaranteeing linear behaviour even at sustained level.
Reference : 22268
159,90 €tax incl.
133,25 € tax excl.
Shipping date: 24-11-2026.
Tang Band W6‑2144 Full-Range Speaker 35W 8 Ohm 89dB 45Hz-20kHz Ø16.51cm
Tang Band W6‑2144 : Front view
Intended for full-range enclosures and minimalist configurations seeking phase coherence, it combines bamboo fibre paper diaphragm with structured Santoprene elastomer suspension, enabling combination of lightness, rigidity and controlled damping. This approach extends to controlled transient response and mechanical stability across entire useful travel, facilitating integration in both bass-reflex and acoustic line loading while maintaining homogeneous restitution across exploited spectrum.
Tang Band W6‑2144 : Dimensions and frequency response
Product typeFull-range speaker
Nominal diameterØ16.51cm (6.5")
PowerRMS : 35W
Max : 70W
Impedance8Ω
Frequency response45Hz-20kHz
Sensitivity89dB
Voice coil diameter38.5mm
Thiele & Small Parameters
Resonance frequency (fS)45Hz
DC resistance (RE)6.8Ω
Electrical quality factor (QES)0.62
Mechanical quality factor (QMS)1.73
Total quality factor (QTS)0.45
Equivalent suspension air volume (VAS)34.6L
Maximum impedance (Zmax)28Ω
Voice coil inductance (LE)0.010mH
Force factor (B·l)5.45T·m
Moving mass (MMD)8.98g
Diaphragm area (SD)0.014m²
Maximum linear excursion (Xmax)3.0mm
Materials
Diaphragm materialBamboo fibre paper
Suspension materialSantoprene
Magnet materialFerrite
DimensionsØ176.5 x 97.5mm
PackageSold individually
Speaker Power (W RMS)35.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)165.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)3.0
Lowest frequency (Hz)45
Highest frequency (Hz)20000
TANG BAND W6-2144 Full-Range Speaker 35W 8 Ohm 89dB 45Hz-20kHz Ø16.51cm
The Tang Band W6‑2144 is a 16.51cm (6.5") full-range speaker designed to ensure extended and coherent restitution from single transducer. It...
