HIDIZS S9 Portable Amplifier DAC AK4493EQ Balanced 32bit 768kHz DSD512
The Hidizs S9 is a portable headphone and DAC amplifier combo, perfect for giving you the best sound quality wherever you are. It integrates high quality components in a compact, practical and stylish package.
Reference : 14840
119,00 €tax incl.
99,17 € tax excl.
This product has been replaced by the new version, the HIDIZS S9 PRO DAC ES9038Q2M.
Hidizs S9
Hidizs S9 Amplificateur casque DAC portable AK4493EQ Symétrique 32bit 768kHz DSD512
AK4493EQ DAC
At the core of the digital/analog conversion stage, a 32-bit AKM AK4493EQ chip with Velvet Sound technology contributes greatly to precise, dynamic and musical reproduction. This allows the S9 to display a THD+N of -113dB and a dynamic range of 123dB.
The AK4493EQ supports high-resolution files up to 32bit 768kHz PCM and DSD512.
Headphone amplifier
Although it is particularly compact, the S9 is not lacking in resources. It is indeed capable of developing a power of 2x 125mW on its balanced output and 2x 90mW on its unbalanced output.
Balanced / Single-Ended
The S9 adapts to your listening device by offering a dual output: unbalanced 3.5mm jack and balanced 2.5mm jack. It is thus capable of accompanying the vast majority of headphones and headphones on the market.
Design
Elegant, the Hidizs S9 is dressed in a sturdy CNC-machined aluminum casing and glass front. An LED illuminating the brand logo indicates the sampling rate of the file being played.
Test du Hidizs S9 par Audio Science Review (Amir)
" Le hidizs S8 était un adaptateur révolutionnaire, offrant des performances étonnantes. Le S9 reprend ces performances et ajoute une sortie symétrique pour offrir encore plus de puissance au même prix que le S8. "
Product typePortable headphone amplifier & DAC
Input1x USB-C
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 2.5mm
DAC chipAK4493EQ
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
SNR119dB / 117dB
Channel separation79dB / 114dB
ASIO compatibility
Compatible systemsAndroid, Windows, MAC OS, iOS
Output powerSingle-ended : 2x 90mW @ 32Ω
Balanced : 2x 125mW @ 32Ω
Frequency response20Hz - 50kHz
THD+NSingle-ended : 0.002% (1kHz)
Balanced : 0.0018% (1 kHz)
SNRSingle-ended : 119dB
Balanced : 117dB
Channel separationSingle-ended : 79dB (32Ω)
Balanced : 114dB (1kHz, A-Weighting)
Output impedance< 1Ω
Recommended headphone impedance8-150Ω
Housing materialCNC machined aluminum
Glass
Dimensions18 x 59 x 8mm
Weight11g
Package1x Hidizs S9
1x USB-C 65cm cable
1x USB-C 10cm cable
1x USB-C to USB-A adapter
1x Rear clip
OutputJack 3.5mm
OutputJack 2.5mm
Parfait pour moi
Connecté à Qobuz, je l'utilise en sortie d'une tablette Samsung S5e, branché sur un casque Grado GW 100. Superbe définition, reconnait les fichiers HiRes. Très satisfait. Je me dis que j'aurais peut-être du attendre le nouveau modèle S9 Pro. Mais tant pis, je très satisfait. Merci Audiophonics pour la livraison rapide.
This review has been posted for HIDIZS S9 Portable Amplifier DAC AK4493EQ Balanced 32bit 768kHz DSD512
The Hidizs S9 is a portable headphone and DAC amplifier combo, perfect for giving you the best sound quality wherever you are. It integrates high...
