By buying this product you get 39 loyalty points
The iBasso PB6 Macaw is a portable tube headphone amplifier designed to provide high-power amplification for mobile sources. It features a balanced design incorporating JAN6418 tubes powered by 22.5V, to increase the dynamic range whilst maintaining stable performance with a variety of headphones, delivering up to 2300mW + 2033mW into 32Ω when using an external power supply.
The iBasso PB6 Macaw is based on a balanced architecture incorporating four JAN6418 tubes, enabling independent amplification of each channel whilst minimising unwanted crosstalk between channels. This configuration is complemented by a power supply voltage of 22.5V, which increases the available dynamic range and allows for a more stable reproduction of level variations, particularly during rapid signal changes.
Furthermore, the mechanical mounting of the tubes relies on a PORON suspension, which absorbs structural vibrations to minimise microphonic effects, thereby ensuring that the audio remains clear even when the device is in motion.
The PB6 operates using two complementary output modes, allowing you to adjust the amplifier’s behaviour to suit your taste. TUBE mode directly engages the JAN6418 stages, resulting in a warmer, smoother sound.
Conversely, the Class A/B mode utilises four BUF634A buffers, whose current capacity and fast response time enhance clarity and extend the dynamic range, resulting in a more detailed and analytical sound.
The internal power supply is based on an 8.4 V lithium-ion polymer battery; its higher voltage reduces the need for the multiple DC-DC conversions typically required with 3.7 V cells. This simplification of the power architecture limits residual ripple, thereby enabling the analogue stages to be powered by a cleaner and more stable voltage.
In addition to battery operation, the PB6 features a 12V external power supply mode, allowing users to overcome the power constraints associated with portable use. This direct power supply increases the available power reserve, enabling the amplifier to deliver 2300mW + 2033mW into 32Ω whilst maintaining stable operation with complex loads.
The level control utilises an NJW1195A analogue controller in a 4-channel configuration, ensuring consistent channel management within a balanced configuration. This architecture allows for adjustment in 0.5dB increments, enabling precise adjustment of the listening level without affecting the balance between channels.
The PB6 offers two bandwidth modes to adapt the circuit’s response to the characteristics of the signal and the headphones being used. The wide-bandwidth mode prioritises a fast response, which improves the reproduction of transients and enhances the perception of micro-details. Conversely, this approach is complemented by a narrow-bandwidth mode that attenuates the fastest components of the spectrum, thereby softening the sound reproduction.
| Specifications | |
| Product type | Portable headphone amplifier |
| Inputs | 1x Jack 3.5mm 1x Jack 4.4mm |
| Outputs | 1x Jack 3.5mm 1x Jack 4.4mm |
| Tube | 4x JAN6418 |
| Autonomy | Class AB mode : 13.5h Tube mode : 9.5h |
| Charging time | 2.5h |
| Balanced 4.4 mm jack output | |
| Gain level Class AB mode | Low gain : +6dB High gain : +12dB |
| Gain level Tube mode | Low gain : +8dB High gain : +14dB |
| Total harmonic distortion more noise (THD+N) | -112dB |
| Frequency response | 10Hz-80kHz |
| Dynamic range | Class AB mode : 125dB Tube mode : 116dB |
| Crosstalk | Class AB mode : 135dB Tube mode : 100dB |
| Output level | 12V DC : 9.5Vrms Battery : 8.5Vrms |
| Output power | 12V DC : 2300mW+2300mW @32Ω Battery : 1600mW+1600mW @32Ω |
| Output impedance | 1.2Ω |
| Background noise | 2.3µV |
| single-ended 3.5mm jack output | |
| Gain level Tube mode | Low gain : +9dB High gain : +15dB |
| Total harmonic distortion more noise (THD+N) | -110dB |
| Dynamic range | Class AB mode : 125dB Tube mode : 110dB |
| Crosstalk | Class AB mode : 121dB Tube mode : 100dB |
| Output level | 12V DC : 4.6Vrms Battery : 4.5Vrms |
| Output power | 12V DC : 660mW+660mW @32Ω Battery : 660mW+660mW @32Ω |
| Output impedance | 0.5Ω |
| Background noise | 1.8µV |
| General | |
| Weight | 293g |
| Dimensions | 140.7 x 78.9 x 19.6mm |
| Color | Silver |
| Package | 1x iBasso PB6 Macaw 1x Mains adapter 1x USB-A to USB-C cable 1x 3.5mm jack cable 1x 4.4mm jack cable |
| Input | Jack 4.4mm |
| Input | Jack 3.5mm |
| Output | Jack 3.5mm |
| Output | Jack 4.4mm |
| Color | Silver |
| Class | Class A / AB |
| Class | Tube amp |
| Remote Control | No |
