Gilles G.
Pratique
Bastien P.
Epoustouflant !
C'était la première fois que j'achetais des enceintes sans les écouter auparavant, juste en me fiant aux mesures ......
Sherman M.
Great DAC!
I absolutely love this DAC because you can switch between the two chips while you are listening to music to hear the difference.
Customers reviews - There are 20793 reviews.
Luka C.
OTG Adapter USB-C to Female Jack 3.5mm This OTG adapter has a USB-C male on its side and a USB-C female and 3.5mm female jack on its ends. It is mainly designed to be used with smartphones that do not have a 3.5mm...
3.5mm jack doesnt work on Samsung
- 3.5mm jack doesnt work on Samsung S21 FE & Samsung A20e
- USB Type-C 90° adapter extender works fine
Long story short product doesn't work properly.
Collica C.
SHANLING M6 PRO 21 DAP Digital Audio Player HiFi 64Go DAC 2x ES9068AS 32bit 768kHz DSD256 Shanling offers with the M6 Pro 21 an updated and improved version of its M6 Pro player. This one now integrates a double DAC ESS ES9068AS, an amplification stage with a bigger...
Ottimo prodotto,OTTIMO SERVIZIO!!!!!
Il Dap è spettacolare!!! Il servizio di Audiophincs è ancora meglio!!!!!Persone molto disponibili, molto gentili e molto professionali!! Ho sempre Adorato la FRANCIA, questa è la conferma!! Per me 10 e lode!!! Cris.
Anton P.
Flawless, beautiful Power Amp.
Thanks Audiophonics for this great Amp.
It came well packaged and protected.
My speakers sound way more dynamic now.
I used the Topping Pa5 before on my Polk R700 Speaker setup.
Not sure, if i am having a placebo, but it sound much better.
There is no hiss and popping. Dead silent amp and pure enjoyment of music.
Jerome V.
super facile à souder
Utilisé pour refaire un câble symétrique.
Soudure super facile à faire grâce, notamment, aux emplacements biseautés des contacteurs entre le connecteur XLR et le câble employé.
Jerome V.
2 Pins Nickel Plated Connectors for Sennheiser Headphones (Pair) These 2-pin connectors can be used to design cables for certain Sennheiser brand helmets.
Moyen pour gros câble
Connecteurs utilisés pour refaire un câble symétrique XLR pour un casque sennheiser HD ovation II (un vieux pépère très bon au demeurant).
A l'écoute, le casque est transcendé donc ça marche.
Par contre, deux reproches et demi.
1- Les câbles trop gros ne passeront pas dans la gaine du connecteur.
2 - les dimensions du connecteur ne sont pas ajustées aux connections du casque HD ovation II (je ne me prononce pas pour les autres) et ce dernier tombe en permanence. Il a fallu que je le retaille un peu pour que cela rentre et que cela tienne sans tomber à tout bout de champ du casque.
2.5 - je suis moins bon que je pensais en soudure et c'est un peu la galère. Les contacts mériteraient d'être biseautés pour faciliter la soudure.
Jerome V.
Pour cable casque symetrique sennheiser
J'ai utilisé ce câble pour faire un câble casque en symétrique pour un vieux casque sennheiser HD ovation II branché en XLR sur un Topping A90 discrète.
J'ai souvent lu des superbes comptes rendus concernant ce casque et j'avoue que je ne comprenais pas trop ce que l'on pouvait lui trouver.
Maintenant je sais.
Cependant, il lui faut un bon câble et le Mogami negflex W3106 lui apporte beaucoup d'informations que le câble d'origine n'amenait tout simplement pas.
En résumé, c'est un super câble pour casque.
Attention, il est cependant assez lourd et le diamètre du câble est important et peut empêcher l'insertion correcte dans les connecteurs utilisés pour le branchement avec le casque.
Notamment pour le type spécifique des connecteurs sennheiser.
stephane d.
une revelation
c'est mon 1er casque planar et je dois avouer que c'est plutot pas mal à condition de l'associer à du bon materiel pour en tirer pleinement profit, utilisé avec un dap hiby r6 et ampli dac hidizs DH80S avec cable usb c fourni avec, et des fichiers flac, hi-res et dsd, je redecouvre un plaisir encore meilleur auparavant même mon fidelio X3 qui est pourtant très bien mais un ton en dessous je pense, mention speciale pour le dac hidizs qui s'associe bien à ce casque et ce sur les bons conseils audiophonics chez qui j'ai acheté ce casque, merci à eux et un conseil à ce prix là vous ne regretterez pas.
Franck C.
Peut mieux faire
Ce petit appareil aurai pu être très bien, mais il y a plusieurs problèmes : la télécommande ne fonctionne pas. J'ai mis au moins 3h pour paramètrer en mode upnp avec le logiciel bubbleupnp.
Le logiciel gratuit de la marque Sabaj s'arrête trop souvent lorsque l'on lance une playlist. J'ai'essyé de lire des flac, ca focntionne mais il est tres lent à faire le recherche de tous les flac.
La qualité du son est
très bien pour le prix.
Pour sertir les fild hp et chuko
Parfait. Bon marché. Sur câbles hp ideal. Evité fils nu. Essayer vous serrez enchanté du resultat. Metre du desoxi gold pour eviter l oxidstion et amelioré la transmission du signal. Neutre et evite les brins de fil nu. Chuko pour être conforme aux normes electrique la aussi ne de nature pas la qualité de vos fils montés.
Patrick R.
Incontournable
Un produit robuste, qualitatif. Facile à monter. Raccordements à visser, dorés 24 carats. Seul bémol, la masse est à l'opposé des autres pôles : il faut avoir assez de "mou" sur les fils.
Rien à voir avec les prises standards disponibles en magasin de bricolage. Chaudement recommandé.
Arnaud P.
idem
je dis pareil que les autres avis 5/5 : c'est 5/5 ! Voilà :-)
Lars H.
NEOTECH NC-01675RH Banana Plugs Rhodium Plated OFC Copper Cryo Treatment Ø8mm (Set x4) These Neotech NC-01675RH banana plugs feature excellent design quality and are ideal for creating high-performance HiFi speaker cables. The contacts are made of Rhodium-plated...
Works well and looks good too
They're a good match for my new speaker cables that are a bit heavy Easy to fit and tighten My speakers passed the frequency test with the plugs in Regular factory fitted brass banana plugs on my old cables did the same But I like some eye candy Since the cables and plugs are visible from above on my amplifier So I paid for good quality as well as aesthetics
Lars H.
High quality sound
Excellent cable for current demanding speakers and matching powerful amplifier Effortless delery in the hole frequency area that my speakers can deliver Relaxed, full of details and never getting harsh in treble even at high listening levels Super satisfying
Casque nomade ... mais haut de gamme
J'ai fait sa critique sur un autre produit qui lui va comme un gant : Le DAC E1DA.
Je recommande les deux.
J'ai un casque Focal et ShennHeiser, je vais les offrir à mes neveux. Mezze only !!!
Stéphane A.
Fonctionne très bien
Produit très simple d'utilisation. Je l'ai pris pour comparer 3 dac/preamplis. Je n'ai aucun soucis de son. , malheureusement je n'arrive pas à entendre une différence... Surement mes oreilles...
jf a.
E1DA COSMOS GRADE A Balanced ADC ES9822Pro 32bit 384kHz With the Cosmos, E1DA offers a high-end balanced ADC, whose analog-to-digital conversion stage is based on an ES9822Pro chip. It uses only high quality audio components to...
Great product !
If you want to seriously get into measurement but you can not afford kilos of money, go buy it !
Be aware of the Zin, for small signal it starts around 600Ohm, but THD+N of 140dB is there !
With a really good osc (janascard dot cz, another great piece of hardware) I don't have any harmonic ! just noise floor around -140dBFS (with 16384 fft points).
only 2 minor concerns:
- I hate usb-C , it is not harsh enough...
- same for the jack if you want to convert amplifier outputs
So it's really a great product !
Alain F.
Erreur de dimensions sur le fiche produit
Bonjour, transformateur très bien fini mais erreur de dimensions sur la fiche produit. Le diamètre est d'environ 75mm et non de 62mm, ce qui remet en question mon projet.
Michal K.
I used this cable to make a DC power cord. Exceptional value for money.
Michal K.
High quality, good looking plug. Worth every penny.
Lucian C.
Amazing ????
Really? How amazing was ? How did you succeed to identify each cable , to be correctly sold onto connectors ?
To be able to handle any DIY work, a minimum tooling is necessary including a multimeter with the continuity test function.
This little tool would have made it easy for you to figure out which is which.
Mathieu W.
DD TC44C Portable Balanced DAC 2x CS43131 Lightning 32bit 384kHz DSD256 The DD TC44C is an extremely compact but very powerful portable DAC, particularly suitable for association with a smartphone. It integrates a USB-C input and a dual output on...
SURPRISE
Pas d'attente partculière lors de la commande Sinon d'avoir un bac dongle qui gère mes câbles (IEM IE900 et MSR7b) au format symétrique 4.4. Excellente surprise DAC a signature très neutre avec superbe séparation et image, grave très tendu. Je le trouve supérieur à mon audioquest cobalt. L'achat du câble TS9 est fortement conseillé et amène une amélioration notable de la scène sonore et notamment la profondeur. Très beau médium aussi. Bref une sacrée surprise pour le prix. je l'utilise avec audirvana et mon iPhone (qobuz)
DAVID D.
la qualité à tout points de vues
Adepte de Oyaide et de sa qualité sonore, je n'ai pas été déçu par ce modèle qui accompagne mes câbles de la même marque. Top produit.
DAVID D.
Très bon tiens la comparaison avec mes oyaide Rhodium
Je l'utilise avec du cable Oyaide (blackmamba, Tunami) et en comparaison avec les prises Oyaide Rhodium, le rapport qualité prix est largement en faveur de Viborg. La qualité de fabrication est top.
DAVID D.
hubert b.
après rodage !
J'étais un peu déçu par l'agressivité au départ (voir avis précédent), mais après quelques heures, c'est beaucoup moins fatiguant ! Je me suis peut-être habitué, je pense surtout que quelques heures de rodages lui ont fait du bien, du coup, je suis content !
à choisir entre un ampli habituel dans les 300€ ou ça 5xmoins cher, si on a pas besoin de toutes les options il n'y a pas à hésiter !
Arthur L.
AXF-100 vs. Matrix Element H usb-filter
The Matrix is 9 X as expensive, but is outplayed in musicality, detail and soundstaging by the AFX-100. Both where played with external powersupply. In combination with the internal power-filter AFX-106 it is an absolute bargain.
Whhaaaouh !!!
Je voulais un casque nomade mais très bon.
On me conseille le Mezze néo 99. Celui en bois est très beau mais son frère jumeau sans bois coûte 100€ de moins. J'opte pour celui-là.
Audiophonics me demande si j'ai ce qu'il faut pour un casque symétrique (je reçois un cours sur la symétrisation). Non.
Ce casque peut se brancher via un cordon asymétrique (câble habituel) mais c'est un autre monde avec un câble symétrique (40€ de +). Vraiment ?
Les conseils de la boutique ayant toujours été bons, je dis ""OK, avec ce câble alors !
Mais votre smartphone sort-il en symétrique ? Non.
Alors si vraiment vous voulez passer de deux écouteurs sur les oreilles à une écoute immergée dans une salle de concert, il vous faut un E1DA (129€ de +). Un mini DAC-ampli de haute volée.
J'ai envie de me faire plaisir et je fais l'achat, je pars en voyage et sans musique, c'est pas possible.
Je mets le casque Mezze avec le câble standard. C'est très bon. Le casque est super agréable sur la tête, le son est bon. Il ne tien t pas chaud. Super.
Quid du E1DA du coup !? Je branche tout ça. Whhaaaouh !!
Ce n'est pas mieux, c'est un autre monde.
Je n'ai rien sur mes oreilles, je suis effectivement dans la salle de concert. Je situe les instruments, et les musiciens jouent pour moi. Tout y passe, classique, Jazz Rock, boum boum ... Génial.
J'ai parfois l'impression que je vais déranger mon épouse qui dort. Non. Tout est pour moi, rien pour ceux qui sont à côté.
Je ne regrette pas une seconde mon achat.
gael s.
Petit mais...
Ce module marche plutôt bien, le Bluetooth ne décroche pas et la connexion s'établie sans soucis.
Sa taille et son alimentation lui permet de s'intégrer facilement n'importe ou.
La puissance est légère mais suffisante pour diffuser de la musique dans ma salle de bain.
le son est plutôt orienté vers le bas medium / grave , pas très équilibré mais reste écoutable pour de la diffusion.
il ne faut pas lui demander de la hifi il n'est pas fait pour ça.
il s'éteint automatiquement après quelques minutes mais ne redémarre pas tout seul (pas le mien).
il faut le rebrancher pour qu'il se rallume.
Werner K.
Protection modules for stereo speakers 12V 16A (Pair) This double mono protection module consisting of two cards will allow you to properly protect your speakers.
Speaker Protection Board
Sehr, sehr gute Verarbeitung. Top Qualität. Extrem schneller Versand und Lieferung. Vielen Dank
Stefan D.
XDUOO LINK2 BAL Portable Balanced USB DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256 Particularly compact to accompany you in all your movements, the xDuoo Link2 BAL also offers very beautiful sound performances, thanks to a carefully balanced architecture and...
Outstanding! Neutrality and musicality, excellent physical controls
The controls work under Windows 7, the pause button can pause Youtube in Google Chrome. The analog-like audio quality, excellent price that rivals 2x more expensive products...Works under Android 8 with HTC 10. Very unique timbre, tested with Sennheiser HD599 and Focal Listen Pro. The detail does not hit you in your face, unlike ESS DAC. It gave slightly better performance than Arcam rPac (which had an expensive OFC USB cable). Yet, plenty of neutral detail even under Youtube (shocking, I know). Bass is soft and dense (in a good way, controlled, with impact). Best of all, the listen is not tiring. Normally, this level of detail is fatiguing, especially with TI or ESS DAC products. I know of this little gem because of this expert review, see the LINK below (pun intended). There are 2x more expensive dongles that are not better. Audiophonics has unbelievable customer support via e-mail, even late at night, and great price, better than the official Aliexpress shop of Xduoo`s:
https://andyaudiovault.com/xduoo-link2-bal/
Olivier M.
MINIDSP FLEX Audio Processor DSP Balanced SHARC ADSP21489 XMOS Bluetooth The miniDSP Flex is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor used previously with a redesigned input/output...
Un peu compliqué mais bluffant avec DiracLive
Une méthode d'activation de licence DiracLive (à acheter séparément) du siècle dernier. Quelques bugs dans le logiciel DiracLive au moment de la calibration (MacOS, d'où les 4 étoiles uniquement) mais le résultat est vraiment bluffant ! Le son des instrument est plus net, plus précis. Quand on désactive la correction, c'est mou, c'est flasque, ça dégouline. Je recommande vraiment. Et merci à l'équipe Audiophonics pour son support.
john p.
Ultimate cables for me ?
I am running two pairs per channel to my Klipschorns (just to be on the safe side - one is fine too) . This is the best cable I ever tested no matter the price. Looking at the price It was difficult for me to believe the difference it made. I really regret not giving solid core cables a chance earlier on. The only caveat is the gauge of the cable- experimenting with the gauge is critical and that was the mistake I had previously done during tests on solid core cables . These combined 20awg cables are ridiculously good. The bass extension, control and the crystal clear mid-highs imho are usually achieved by major gear upgrades not a few meters of wire!!! and you Know horns don't lie !!!
Philippe S.
MONOLITH M-15 V2 Active Subwoofer THX 1000W Black The THX® certified Monolith M-15 V2 subwoofer delivers deep bass with low distortion. Dropping below 16Hz, the Monolith M-15 V2 unleashes significant volume with the ability...
La bonne affaire !
C'est mon cinquième caisson grave, je peux dire que pour le prix, je n'ai pas été déçu. Puissant, clair avec des graves propres, je n'ai pas regretté le fait qu'il n'y ait pas de correction électronique. Le rapport qualité prix est passé de très bon à bon depuis la hausse du prix.
Philippe S.
La bonne affaire !
Je suis un habitué des câbles hi-fi de qualité, j'ai été heureux de voir que ce rj45 rivalise avec des câbles 3x plus cher. Je recommande.
Philippe S.
Bon rapport qualité prix, il alimente une voie centrale Paradigm founder c90 avec brio, les voix sont claires et charpentés, tous les détails sont là. Évidemment il y a mieux mais bien plus cher. Je recommande.
Philippe S.
La bonne affaire !
Après plusieurs tests, je le trouve aussi bon que mon audioquest carbon à 179 €. Le rapport qualité prix est donc excellent.
Michel V.
KT120 Tung Sol
Bonjour à toutes et à tous.
Ayant débuté en 1967, il y a 55 ans, j'ai construit notamment il y a quelques années un canal basses pour multi-amplification autour des tubes KT90 EH. Le remplacement par des KT120 n'apporte pas une augmentation de puissance, mais procure des basses mieux tenueset dynamiques qu'avec des KT90 EH voire des 6550 Sylvania ou Tung-Sol NOS ni des KT88 GEC. Ce tube est un excellent choix dans les basses grace à une plaque bien dimensionnée et surtout une cathode mieux chauffée que celles des KT90, KT150 ou KT170, lesquelles travaillent à plus basse température de cathode.
Par contre leur rendu en large bande laisse à désirer par rapport aux tubes NOS et même aux KT150.
VAGNER Michel, Moselle.
Johan S.
Provides full galvanic isolation.
This unit provides true galvanic isolation between usb input and the spdif output. It therefore prevents ground loops between PC and DAC (for instance) and that by itself gives a big inprovement in signal to noise ratio. Should be pointed out in the description.
Teddy T.
L'avis d'un cabloseptique
Alors oui ça change, le cable apporte un reel gain, chez moi ça ce ressent surtout sur le haut médium, l'accuphase sort encore plus de potentiel, ça change pas l'ampli non plus ça reste un cable, mais il vaut clairement ces 50 €.
Charles-Antoine L.
TOPPING L30
Livraison rapide en 3 jours. En ce qui concerne le L30 pour ma part je l’associe à un Hifiman Sundara. Casque un peu gourmand pour ce petit ampli il faut donc monter le gain à +9db. Une fois cela fait l’association est fabuleuse avec de belles bases et du détail pour un prix plus que raisonnable.
Thomas K.
Great tube amp for a very reasonable price with minor quirks
Ordered this thing from Germany, it arrived well packaged and without any issues. I will order from Audiophonics again if I ever need something. The prices are more than competetive and the service was nice and answered all my questions about the product.
The amp itself performs very nicely, but keep in mind that some USB ports could carry over some interference issues to your DAC and then to the AMP. Via USB I had some weird electrical buzzing, an optical cable fixed all those issues, so keep that in mind. This is not really an issue of this amp but more an issue that could happen with any computer and an AMP that is sensitive to picking these things up (this includes stuff from your phone too).
About the amp itself. Music sounds fuller with it, I am pairing it with the 650's from Sennheiser and it's pleasant. The transformer of the TA-26 can hum a little, mine does it but it's not noticeable when listening to music, but that's to be expected with a transformer like this (might be fixable so it's completely silent). The tubes are completely silent when not listening to anything, no humming, buzzing or microphonics in my case, so that's very nice.
Vijay Kishan R.
Best price performance ratio
I bought this 6 months ago for my Canton Refence speakers and it has performed beyond expectations. I have A/B ed them against amps 5X the price and this one still holds its own in terms of delivery. others may look flashy with all dancing lights (I'll buy my christmas lights seperately - thank you), but this one delivers. Combined with a decent DAC (like the Topping D90SE or even an SMSL SU-9N) the set up absolutely shines. I just bought another LPA-S500NC one for the centre speaker (another Canton Reference). My application is purely music - stereo, and now multichannel (routed through Okto DAC 8 Pro). Would be a tad much for Movies, but hey, these bad-boys have an RCA switch - now they are connected to my BD-player as well ;-)
Quality and excution is superb (review on Audiosciencereview ) and communication with Audiophonics was crip and clear (in English). No snake oil, no BS - pure delivery.
Audiophonics team - keep up the good work - colour me impressed.
Jean Michel P.
Excellente schuko
Très bonne fabrication et serre câble efficace. A l ecoute spectre large et beaucoup d ouverture. Curieusement s avere nettement meilleure que la Bals73 qui équipe le cable Olflex CY 110
Michel l.
exceptionnel
produit d'une excellente qualité d'écoute très aéré et d'une justesse incroyable merci a audiophonics
Stephane N.
SABAJ D5 DAC ES9038Pro Headphone Amplifier Balanced XMOS Altera 32bit 768kHz DSD512 The Sabaj D5 is a solution that acts as both a DAC and a headphone amplifier. It ensures excellent performance, thanks to a careful architecture and components selected for...
Très bon Dac qui pilote une paire d'ampli mono NCORE en mode symétrique.
Beaucoup de détail, très droit, voix superbes.
Je recommande.
Etien K.
GUSTARD LINE-02 Cable HDMI 2.0 I2S OFC Copper Gold Plated 1.5m This HDMI 2.0 Gustard Line-02 cable allows to make I2S connections via HDMI on devices with this connectic. It benefits from a nice design, with OFC copper conductors and pure...
Un bon câble
J'ai deux câbles HDMI différents qui me servaient pour l'informatique et j'obtenais un son assez semblable avec les deux en connectant mon PI2AES à l'entrée I2S de mon DAC R2R, the Musicien Pegasus.
Avec ce câble de Gustard, j'obtiens un son un peu plus clair dans mon système.
Le câble, lui-même, est de très belle facture.
patrick a.
Utilisé sur des bibli un poil montantes tout est devenu meilleur : aigu agréable et basses plus présentes, merci aux précédents commentaires qui m'ont aiguillé. Sur un deuxième système plus pointu face à des Qed révélation un léger manque de subtilité et d'élégance mais très honorable pour le rqp. Câble pas universel s'il en existe ! Mais ramène le sourire dans un système au son montant et basses réservées.
patrick a.
Utilisé en modulation rapport qualité prix exceptionnel , n'est que très très peu distancé par un QED signature 9 fois plus cher.
Jerome V.
TOPPING A90 DISCRETE Discrete Balanced Headphone Amplifier Preamplifier Black Topping returns with the A90 Discrete, an improvement of the previous A90, this time equipped with discrete components. Both a headphone amplifier and a preamplifier, it...
Compte rendu d'utilisation après quatre jours d'utilisation quotidienne.
Le titre résume mon impression auditive.
C'est excellent.
Les basses sont présentes et ne sont pas TROP présentes.
Les voix et les aigus sont aussi bien détaillés mais ne sont pas TROP détaillés (utlisation couplée avec DAC Audio-GD, des Denon POA 6600 et JMR offrande supreme V2)
Le gros avantage du Topping A90 par rapport au PRE 90 est, d'après moi, la possibilité de l'écoute au casque. Mes références à ce propos étant proche du néant, je ne me permettrai pas de définir si c'est mieux ou moins bien mais dans tous les cas, ce que j'ai pu entendre et "au regard" de la joie de mes oreilles, encore une fois, c'est excellent.
Deux petits bémols néanmoins.
L'absence d'un réglage possible des basses et aigus comme, malheureusement, dans de plus en plus de préamplificateurs.
Une télécommande dont la progressivité est surprenante. Cette dernière a tendance à faire augmenter ou diminuer le son par "saut" très important si vous avez le doigt lourd sur elle. Méfiance dans les premiers temps.
Enfin, en bref et en résumé, c'est super bon, nonobstant le prix, que d'aucuns trouveront élevé et d'autres, "pas assez cher mon fils".
Bluffant
Monté sur une barrette Furutech alimentant un système déjà bien soigné en câbles secteurs, le gap est immédiat. Le son est plus propre, plus précis, plus transparent, plus truc, plus machin, bref plus tout. Son prix n'est pas si élevé comparé au gain apporté ou à un bon câble secteur. Très conseillé ++
