Baptiste D.
Ca marche
Marche nickel avec un dongle Shanling UA1 pro, non reconnu au passage sur un smartphone sous android...
PATRICE P.
SOUNDCARE STANDARD Pointes SuperSpikes M8 (Set x4)
Pieds montés sur une paire d'élipson avec des patins Scotch sliders move & protect diamètre 30mm, impeccable la tout...
Il s’agit de mon premier DAC avec la technologie R2R et je ne suis pas déçu.
J’ai essayé cet appareil dans plusieurs...
Customers reviews - There are 21096 reviews.
André D.
boitier pour ampli
tres belle finition ,aspect sobre et agreable ,solide et efficace ,permet de faire un superbe ampli
Dominique P.
Borniers de bonne facture à un tarif raisonnable.
Ces borniers sont un best seller pour le DIY. On le rencontre d'ailleurs aussi sur des matériels commerciaux HDG.
Sébastien D.
OK, RAS
Remplace mon précédent avis. Les perturbations venaient de mon installation.
Cable OK
Andrew M.
RaspTouch I-Sabre V3 - Streamer touch Raspberry Pi & DAC ES9023 Silver The Rasptouch Audiophonics is a network player based on Raspberry Pi with a touch screen for easy use. It is declined here in its version with DAC I-Sabre V3 ES9023, TCXO and...
Quality built unit
Once I saw this unit, I knew I wanted to get it for the bedroom. Tried looking for local North American sellers, but could not find one. Shipping was quite fast and arrived well packed. If you don't have an adapter to go from European to North American socket then order one with your unit. Very sleek design. A design change that I would like to see is, have the ability to adjust the angle of the display. Having all the I/O cable come out the back is also great idea to have a clean setup. I have my original setup using the SmartiPi Touch case which is nice, network cable comes out the side and a few other.
Philippe A.
WM AUDIO BS-108 Banana Plug Gold plated Copper Ø6mm (Pair) These BS-108 banana plugs from WM-Audio in gold plated copper offer very good conductivity and will allow you to offer your speaker cables aesthetic and practical connectors.
Attention au type de vis
Objet conforme à la description.
Justement, il faut bien noter que les vis sont de type TORX et que cela nécessite un tournevis ou une clé que vous n'avez certainement pas chez vous, en tout cas pour cette taille !
(j'ai commandé 6 fiches bananes 4 étaient avec des torx et 2 avec des vis classiques...)
jean pierre T.
Porte bien son nom
Clairement meilleure que sa petite soeur, restitution plus fluide et avec davantage de relief.
Par contre je conseille de soigner l'alimentation , tant au niveau de la partie "dirty" que de la partie "clean".
Je l'ai associée à un RPI B+ et comme OS j'ai installé Archphile.
La restitution est un poil meilleure en mode mpd direct qu'en passant par l'upnp.
Christian N.
Ampoule navette blanc chaud
Excellent article
Ne chauffe pas
Éclairage blanc chaud
Installé sur tuner Sansui TU 317 : résultat parfait
Un peu de soudure pour remplacer les lucioles pour info
Maurice L.
Erreur sur la couleur !
Ma commande a été traitée dans les meilleurs délais et le colis est parvenu dans un parfait état. Cependant, désagréable surprise au déballage : commandé en noir, c'est un modèle argent (Silvery) qui m'a été envoyé.
Noel R.
noel.renee@wanadoo.fr
Les vis fournies avec ces poignées ne sont pas assez longues, il manque environ 5 mm.
Denis L.
Écoute reposante
Équilibre général correct apportant de la matière. Le son est mat et un peu rond pour le grave . Pour le cd j'ai préféré le tornado plus précis.
Bref un peu déçu
Raphael P.
AMPHENOL AG4MCC Male Mini XLR 4 Pins Plug Gold Plated This Mini XLR socket has 4 poles. The contacts are made of a Copper alloy with gold plating, ensuring good conductivity and resistance to oxidation.
Parfait pour recâbler un casque AKG
Utilisé pour remplacer la fiche de mon casque AKG Q701 pour le recâbler en symétrique. Tout était nickel, rien à signaler, c'est exactement le même format que le connecteur d'origine, il suffit de se débarrasser des rondelles.
Belle finition en laiton Massif.
Grace à mes reliquats de cours de physique, je n'en ai mis que 3 par enceinte (Colonnes de 37kg).
Deux devant et une derrière, bien centrée, et là sur 3 points, impossible que ce soit bancal.
J'ai vissé à fond le petit cône, avec une goutte de frein filet et c'est nickel.
Au point de vue rendu, les basses sont bien dégraissées et plus tendues.
Bonnet d'âne pour le fabricant qui aurait pu mettre les vis, ça évite de passer 1 heure à Leroy Merlin pour trouver le bon modéle ( 0,15cts les 6 ).
Claude B.
On comprend aisément que le Raspberry Pi fasse l'économie de fonctions telles qu'une prise SATA ou une sortie audio numérique afin de limiter les coûts. Ce qui est en revanche plus contestable, c'est l'absence totale de gestion de l'alimentation, conduisant l'utilisateur à devoir débrancher brutalement l'adaptateursecteur lorsqu'il perd la main sur le soft et qu'un reboot s'avère nécessaire. Ce petit module, quasiment indispensable pour toute réalisation DIY, vient corriger cette grave lacune en proposant une gestion hard et soft de l'alimentation. Le montage est aisé, les scripts à ajouter à Raspbian sont disponibles sur le forum, et l'ensemble fonctionne parfaitement. Un grand merci à Audiophonics pour ce très utile module.
Thomas D.
Bon son mais instable en USB et le driver XMOS n'est pas signé
J'utilise ce DAC depuis plusieurs jours avec sa sortie casque.
Il fonctionne très bien en coaxial ET en optique (j'ai testé les deux branchements sur un lecteur de CD).
En revanche, pour l'utiliser en USB,sur un PC, deux possibilités :
- soit le faire reconnaître par Asio4all, mais le format DSD ne sera pas reconnu
- soit (pour profiter du DSD) installer le driver XMOS fourni par Audiophonics. Mais ce driver n'est pas signé (= pas reconnu officiellement par Microsoft) et il faut donc désactiver le contrôle des pilotes et le Safety Boot de Windows 10 dans le BIOS. On trouve la procédure sur le web. Ce qui n'est pas du tout pratique.
Par ailleurs, en USB, Foobar étant configuré correctement avec le composant foo-sacd, la lecture de DSD fonctionne une fois sur deux.
Très instable.
Dominique V.
Le top dans 2 boîtes d'alumettes
Révolutionnaire !
Est ce que les plus jeunes se rendent compte de la prouesse technique? Pas de distorsion, bande passante linéaire. Consommation insignifiante. Température proche de 25 degrés. Impensable il y a 20 ans...
Le top! Et un site au taquet.
maurice b.
Belle réalisation
Très belle réalisation au point de vue technique.
maurice b.
Bon son mais unitilable en entrée USB et optique drivers inexistants
J'utilise cet appareil depuis fin aout, le son est très bon comparable à un dac 3d lab nano 10 x plus cher, mais malheureusement inexploitable si vous vous voulez utiliser l'entrée USB ou Optique.
C'est donc uniquement par l'entrée SPDIF coaxial que vous pouvez utiliser ce produit. Pas de réponse depuis 6 jours du sav d'audiophonics ! J'ai donc envoyé un mail au constructeur qui m'a envoyé sous huit heures un driver générique (XMOS-Stereo-USB-Audio-Class2-Driver-3079_v2.26.0 for WIN7) accompagné du message suivant (Thanks for your support ,and I am sorry to take any inconvience to you. We will have supplied offica driver from XMOS company and can get it in coming days.
I send you a free driver for testing firstly . En attendant que xmos veuille bien mettre au point ce driver (au moins déjà six mois de commercialisation et toujours pas de driver, on se fout de la gueule du monde, Malheureusement l'installation sur 3 ordinateurs différents ( 2 sous win 10 et un sous win7 n'ont pas permis de rendre visible ce Dac au demeurant excellent concernant ses prestations sonnores sous l'entrée SPDIF coaxial. Donc Wait & See ( not too much time ) sinon retour à l'expéditeur . Mention 0 pour le SAV audiophonics !
Emmanuel G.
EXTRA
Un excellent câble qui a remplacé une paire de MOGAMI 2497 avec brio sur mon système tout ATOLL.
Détail - présence - équilibre - neutralité - tout y est à un prix défiant la concurrence - et le jaune est si beau ………!
Eugen M.
Bon DAC avec AMANERO
J'ai combiné ce DAC avec un AMANERO pour avoir un DAC pour mon ordinateur. Il fonctionne très bien et le son est très rond. Il manque un rien dans les hautes fréquences mais rien de grâve.
ERic D.
AUDIO-GD MASTER 1 Pure Class A RCA XLR ACSS Balanced Preamplifier With this Master-1, Audio-GD offers one of the best preamplifiers in the world, integrating the quintessence of audio technolohy KEY POINTS: Symmetrical design Class...
Un excellent préampli.
Je ne rédige pas souvent d'avis sur les produits que j'achète. Je fais une exception cependant pour ce préampli. Le rapport prix/performance est simplement imbattable. J'ai eu des préamplis valant trois fois le prix de cet Audio GD et il est largement à la hauteur. Le temps de chauffe est non-négligeable, mais une fois ce temps passé, la performance est au rendez-vous que ce soit sur la dynamique, l'image ou les timbres. Top produit.
Herilanja Z.
Super Produit
L appareil est vraiment vendu comme c etait decrit. Je suis tres content et satisfait du produit. Tuot fonctionne.
Mais comme même il y a un petit defaut, c est que le boutton du volume n est pas bien fixé: comme boutton à joystick. Est ce que c est normale?
Axel P.
Facile à installer
Excellent interface numérique. Je l'utilise sur un Raspberry Pi 3 B+. L'installation est d'une facilité déconcertante.
Je n'ai pas fait de test audio comparatif mais aux premières écoutes, la sortie optique se comporte bien.
J'utilise également le récepteur infrarouge pour piloter une Squeezeplay sous piCorePlayer avec une télécommande Logitech Harmony paramétrée comme une télécommande de Squeezebox Touch. Pour information, le récepteur utilise le port GPIO 26.
Très content du produit et également d'Audiophonics qui a répondu rapidement à ma question.
Je referai cet achat pour un autre Raspberry avec le même usage.
Pierre B.
Super rapport qualité prix
Produit très pro, mise en oeuvre ultra simple malgré l'absence totale de toute documentation.
Je l'ai passé au banc de test impressionnant, bande passante mesurée 5 Hz, 300 KHz sans atténuation, signaux carrés propres de 20 à 50 KHz, signe d'une bonne attaque de note. Un bonus le contrôleur de volume, très précis, est aussi un pré_ampli puisqu'il offre un gain de 3, largement suffisant avec les sources modernes.
A l'écoute test confirmé, aucune limitation en bande passante, grave dense et tenu, aigu fluide et jamais agressif parfait, en appuyant sur le bouton rotatif on a la fonction mute du haut de gamme.
Quelques détails qui lui coûte une étoile :
- Pas de connecteur à visser ou à souder sur la carte alors que des emplacements sont prévu à cet effet.
- Pas d'écrou fourni pour le bouton rotatif qui n'est pas un standard..
- Aucune notice, ni entretoise fournie avec le produit bien que figurant sur la photo.
- Moins grave le pas du potentiomètre n'est pas changeable, je pense que c'est livré avec un pas de 0,5 dB ?
Pierre
arnaud m.
Amplificateur acheté pour mettre au repos mon "radiateur à tubes " durant la canicule !
La première écoute m'a parue très fade par rapport aux tubes. Mais après un mois de rodage ( ou d'accoutumance à ce nouveau son?) le résultat est correct avec un son qui remplit bien ma pièce d'ecoute.
le seul problème rencontré est une connexion Bluetooth très instable avec mon mac bookpro donc pas utilisable dans ces conditions. Pas de problème avec mes autres appareils Bluetooth.
Fernando R.
Fernando Rocha
Product exactly the same as advertised
beau son
Cette interface devait rejoindre un système audio couplé à mon ordinateur de bureau, mais après écoute elle a pris place sur mon système haut rendement car la conversion est fine et aérée, cela aurait été dommage de ne pas profiter de ses capacités sur mes fichiers flac en 96 khz, elle tient la comparaison avec mon autre interface GUSTARD U12. Évidemment il faut une alimentation séparée pour découvrir toutes ses qualités pour éliminer les bruits usb; mais aussi , dans mon cas, car l'alimentation 5 V de mon streamer semble incapable de fournir assez de courant sur sa sortie usb pour une émulation de cette interface. C'est un très bon rapport qualité prix.
Olivier D.
il tourne sur un ampli de 2 x 200w rms pour protéger mes enceintes de 350w rms, après les tests, il coupe à partir de 1 volt.
mon ampli plein régime = aucun déclenchement intempestif !
en plus reçu en 3 jours !
Merci Audiophonics !
Robert B.
Very warm and detailed dac
I've seen the Hans Beekhuyzen video and want to see of this dac 9038 was even better than my 9018 Audiophonics
Lower Bass is warmer, midbass preciser, mids are more clear and high's could be a tiny more crisp but all details are there. Maybe my amplifier is never aggressive.
The 9038 is never to sharp no S sounds en very good sounding.
Both card works good with Picoreplayer 3.5.0
The eq in Pcp can be used for a tasteful treble.
It was a little upgrade with instead of the 9018.
Laurent V.
Très bon produit en remplacement de l'origine. Tellement plus naturel. J'ai d'ailleurs de bien meilleurs résultats avec l'ajout d'un fusible argent (rhodium serait surement top aussi) en remplacement du fusible l'origine qui bloquait le potentiel de ce produit et au final de l'alimentation du produit en question. C'était tellement évident à l'écoute.
Laurent V.
J'ai la version gold, la version rhodium et la version rhodium et il est clair que ce modèle va bcp plus loin en terme de naturel et rapidité (pas de traînage) mais aussi en terme de micro-informations. C'est la deuxième que j'achète afin de séparer mes sources et mes amplifications. Je les utilisent dans une gouttière Legrand avec des lignes séparées.
Naturel, transparent et détaillé
Contrairement aux modèles beaucoup plus chers des autres marques, ces fiches sont en pur cuivre.
La restitution est extrêmement transparente, détaillée et nuancée. On retrouve la douceur et le soyeux que l'on perd avec les modèles en laiton.
Les timbres sont superbes, il y a une infinité de micro-détails même au niveau des aigus qui sont très diversifiés. Les voix sont charnelles sans être charnues, les bois et les cuivres sont pleins, riches et soyeux, les cymbales ont une très grande palette harmonique et les basses sont profondes et très diversifiées.
Il est étonnant que la plupart des autres marques proposent des conducteurs plaqués avec des métaux précieux mais dont le corps est en simple laiton.
Bruce B.
JUSTBOOM Digital player Raspberry Pi W Zero Hat Amp Zero FDA TAS5756 with Volumio A full digital amplifier (FDA) and network reader based on raspberry Pi zero. Hyper compact and modular format according to your desires.
Le top de la transparence à ce prix
Excellent kit DIY de mon point de vue. Côté transparence du FDA, surclasse mon précédent équipement iEast M30+Alientec D8 (je stream en Airplay).
Pour les cables, il faut par contre du 1,5mm2 max et des petits doigts !-)
Donne une grosse envie de multiroom sur le concept en tout cas.
Pour info, permet de sonoriser sans problème une pièce de 20m2, avec 1.5W de consommation seulement. Peut même être alimenter par une batterie de recharge smartphone pour les puristes ou les nomades
Claude B.
Discret petit boitier utilisable pour divers projets DIY
Je l'ai détourné pour donner un joli écrin à une box domotique DIY, qui comprend un Raspberry Pi, un HAT RTC, une carte Razberry dont j'ai déporté l'antenne, et la gestion d'alim audiophonics. Il reste encore suffisamment de place dans ce petit boitier pour y ajouter un disque de stockage de données SSD. Dommage que le modèle sans marquage ne soit plus dispo, cela aurait été parfait. Mais bon...
Claude B.
Effacez mon commentaire précédent, svp.
Au temps pour moi, je viens de m'apercevoir que le petit boitier plastique qui entoure le connecteur micro SD femelle peut être retiré pour monter la carte dans le boitier alu DIY pour Raspberry Pi 3 / I-DAC. Mon commentaire précédent est donc nul et non avenu. 5 étoiles pour cette rallonge qui évite de démonter le boitier pour changer de carte SD.
Claude B.
Incompatible avec boitier aluminium pour Raspberry Pi 3 / I-DAC pour lecteur réseau audio
Attention, cette rallonge est compatible avec le boîtier Raspdac mais PAS vec le boitier aluminium DIY pour Raspberry Pi 3 / I-DAC pour lecteur réseau audio, la fente n'étant pas assez haute pour que la carte SD soit accessible. Cela mériterait d'être noté dans la description du produit.
vannarith P.
ELECAUDIO US-24G Prise Secteur USA NEMA 5-15 plaqué Or Ø16.5mm Le connecteur de référence US-24G se distingue au premier coup d'œil par son corps en nylon noir à la finition impeccable et aux proportions idéales.
prise iec et nema
Super servive,bon produits,
mais ne fais pas la meme connerie que moi pour livraison express par TNT de M...
Ils m'ont pas livre chez moi et ils ont le culot de m'envoyer un sms comme quoi je suis absent de chez moi,et les produits sont deposes chez un marchand(point relai).
Svp monsieur,deconseillez vos clients a envoyer par TNT(tres nul transport)
Produit étonnant et d'une efficacité redoutable.
Comparé à mon DAC Magic plus dopé d'une alimentation de Pardo , après moulte comparaison, je n'ai pas trouvé de différences significatives. Il est vrai que le récepteur SMSL B1 est équipé d'un dac de grande qualité. Produit d'une rare qualité à conseiller sans réserve.
Philippe R.
Fonctionne aussi en 12 V continu, en alimentant entre la borne gauche du bornier AC IN et la masse
Pascal l.
Excellente soudure
Très bon produit, facilite le travail. Pour moi la meilleure soudure à l'argent.
Jean-Pierre B.
Un petit pavé dans la marre ...
... des sources numériques.
Après lecture de quelques retours d'expériences (ex. sur Headfonia : X10T Vs AK SE100) j'ai décidé d'en essayer un sur mon système numérique (actif, débafflé et entièrement sur batteries Optima).
Et bien, effectivement, et c'est un bon signe, après le premier morceau testé j'ai laissé jouer et écouté l'intégralité du disque tellement c'était agréable.
Ce transport numérique me délivre plus d'informations, d'ambiances des salles (que mon transport CD ou que la sortie numérique de mon Fiio X5), tout en conservant le côté naturel, l'étendue des octaves, la dynamique...
J'ai fait ces écoutes sur la sortie S/Pdif (avec un câble : jack VIABLUE T6s/câble 75ohm argenté PTFE/ rca Argent) pour comparer ce qui est comparable.
Ce petit pavé a accepté mes 2 cartes SD de 256 Go, ce qui fait quand même 1/2 Terra de stockag, soit environ 700 Cds en WAV, revers de la médaille l'écran est assez riquiqui et les touches sont moins pratiques qu'une roue pour se balader dans les fichiers.
Il est pas pratique, mais il a quand même 5 étoiles pour le plaisir qu'il procure...
Jean-Pierre Bachelier / Artisanat Acoustique
Jean Claude A.
Indéniablement,
un des meilleurs DAC de la catégorie
résultat bien au delà de mes espérances : utilisé à la place de l'entrée USB de mon ampli ,a transfiguré le DAC du Ra 1592 !
XDUOO TA-02 Tube Headphone Amplifier class A Hybrid The xDuoo TA-02 headphone amplifier is a hybrid design of two Tubes driver 6JI (5654) with a Buffer transistor class A.
Ne pas oublier d'indiquer dans le descriptif qu'un adaptateur secteur USA/France est nécessaire...
Eric D.
Super cable
Le gain est direct....
Graves propres . aigus précis et agréable,bon medium........que dire de plus.....
Jackies C.
musical mais pas totalement fonctionnel
J'en ai pris deux pensant pouvoir faire évoluer mon système tri phonique, diviser les canaux avec un filtrage numérique et utiliser les deux DAC pour envoyer sur deux ampli analogiques. Windows 10 ne gère qu'une seule carte son à la fois, Vous pouvez essayer tous les logiciels comme foobar et autres, c'est peine perdue.
je viens de rebrancher mon petit audiophonics U Sabre V2. Il fait au moins aussi bien sur mes Cabasse Sampan. De plus il dispose d'une sortie jack que j'utilise pour la section caisson basse (DIY clipschorn). Je vais prendre le minidsp 4xHD pour gérer le filtrage actif et l'egalisation.
A suivre...
Audiophonics société sérieuse
Je ne vais pas donner mon avis sur ce filtre mais louer le sérieux et le professionnalisme d'Audiophonics.
En effet, j'avais commandé ce filtre et en allant réceptionner ma commande, ( j'habite Bordeaux) Mr Aubert m'a expliqué qu'avec mon DAC Audio-GD je n'en avait pas besoin car des circuits de ce Dac faisaient le travail de filtrage.
C'est honnête et sérieux comme démarche. Ils m'ont remboursé de suite.
Bravo
Bertesi G.
Meglio prima,MA MOLTO MEGLIO PRIMA.
Sempre di ottima fattura,ma l'aumento del prezzo non è nelle aspettative, prima l'alluminio era lucido,ora è trattato e opaco,esteticamente piu' bella prima e piu' pesante dando l'impressione di robustezza,Togliendo materiale + guadagno -peso, prima la iec la davano gratuitamente e i piedini in gomma da avvitare sono stati sostituiti con 4 adesivi in silicone. 10€ in piu' per avere meno,Complimenti!!!
Olivier R.
un upgrade sans compromis
Si la possibilité vous est offerte de changer les amplis op de votre DAC par exemple , ne vous privez pas !
on passe à un niveau de dynamique et de transparence ( séparation des instruments ) supérieur .
installés dans mon Maverick Tube Magic D1 , le résultat obtenu le place au niveau de matériel bien plus onéreux ( upgrade de trois amplis op doubles compris !! )
neil c.
Amazing
Superb. Significantly better than the Pi-Dac + it replaces, and I thought that was pretty good.
Éric M.
Excellent rapport Q/P
Cet ampli est utilisé en écoute de proximité dans une installation de bureau, en compagnie d'une paire de Mission 731 Pro et d'une SqueezeBox 3 connectée en optique.
Ce petit ampli n'a pas à rougir de ses prestations audio (réponse linéaire, grave propre, medium aigu plutôt naturels). Ramené à son tarif actuel, soit 99 €, on peut même le qualifier d'excellente affaire.
