John T.
Brilliant device!
Siegfried F.
Ivan S.
IvanS
Customers reviews - There are 19270 reviews.
gabriel m.
Très bien !
J'aurais vraiment aimé voir quelques graphes dans la description !
Sinon vraiment pas mal. J'ai monté un 2.1 avec du matos de récup : deux enceintes 30w JVC et un sub Samsung. Très content du résultat. Il faut juste penser à l'alimentation non fournie. Je n'ai pas réussi à me connecter au bluetooth mais je n'ai pas acheté pour ça alors, attention si c'est important pour vous !
Le code pour l'appairage Bluetooth est : 0123
Laurent M.
SHUGUANG 12AX7B / ECC83 Amplification Tube (Unit) This Shuguang 12AX7B amplifier tube will allow you to replace an equivalent model but also the 12AX7, ECC83 and 12AX7-T tubes or an integration on a DIY creation. With a double...
Parfaites
Lampes de qualités et contrôlées.
Livraison rapides et très bien protégée.
Merci.
Jozef Š.
Great sound upgrade, NOT 75 Ohm !!!
Excellent build quality, fine sound upgrade for interconnection type...but it is not 75 Ohm cable like was in description before my order...well not so suitable for digital coax type cable construction.
Jozef Š.
Unusable for coaxial cable
Excellent build quality but not suitable for coaxial cable.
Stunning cable
I run this cable for amplifier, CD and conditioner unit. It is sonically the most gorgeous I’ve used bettering Nordost by a long way.
I have it terminated with solid silver IEC’s and UK plugs and again, sound is stunning, especially the mid range depth and realism.
Stunning cable
I have used many €20-€30 p/m cables and so glad I jumped to this price level and even more so that the sonic improvements have been worth every penny.
Naturally, the first few weeks are a little light and muddy in the bass, but other out of the box includes more air around vocals abs terrific timing.
A very worthwhile cable upgrade.
Excellent cable
I changed out a V1 Nordost Blue Heaven RCA to a self made cable and the results were astonishing. It makes one wonder why you pay silly money for a brand with good marketing when you can make as good, or better, for a fraction of the costs.
François D.
Préampli McIntosh C2300
Très bonnes lampes sur la partie ligne du préampli C2300. La scène est plus large qu'avec les tubes d'origine avec un très bon medium et des graves qui se tiennent.
Roman R.
Compared this cable with the stock cable that goes with Marantz PM-8006 and instantly heard tighter bass. No soldering. Connectors are also Elecaudio.
Benoit s.
excellent!
je viens de d'installer ces fiches banane sur un câble audioquest relativement bas de gamme et je suis très agréablement surpris par le résultat sonore obtenu. La différence est plus que subtil!
La finition est certes un peu "cheap" mais pour celui qui cherche avant tout un nette gain sonore sans se ruiner c'est parfait
Juan A.
Bon appareil, juste ce dont j'avais besoin.
L'article a été reçu très rapidement et très bien emballé comme c'est la coutume d'Audiophonics. Le switch est solide, pour sa petite taille il sent lourd dans la main, il est bien construit. Il fonctionne correctement et il n'y a pas de détérioration audible du son. Cet appareil me permet de basculer entre mes deux paires d'enceintes confortablement sans avoir à connecter et déconnecter constamment des câbles. Je ne sais pas si les polarités sont inversées comme mentionné précédemment, d'après ce que j'ai pu trouver sur le site Web du fabricant, à partir de 2020, cet appareil a subi quelques petites modifications matérielles et logicielles. Tous les boutons de la télécommande sont opérationnels, certains ne servent qu'à contrôler d'autres unités et il y a un bouton pour régler la luminosité de l'écran. En résumé je suis très content de ce petit appareil qui me facilite la vie.
Y1-G Gold plated Spade Ø5.5mm (Set x4) Inclined spade plugs with screw fixing compatible with cables up to ⌀5mm in diameter. A brass body with gold plating make it an excellent conductor to convey the musical signal.
Bon Produit
Bon produit, mais je préfère les fiches banane, car avec les fourches le serrage n'est pas suffisant safe dans mon cas.
Louis F.
boucle de masse
Je suis un peu déçu par cette alimentation malgré tout le soin apporté.
En effet il y a un problème de conception, la masse de la sortie est connectée à la terre.
Cela peut créer une grande boucle de masse si un autre element a aussi la masse reliée à la terre.
Ce qui est mon cas malheureusement.
Je vais voir ce que je peux faire pour réparer le problème mais après démontage cela va être difficile.
Le filtre secteur inclus est aussi assez faible.
philippe L.
LED
sur le modèle que j'ai reçu, les led d’éclairage sont montées en parallèles après un régulateur et un redresseur, elles éclairent normalement a partir d'un tension de 5v ac.
Antoine B.
IFI AUDIO NOVA Power Cable OFHC Copper Gold Plated Shielded 1.8m The iFi Audio Nova power cable offers excellent performance to provide your audio system with a clean and stable electrical signal. Its structure is totally symmetrical. It uses...
La qualité de fabrication est impressionnante (attention câble de gros diamètre très lourd). Les résultats sonores auxquelles je ne croyais qu’à moitié en changeant mon câble secteur sont évidents. Excellent rapport qualité prix surtout en considérant les 1,8 m
Yannick M.
Fonctionne parfaitement sous Windows 10 avec un Splitter TRRS ainsi qu'un câble TRRS pour pouvoir le positionner à l'endroit voulu.
Je l'ai utilisé avec son fichier de calibration sous Room Eq Wizard pour calibrer mes enceinte. Ca fait parfaitement le job pour pas chère.
Excellentes. RPQ imbattable pour OR + Téflon
Ce que j'aime dans ces RCA chassis, c'est qu'il n'y a pas de rondelle-languette pour souder la masse. C'est sur le corps en massif.
ça c'est une bonne masse pour peut que l'on étame la RCA avant, sans être montée; puis d'étamer le fil ET ensuite souder l'ensemble avec un nouvelle apport de soudure. Pas le temps de chauffer.
Ensuite, le corps assez long permet une bonne prise pour les câbles qui y seront branchés.
Isolation avec rondelle qui font le taf.
Bref, je vais en reprendre une paire d'avance tiens ;)
Andoni G.
Big and solid
I used them for 2 big hifi racks. They are big.
Andoni G.
Perfect for a little subwoofer, they are small, I used them for isolate a SVS 1000 sub
Andoni G.
Feel and looks perfect
Solid and good feeling, I bought it adviced by audiophonic.
Gérard R.
SHUGUANG KT66 Tetrodes Power Tubes (Matched Quad) These Shuguang KT66 tubes are power tetrodes, ideal for HiFi design or as replacements for similar models. They are sold factory matched by four units.
EXCELLENT TUBE
Sur un ampli tel le Van der Veen UL40S, le son est top. A recommander sans réserve
Gérard R.
belle découverte
Je cherchais à faire un petit sub pour compléter un LB dans un volume réduit. Dans 22 litres, soit une caisse de 33cm au cube, ce petit haut parleur remplit bien son office en créant un soubassement convaincant. Alimenté par un ampli transistors de 30 watts et filtré actif à 80Hz en 12 dB/octave, çà fait le job à niveau confortable 80/85dBSPL.
Marin M.
Wonderful DAC/AMP! As DAC itself, with signal coming from cd transport it cannot be differentiated from PCM63 or PCM1701 cd players, except in the highs. Headphone amp is also wonderful. It is very warm and sound very natural. I compare it with Topping L30 and the Audio-GD one sounds more pleasant and not that sterile. Only drawback is the highs. As non-oversampling dac, they are rolled off, starting from arround 10-11 kHz. I tried to pass the signal trough DSD, and it then shows the full range of frequencies, but the processing from PCM to DSD that the PC is making does not sounds as much pleasing as the native PCM. I had friends that are 45 years old and above, and they cannot hear the rolled off higs. I can hear it, but for me it is plus for long listening sessions, because it does not bring fatigue.
Eetu B.
Mediocre amplifier board
First boards to arrive were missing components, but thanks to Audiophonics' good support, I was quickly sent new boards. The boards suited well for my project and they sounded decent. The layout and build quality of the PCB is good and most of the parts were genuine parts, altho some regulators seemed to be refurbished. Also I would have wished that more data about the boards had been sent with them. (Testing results etc.) The boards were in a lot of use for about a year, until on the other board, the relay for selecting signal input, died. For the price they are decent amplifiers,
Jacques E.
Fabuleux
J'ai utilisé ce condensateur dans une liaison numérique avant un transfo de sortie ,en lieu et place d'un modèle déjà de qualité (MKP) et bien tout est devenu plus doux mais attention sans perte de définition, fluidité et naturel, voila...
Albert L.
Performance de haut niveau
Me permet d’écouter les meilleurs formats audio diffusés sur internet, mais aussi d’apprécier l’authenticité des enregistrements sur support à partir d’un PC. Cela dit, ce n’est certes pas avec le câble USB fourni que la prestation musicale est irréprochable. Aucune cohérence entre cet accessoire standard et le logo « HI-RES AUDIO » qu’arbore le boîtier. C’est une supercherie. Il a fallu le remplacer sans attendre par un câble USB audio digne de cet équipement. Le câble : « Viablue KR-2 Silver Câble USB-A Male/USB-B » acquis pour l’occasion est l’accessoire complémentaire idéal pour un rendu audio d’excellente qualité. Les trois sorties audio permettent l’utilisation sur un large éventail de système et d’installation, ce qui, en complément d’un PC portable rend la diffusion de la musique polyvalente, avec la qualité, à condition toutefois de s’équiper des câbles audio adéquats. Conçu pour, ou à partir de Windows 10, l’installation est automatique dès la détection du périphérique.
CHRISTOPHE D.
Rapport qualité/prix imbattable!
Très bon produit, fonctionne parfaitement avec le dtoverlay=hifiberry-digi-pro
J'utilise une configuration similaire à Moode Audio (upmpdcli+mpd) pour jouer du Qobuz depuis l'appli BubbleUPNP et cela fonctionne parfaitement.
Très bon timing, pas de problème contrairement à mes DAC USB Asynchrones ou pas...
marc m.
qualité audio top mais doute sur la durée de vie
Très content de la qualité audio.
Fonctionne très bien sous Linux/Ubuntu.
Par contre le premier que j'ai acheté viens de griller au bout de 3 ans et demi.
J'en ai quand même commandé un autre.
Andre R.
SABAJ D5 DAC ES9038Pro Headphone Amplifier Balanced XMOS Altera 32bit 768kHz DSD512 The Sabaj D5 is a solution that acts as both a DAC and a headphone amplifier. It ensures excellent performance, thanks to a careful architecture and components selected for...
Excellent resultat d'écoute
Un DAC qui transpire la qualité de fabrication. Il n'est pas en reste pour les résultats sonores.
Merci pour le conseil.
J'ai quelques difficultés pour paramétrer FOOBAR pour la lecture des DSD en direct (sans passage en PCM). Avez vous un tutoriel.
david a.
ATHOM
EXPÉDITION RAPIDE ENVOI DES COLIS SOIGNÉ ! JE RESTE FIDELE CHEZ AUDIOPHONICS .
Alain c.
bon produit, mais cable alimentation trop court !
bon produit que une très bonne sonorité, mais, malgré ceci j'ai constaté
que le bloc alimentation, n'a pas interrupteur en amont pour l’éteindre
et ce bloc reste en permanent sous tension, raccordé au secteur 220 v.
sa LED rouge est aussi désagréable, et difficile a masquer, car le câble
qui fait seulement 1.20 est bien trop court.
si l'on n'a pas une prise a proximité immédiate il faut faire l'achat
en supplément, d'une rallonge avec interrupteur pour couper l'alimentation, électrique du transformateur d'alimentation du
pré ampli.!
Jean-Pierre G.
Top.
Je viens de recevoir mon câble. Livraison super rapide.
Cable de qualité.
Allez y les yeux fermés.
Vous ne serez pas déçu
My reviews of UcD180HG HxR module
https://www.audiosciencereview.com/forum/index.php?threads/hypex-ucd180hg-hxr-amplifier-module-analysis-and-review.27852/
Olivier P.
Volume Control Board LED Display Remote Control This small volume control module incorporates a red LED display, indicating the sound level. It can be controlled remotely by its built-in IR receiver and the remote control...
controle de volume à télécommande
Ce produit mérite bien 4 étoiles, car la qualité et le fonctionnement sont parfaits, la télécommande n'a pas besoin d'etre en face du récepteur pour agir. Pas de perte pas de temps mort.
david d.
amazing
Great clarity, imaging, tonality, dynamics. It improved my sound by a big margin. I wil buy a second unit soon.
Bertrand A.
Ce DAC est vraiment bon ! surtout si on remplace les 3 AOPs d'origine par des AOPs doubles BURR BROWN OPA627.
J'ai fait l'erreur de me fier à l'avis précédent :
Une DEXA discrete est un AOP simple ; en sortie de ce DAC cela pose un problème de niveau de sortie...
Serge L.
SHANLING UA2 Balanced DAC USB-C ES9038Q2M 768Khz DSD512 Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or you simply want to improve the...
DAC au top
Un petit DAC fort joli, très pratique et polyvalent mais grand par le son. Fonctionne parfaitement sur MacOs Monterey (pas évident), le son au casque (je ne fais pas la liste) et avec les HP (Iloud Micro Monitor) est parfait, bon rendu à fort volume comme à bas volume.
Parfait pour une utilisation Hifi ou professionnelle (studio) car très détaillé et toutes les fréquences passent à merveille. Je recommande vivement.
Je n'ai pas testé la sortie symétrique ni sur Iphone mais je ne pense que cela soit moins bon.
Alain M.
Excellent résultat avec enceintes large bande
Utilisé pour corriger la courbe d'enceintes TQWT avec HP Supravox large bande type RTF215 Résultat bluffant après seulement quelques mesures avec logiciel REW. Correction et transfert vers le minidsp facile moyennant un nécessire apprentissage. Bien plus efficace que n'importe quel filtre passif. Je recommande.
Dorian L.
Efficacité impressionnante
J'ai acheté ce filtre pour l'installer sur le câble d'alimentation de mes enceintes PC et le résultat est là. Mes enceintes étaient tout simplement inutilisables car les parasites couvraient le moindre son qui aurait pu en sortir, après installation de ce filtre je n'entends des parasites qu'à volume très très faible et il faut tendre l'oreille.
Allez y les yeux fermés surtout pour ce prix là !!
Joaquim Y.
Souffle pendant les silences
Ampli bien fini sur le plan esthétique . Je ne suis clairement pas audiophile mais, comme indiqué dans la description, cet ampli présente un souffle notable pendant les silences. La mention n'était cependant pas présente sur le site lorsque j'ai acheté cet article en 2018. À éviter si vous cherchez un tant soit peu un confort d'écoute. Je m'en suis rendu compte en le comparant à un autre FDA. Étonnant que ce produit jouisse d'une telle notoriété avec un tel défaut.
Dans la même catégorie le SMSL AD-18 est bien plus agréable (bien qu'il faille changer l'alimentation qui siffle).
Nicolas D.
Fiches banane Viborg
Très bon produit. Remplaces des fiches à serrage bas de gamme. Celle-ci tiennent bien dans les bornes des ampli QSC. Pas de modification du son, elle sont transparente et c'est parfait !
Frederic p.
Waouh ..!!
Franchement je ne pensais pas que ce câble rj45 puisse m’apporter une différence sonore..!!
Malheureusement j’étais surpris quasiment de suite un gain en clarté et en dynamique .
Une très très belle fabrication dommage qu’il soit pas équipé du VIABLUE EP-7S
Qui a l’air de meilleure qualité que le viable Ep équipe avec ce câble rj45
Franchement a ce prix là il a même pas à réfléchir ..
Henri c.
bonne qualitée
je l'ai depuis peu, je trouve la qualité audio bonne , il se synchronise
bien ,la qualité de fabrication est bonne , l'affichage est un plus agréable , a ce prix c'est une bonne affaire.
Owen M.
AUDIOPHONICS HPA-T400ET Power Amplifier Class D 3 Channels Purifi 1ET400A 3x400W 4 Ohm We are proud to offer you the AUDIOPHONICS HPA-T400ET, a 3 way class D power amplifier based on three PURIFI 1ET400A modules. This ready-to-use version is aimed at audiophiles...
Fantastic
This thing is crazy. I've never in my life heard a quieter amplifier. Well, the Bryston 6B SST I had was pretty close. But that was a $6000 amplifier (and until now was the best power amp I've ever owned). Holding my ear next to the speakers, the only thing I can hear is a very quiet ticking in the ribbon tweeter from (what I assume) is EM noise in the environment (speakers are Elac Carina). That ticking is inaudible from 5 cm away. The typical amp hum is absolutely non-existent. Listening the music (Beck's Sea Change on SACD) is enlightening. I haven't upgraded my surrounds, which are active Tannoy Reveal 6D speakers. Listening with my ear next to the speaker, and the Tannoys have a distinct sound, while the Purifi-driven Elacs sound like... nothing. Just incredible. I've never heard, in my 20 years as an audiophile, a more neutral speaker+amp combination.
Also, the packaging was exceptional, and if you're a minimalist like me, the amp is just glorious. Sturdy, clean design. Feels great in the hand. Binding posts are so sexy I wish I had a reason to use them more. A flawless amp, and worth every cent. Congratulations Audiophonics (and Purifi)!
* One negative: The courier left the package outside my door. This is not acceptable for a 2k€ item. I mentioned this to Audiophonics, and they replied that they'd report it to the courier. Naturally, this is not entirely their fault, so I didn't consider it when rating the amp.
Patrice S.
Quelle surprise !!!
Alors, marche ou marche pas les cables secteurs ? Il y a tant d'avis opposés sur le sujet que je tente régulièrement l'expérience avec du matériel à prix raisonnable.
J'ai donc acheté 2m de ce CS-361B et j'ai équipé deux câbles de 1m avec des connecteurs de la même marque (PS et PI 24).
Je possède à ce jour 1 cable CS-331B, 1 CS-321B et 2 CS-361B, branchés sur une barrette secteur Wireworld Matrix II. Mon matériel audio est tout ATOLL (série des 100) et enceintes Récital Audio modèle Illumine (au passage excellentes enceintes au RPQ très très bon).
EH BIEN QUOI QU'ON EN DISE ÇA MARCHE SUR MON SYSTÈME !!! Mais en fonction des câbles et leur emplacement sur la barette c'est parfois si subtile que je pense que placebo n'est pas loin. En revanche le CS-361B en alimentation de la barrette a eu un effet foudroyant...d'un coup et pas au bout de 40h00, le son s'est libéré, il s'est éclairci, les notes se détachent nettement et finissent lentement, la scène sonore a gagné en profondeur, dans les orchestre les groupes d'instruments sont plus lisibles avec un meilleur positionnement dans l'espace, il est précis, mais attention aux mauvais enregistrements, il laisse tout passer dans mon cas. Ah oui, les masses ont bien évidemment étaient contrôlées avant branchement.
J'ai essayé de nombreuses combinaisons avec mes câbles mais la plus flagrante, et de loint, est de positionner le CS-CS-361B en entrée de la barrette. A ce jour mon système fonctionne avec CS-361B entrée barette et ampli, CS-321B sur le streamer et le CD passera en CS-321B car de mon système j'élimine le CS-331B pas assez dynamique et limitant les médiums et aigus dans mon cas. JE SUIS RAVI, le résultat sonore me convient et cela par des investissements progressifs et peux coûteux au regard du résultat.
Je trouve ce cable assez souple, malgré son diamètre, et pour donner une idée de l'encombrement, il faut un espace minimum de 11cm entre le mur et le meuble accueillant le matériel.
Pour finir je ne peux que conseiller ce câble en alimentation d'une barrette. Pour le prix il faut tenter l'expérience.
Marc P.
Etonnante version MK2 sans les prises branlantes!!
Mon instal ayant pris de l'ampleur, streamer, DAC etc... j'ai racheté une barette identique à la première. La première il y a deux ans amenait une évidente transparence (à priori cable interne de course??) mais avait des prises un peu branlantes. Bon une fois la prise fixée, personne va aller la secouer, mais c'était une petite contrariété. Oh surprise Audophonics a du rectifier le tir car non seulement ce ne sont pas les même prises (plus cossus) mais enclenchement super ferme dans la prise. Le top. Là sans les prises bralantes, je suis bluffé car y'a plus aucun reproche possible et toujours ce petit plus en transparence. Chapeau bas et bravo d'avoir rectifié une (probable) erreur de jeunesse. Surtout gardez les même prise. C'est pas du furutech mais beau placage or et très proche de furutech niveau qualitif (vu chez ami audiophile et toujours du mal à comprendre de tels prix) et pour 8 prises le "coût à la prise" est juste "wow" !!
Kalle J.
Good value.
Upgraded from my NAD D1050 (CS4398) that tragically died.
This unit does everything just as good or better.
- for no USB-C
Super mais pas avec un conditionneur
Avant l achat d un conditionneur keces bd1200 soit toroidale de 1200v/a. Déphasage et filtrage en mode commun. Le filtre Ifi tasse la dynamique. Dommage. Je l est brancher sur l
Une prise mural libre du salon. La PR contre surprise. Le modem fonctionne mieux. Le réseau est devenu plus rapide et bc plus propre. J ai adjoind une Ifi purifier kiné dc entre l alimentation du modem. La encore mieux. J ai un 2eme Ifi noise filtre. Je m en sert sur la multi prise pc portable et n'as. La encore du mieux partout. Le n'as délivré les bits sans perte, propre. En gros une fois trouvé le ou les bons emplacement ses filtre travaille vraiment bien. Mon streamer Ifi zen donne son max. La tv a des images magnifique, mon pc n'a jamais fonctionné aussi bien. Même audirvana en a profité. Achat recommander. Comme une personne ici la dit 2vaut mieux qu 1..Le tweak RQP exeptionnel
Olivier G.
Superbe boitier
Produit reçu bien emballé/Produit aux finitions exceptionnelles
Barrie M.
NEOTECH NEI-1001 II Interconnect Cable Balanced UP-OCC Silver 2x1.17mm² Triple Shielding The Neotech NEI-1001 II is a balanced modulation cable made of 2 Silver UP-OCC conductors with a cross section of 1.17mm². Each conductor is composed of 4 strands of...
Excellent DIY Interconnect Cable
Could tell immediately that this is an exceptional cable . Excelled from get go with I am sure more to come as cable runs in with use . Using to connect Electrocompaniet EMC1 UP ( used as transport ) to Gustard A22 DAC and pair of balanced interconnects for Gustard to PreAmp (ATC SCA2) . Cable has replaced Neotech NEMOI-1220 ( OC UP silver ) . The 1220 is very good but 1001 is better . Highly recommended .
