Jean-Claude F.
Très bon câble HP
Jean-Claude F.
Yvain C.
J’ai hâte de la...
Istvan N.
Decent input switching device
The device itself is a very solidly built unit.
Giving only 4 stars because the following:
- the colored cable which connects the rotary switcher to the board has the tendency to break pretty easily. Some heat-shrink tubing would be nice over the connection points.
- for the voltage regulator maybe use an LDO type (eg. KA78R05) or similar for better efficiency (less heat generated)
Istvan N.
Good speaker protection module
The module in general is OK, it does it's job as advertised.
However:
- make absolutely sure that the connected AC supply, when rectified and filtered provides at least 12V DC, otherwise the relays won't click. I've used a 9V AC transformer, and it was not sufficient.
- I had changed the filtering capacitor to a 25V unit. The provided 16V cap was very much on the edge from my point of view, and it would not live for very much long time, if run at the limit.
Istvan N.
Steel Shielding Cover for Toroidal Transformer 140x64mm This black steel cover allows you to hide a toroidal transformer while acting as shielding to considerably reduce harmful EMI disturbances. The internal dimensions of this cover...
Very nice cover
A very nice, massive cover for the toroidal transformer. It is powder coated.
pascal P.
OCTAVIO STREAM Streamer Bit-Perfect WiFi AirPlay 2 Bluetooth 24bit 192kHz Octavio offers with the Stream an improved version of its first streamer model. Extremely easy to use, it is designed to modernize an existing HiFi system by transforming it...
Correct
Il fait le job mais pas mieux que mon PC pour lire Qobuz. Pas d'entrée USB pour lire un disque dur ce qui oblige à lire sa bibliothèque via le Wifi, ce que toutes les configurations ne permettent pas. Pilotage via Android correct mais peut mieux faire.
Philippe V.
Encore plus satisfait
J'ai commandé le Mogami 2972 afin d'alimenter la section médium aigüe de mes en enceintes (fils reliés 2 par 2) en complément du w3103 pour les basses. Le resultat a été immédiatement très convainquant (en comparaison du w3103 seul) et qui s'améliorera probablement encore légèrement dans les jours à venir. Je suis vraiment très content d'avoir découvert le câble Mogami. La livraison en point relais en 24H. et très bien emballé. Audiophonics est toujours au top.
Robert K.
Quality product
I am very satisfied with the purchase. The module arrived fast,undamaged - well packaged (wrapped in cardboard and taped, wrapped in protective paper and placed in a larger cardboard box and taped again - excellent).
I am also surprised by the thorough and clean production, where quality components were used (among others Japanese ELNA-RC2, Panasonic-FC and Korean Lelon 105° capacitors).
I haven't tested the product yet, because I'm still waiting for the remaining components, but from what I've seen, I can report that I'm satisfied with the decision for Audiophonics. Greetings from Slovenia.
olivier C.
Vraiment surpris...
Je reçois le produit tard, pour n'embêter personne à debrancher la chaine hifi, je branche la Vilborg sur mon ampli à lampe Bogner, et la......grosse claque, plus de parasites, tout est limpide, plaisante à l'oreille, demain je teste sur la hifi et j'espère reprendre une claque....à suivre....
Delacour j.
Finition très propre.
Utilisée pour recouvrir une tresse de blindage sur le câble secteur d'un téléviseur.
Delacour j.
Pratique.
Utilisée pour finaliser le blindage d'un câble secteur.
Delacour j.
Conforme à la description.
Utilisée pour fabriquer un blindage sur un câble d'alimentation secteur d'un téléviseur.
Delacour j.
Un bon produit.
Solide, massif...très pratique pour serrer les câbles dénudés et quant dispositif de serrage de la gaine, il est exemplaire...
Anne b.
fourche cuivre plaqué or
fourche cuivre de tres bonne qualité utilisé sur ampli tuner technics on peu meme utlilisé les fiches bananes vraiment bien merci audiophonics
Un très bon rapport qualité prix ..résistance précise et transparente ..
Yves G.
Bon rapport Qualité/prix.
Simple et de qualité.
Montage connecteur Schuko Type E/F 250V 16A Ø8mm Noir à 2€.
Avec du câble OLFLEX 110CY 3x1,5mm² et un connecteur IEC C13 à 3€. Pour remplacer les fiches d'origines (en 0,75mm²) de mes deux amplis (Denon DRA800H et Cambridge CXA80) Fonctionne parfaitement.
Première commande depuis la Belgique et pas la dernière.
Yves G.
Bonne fiche et bon rapport Qualité/prix.
Yves G.
Bonne prise bon rapport Qualité/prix.
Christophe A.
ARMATURE ELECTRA F8 V2 Filtered Power Distributor 8 Sockets Aluminium Black The Armature Electra F8 V2 is a high quality filtered mains distributor, integrating two direct sockets and four filtered sockets which will give your music back its real color....
a
Très content de cette acquisition. Produit de qualité avec une belle finition. Je l'ai mis en évidence sur mon meuble Hi Fi NORDOST tel un élément de mon système puisqu'il apporte une réelle valeur ajoutée:
Définition, qualité des timbres, aération de la scène sonore
Yves L.
DAYTON AUDIO HTA100BT Hybrid Tube Amplifier BT5.0 Phono 2x50W / 4 Ohm The HTA100BT stereo amplifier provides the roundness and richness of tube amplifiers while taking advantage of a completely up-to-date connection including no less than a...
VVHP
Matériel et livraison impeccables.
Attention : matériel livré réglé en 110V...
Aurélien M.
J'en mets sur tout mes câbles secteurs. Avant j'étais sur la première version, mais là c'est une autre histoire, on va un peu plus loin. Puis question esthétique, c'est quand même autre chose
Jean-Marie B.
preampli FX AUDIO
Agréablement surpris il a tout d'un grand ..Bien entendue pour moi il se place entre la sortie casque de mon PM8006 MARANTZ afin déjà de profité de ces qualités pour venir se brancher dans un AMPLI casque de classe A et de lui donner chaleur et détails encore plus précisément
Niklas R.
Great Cable for DIY Projects !
This is a great cable for DIY projects with space restrictions. The cable is lightweight, flexible, and easy to solder !
Simon F.
Works a treat
I used this DAC with an old Raspberry PI-1B I had lying around. I'm very pleased with the resulting sound (pioneer amp and 80s-era KEF speakers).
Unlike later RPI models, the necessary I2S connections to the RPI-1B (Version 2) are made not via its 26 GPIO pins. Where to make the connections is very clear from he DAC documentation/schematic (on the audiophonics website). Rather than soldering wires directly to the RPI PCB, I soldered a "2.54mm Separable Male Pin Header 2x4 Pins 5.5mm (Unit)" to the RPI and connected this to the DAC using "I2S 2.54mm Female / Female Cable 1 Pole Silicone 17cm (x5)". All really easy.
Christophe A.
Je m'arrache les cheveux
J'ai repris un deuxième A300 pour profiter du mode BTL. J'ai suivi les instructions à la lettre, mais rien à faire, j'ai uniquement du son sur la sortie droite de l'ampli maître, sur l'ampli esclave aucun son. Quelqu'un pourrait-il m'aider à résoudre ce problème. Merci à tous
Serge H.
LUDIC ASGARD Power Distributor 6 Schuko Sockets Black The Ludic Asgard power distributor is a high-end model with 6 Schuko plugs and a total shielding. It will provide your audio devices with a clean and stable electrical signal,...
Filtre ludic ASGARD
Le meilleur filtre passé chez moi.
Pour moi, le seul qui marche correctement, neutre en audio et nettoie la video sans brider le son.
Le découplage sur pointes fait la différence.
Pas de fusible de protection, ni d'interrupteur qui brident la dynamique.
Ludic a tout compris !!! La tension affichée est un vrai plus.
Pierre S.
Fidèle à la description
Je l'ai mise sur de longs câbles de haut-parleurs Linn K400, il ne sont pas rond mais oblong, env. 3cm/1.5cm , la gaine s'est très bien adaptée à la forme. C'est très brillant comme rendu, mais quand même beaucoup mieux que la gaine brute des K400. Mais pur plastique au toucher. Mettre des gants pour les appliquer au risque de se bruler...
Pierre F.
Sparkos
Voilà une merveille qui n'est pas une illusion. Il mérite 100%
Vincent H.
Acheté sur ce site il y a deux ans. Satisfaction intacte. Comme lu dans un avis plus ancien: fini la recherche de l'ampli qui convient à telles ou telles enceintes, etc. Une source de qualité (CD branché en coaxial, Qobuz HiRes en USB, TV en optique), des enceintes de bonne taille bien étudiées et adaptées à la pièce, et l'ampli fait le job: ça amplifie, c'est droit, c'est clair et limpide à toutes les fréquences, très dynamique. La puissance max est bizarrement notée à 10% de distorsion (pourquoi ne pas mentionner la puissance max à 1%? A 10% de THD, on préfère baisser le son...). Avec des enceintes à haut rendement sur lesquelles on besoin seulement de quelques watts, c'est tout simplement impeccable et je ne reviendrai pas à des appareils lourds, énergivores, qui chauffent plus qu'ils n'amplifient.
Andris L.
Delta-sigma end game
Delta-sigma end game, but probably too expensive for many enthusiasts and I agree about the packaging, it is vulnerable, just hope that the store will package it well (it was acceptable for me).
Andris L.
The best of the best in its class
Super cheap price that makes any DAC sound acceptable (entry level Hi-Fi). The sound is relaxed but confident and well controlled with a slightly pronounced separation of vocals and instruments. From a very cheap built-in DAC, you will notice that the sound is no longer so compressed, it has become freer. I think this OP-Amp could be compared with any budget external DAC, but definitely better than the built-in one of Wiim streamer, cheap phone or headphones. This OP-Amp is the first one that produces a different sound from the ones included in the Aune X8 set (I compared).
Andris L.
Solid material with a metal plate inside that you can't see in the picture.
Andris L.
AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Black The X8 XVIII BT Magic DAC from Aune is a special edition of the DAC, on the occasion of the 18th anniversary of the brand. This one takes back the idea of the interchangeable...
Standart package *** stars worth
I wrote a review for ASR. In short, you should know:
Only one extra Op-Ams comes with the set.
All the extra Op-Amps offered by Aune are no better than a cheap DAC on the market. The sound starts to normalize around OPA627, which can be purchased separately, and because of which you will not be able to close the lid of the device. The optical port does not click into place. The potentiometer has difficulty separating the channels. A POP sound will be heard when laying in/out. Only with Sparkos SS3602 will you have a real benefit. You can initially buy the cheap BB OPA627 and upgrade over time, or upgrade immediately if funds allow and the system is ready for it.
Bernard P.
attention au branchement
Très bonne prise achetée pour montage cordon secteur en DIY. Par contre suite à connexion sur barrette secteur dynavox X4100, allumage de la led Inversion de phase. Après recherche du défaut , le cordon est en cause : inversion phase et neutre au niveau de l'inscription N et L inscrit au niveau insertion des fils: Donc à ne suivre pour le branchement.
Par contre le schéma de branchement donné par le site est correct
Hugo Z.
Digitaler Eingang mit Bluetooth
Verbindung ist sehr gut und reißt nicht ab. Klang über Digitalkabel sehr gut.
AIYIMA B2D1496 Class A/B Amplifier Board SanKen1494/3858 2x220W 4 Ohm The AIYIMA B2D1496 is a Class A/B amplifier module. It is based on 8 SANKEN transistors, 4x 2SA1494 and 4x 2SC3858, to deliver a comfortable power of 2x220W under 4Ω or...
Service de qualité de la part d' Audiophonics, expédition rapide et emballage correct. .
L'ampli acheté produit un son de qualité, sa fabrication est de bonne qualité. Seule la dimension en hauteur est 5mm supérieure à celle donnée dans les caractéristiques produit.
denis L.
Super soudure
Necessite un bon fer a t° élevée mais soudage facile. Excellent pour les câbles RCA DIY son super détaillé et fidèle. Pas donnée mais résultat au top!
denis L.
Excellent RQP
Très bonne qualité des matériaux utilisés. La fiche peut paraître un peu légère mais elle tient bien dans les connecteurs pour une utilisation domestique sans débranchement très fréquents. Facile a souder et son top, neutre et fidèle. Très bon rapport Q/P
Marcos Pérez J.
A great cable
I have no experience in my current system with expensive cables, but I do have experience in how my equipment sounds and a good system must sound. And I can't think of how another cable could sound better. This cable is extremely detailed, and the best: not at all shiny, something that is usual in silver cables. An increase in the level of detail also means an increase in the hissing level in the recordings.
It is an ideal cable for DSD or low noise tracks. I have mounted it with RCA NEUTRIK NF2CB2 connectors. It would be very interesting to try it with other connectors to see the differences.
Marcos Pérez J.
AUDIOPHONICS MPA-M500NCX Power Amplfier Class D Mono NCore NCx500MP 1x500W 4 Ohm We are pleased to introduce the MPA-M500NCX, a mono power amplifier based on a NCORE NCx500 amplifier module.
Highly recommended
I also use this power amplifier in an active speaker system to amplify the bass frequency speaker. I can only say that the result is totally realistic bass frequencies. I have also done tests as a medium and high frequency amplifier and the result has surprised me very positively, not so much as to replace a power amplifier with 300B valves and premium components, and although the timbre and especially the voices of the power stage of vacuum valves are noticeably superior, the scene and speed seem outstanding to me, especially for the price of these stages. I advise your purchase without reservation.
Pierre B.
j'en rajoute une couche !!!
aujourd'hui mon revendeur hifi m'a prêté un drive heed obelisk dt pour tests.....le drive va rester à la casa car couplé au D300 cela donne un truc super musical !!! avec le oyaide dst-75 cela donne de la matière et beaucoup de délicatesse tout en gardant une dynamique très naturelle....
ne sous-estimez pas ce petit dac,c'est une merveille de musicalité !!!!
Daniel P.
Utilisé pour le secteur
C'est vraiment du très bon câble, tout est mieux, je vais l'essayer pour les enceintes.
Daniel P.
NEOTECH NC-01675RH Banana Plugs Rhodium Plated OFC Copper Cryo Treatment Ø8mm (Set x4) These Neotech NC-01675RH banana plugs feature excellent design quality and are ideal for creating high-performance HiFi speaker cables. The contacts are made of Rhodium-plated...
Conception à revoir
Je suis déçu, pas par le son mais par le fait que, s'il y a bien deux vis pour maintenir le câble, une seule est fonctionnelle, une courte si votre câble est épais, une longue si le câble est fin, mais pas les deux, pour le prix j'aurais aimé avoir des vis supplémentaires. Et puis avec des Furutech, je peux bloquer les fiches d'une seule main, ce qui est pratique lorsque l'ampli est lourd et un peu inaccessible par l'arrière, alors qu'avec ces Neotech il faut les deux mains pour un bon blocage.
Remy M.
Un câble de toute confiance
Je recherchais un prolongateur Jack 6,35mm de 2,5m, ce qui est curieusement peu fréquent.
Un câble est un support passif qui transmet un signal électrique. Il ne le modifie pas si ses composants sont de qualité, sans jeu dans le connecteur, sans faux contact, sans interférence, sans distorsion.
Sinon, le son de vos enceintes ou de votre casque sera altéré, mais il ne sera en aucun cas amélioré. Toutes les mesures physiques et les tests en double aveugle le démontrent.
Mogami et Neutrick sont des références incontestées dans leur domaine et le montage a été très bien fait. Le résultat est parfait et ce câble durera certainement plus longtemps que moi.
Eric K.
câble RCA
Bonne qualité mais un peu dur à enficher (il faut desserrer le connecteur délicatement !). Merci: bon rapport qualité/prix.
Eric K.
filtre Heimdall
Installé sur des sources : très efficace. Un peu "léger" par rapport à d'autres produits (?...)
Eric K.
filtre secteur
Très efficace, merci
Eric K.
DYNAVOX 2-Way Speakers 40W 92dB 4-8Ω 50Hz-20kHz (Pair) This pair of low-cost 2-way trapezoidal speakers offer excellent value for money and are ideal for use in small rooms or bedrooms. Each speaker is equipped with a 130mm...
enceintes compactes
très correctes pour ce prix. Merci audiophonics !
Eric K.
FOSI AUDIO T3 Amplificateur à Tubes Class AB 2x 6F2 Bluetooth 5.0 2x50W 4 Ohm The Fosi Audio T3 is a small tube amplifier allowing to enjoy the sound signature of this round and warm type of amplification at a low price. It is thus equipped with two 6F2...
ampli 50W
Très bon son/appareil compact.
Patrick C.
DAC Topping DX1 suite ....
Essais avec alim linéaire et alimentation batterie (avec un câble USB en "Y") concluants : l'amélioration sur la dynamique dans le grave et l'aération en vaut le coup.
Ça m'énerve qu'il soit bon !
En attendant la réparation de mon top ampli classe A haut de gamme, il me fallait un truc pas cher pour patienter.
J'ai écouté des PURIFI et autres "classe D" qui ne m'ont pas du tout plu. Froid et plat a mon gout.
Bien, je sors le truc tout léger de sa boîte, c'est joli. Je branche. Je lis le mode d'emploi (nécessaire) et je teste.
Sur l'option SDB, effet "loudness" comme j'aime le son, je suis très énervé de m'avouer que le son est la.
La scène est plus petite qu'avec mon ampli habituel. Je lui ai trouve quand même un défaut. Na !
Pour le reste, c'est le premier classe D qui me séduise en plus du prix ridiculement bas (20 fois moins que mon ancien ampli).
Je recommande vivement. Même aux audiophiles.
Jusqu'à maintenant, que du bon!
Première bonne surprise: l'ampli non dispo avec délai de 2-4 semaines. Je commande et je le reçois 4 jours plus tard. Merci @audiophonics
2ème surprise (qui ne devrait pas en être une): le son est superbe. Je reconnais cependant l'improbabilité de mon installation: en remplacement de 2 blocs mono flying mole, l'ampli est connecté à un sélecteur de sources audiophonics partagée entre une interface usb esi gigaport ex, la platine dvd, la télé et un player hidizs ap80 pour la réception bluetooth , et à mes antiques Jamo e610 pour les sorties. Quelques essais en bluetooth, puis en filaire avec une playlist sur le pc et enfin la nvidia shield. Sans conteste ni prétention audiophile de ma part, cet ampli délivre un son pêchu, détaillé riche en aiguës et basses... Boitier massif que je loge dans une case de mon meuble TV ikea, sans chauffe apparente.
Mon impression est donc plus que positive . A voir sur la longueur, mais j'ai confiance.
Merci encore pour cet appareil!
