Laurent B.
Bonne upgrade
Hans B.
Patrice L.
Un produit bien conçu.
Customers reviews - There are 19358 reviews.
Daniel V.
Daniel V.
It is an overall excellent device (SMSL AO300), well thought out with a wide range of connection options to the source and end components of the apparatus.
In terms of sound, I am satisfied with its clean, natural sound on both analog and digital connections. Speakers used are B&W CDM-1 + Dali SW-8; on the headphone output there is an excellent combination with 1MORE Triple Driver Over-Ear headphones (slight modification - removal of 2/3 layers of foam above the drivers).
I wanted (ordered) a black version, a version with a silver front panel arrived. . . :-)
Eric K.
ampli casque
Super son . Utilisé avec connexion symétrique casque Audio technica
Eric K.
MUSES8920
Très bon sur ampli en remplacement de APO 5532
Eric K.
cable 4mm2
très bien pour mes enceintes colonne.Merci à Audiophonics
Robert W.
TOPPING D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Silver Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB...
DAC sounds realy nice
Only remote control (BT) seems to disconnect after a while and when Press a Button IT reconnects in around 15 Seconds and have to Press Button again to send Funktion.
Janez R.
Six Stars
In short, I had problems with first amp (left channel wouldn't turn on sometimes), waited too long for replacement one, with which I encountered some weird beeps from speakers - but found the cause with patient help from M. Sav. (poor wire sorting in the back of amp).
Now it is all perfect.
Congratulations to incredible Audiophonics team!!!
The sound is amazing, however, the curiosity of what 7040 and even 9040 are capable in terms of SQ, was only boosted by 400 Purifi amp module integrated into Audiophonics amp.
Thank you, Audiophonics.
Sebastien D.
IEC C13 to IEC C14 Power Cable Extension 3x0.75mm² 0.5m This IEC C13 to IEC C14 extension cable enables you to extend a mains connection by plugging in another mains cable. The cable features OFC copper conductors with a...
Une rallonge quoi
Sebastien D.
Branché en pré-out front sur un Denon avc-x3800 pour essentiellement écouter de la musique avec mon eversolo DMP-a6 je suis comblé, richesse des textures et profondeur des graves sur Focal Chorus 726v, le top quoi... Ça soulage l'ampli home cinéma aussi de ce fait, le Purify c'est top
Daniel V.
Daniel V.
Daniel D.
prise IEC viborg VF512R
Attention, je confirme l'un des commentaire écrit sur cette prise. Excellente qualité à tout niveau, toutefois cette prise ne rentre ni dans ma barrette secteur, ni dans lecteur cd, ni dans mon préampli (uniquement dans mon Subwoofer qui vient des US, marque THIEL). J'ai hésité à la retourner car, pied à coulisse en main, il y a 1mm de trop dans un sens, et 0,5mm dans l'autre ainsi que sur les chants biseautés, par rapport aux prises IEC courantes, étonnant.... J'ai finalement réduit tout cela avec une lime plate, 30 minutes de travail minutieux et ça a marché !!! Son pendant en prise shucko ne présente aucune anomalie.
MARC B.
XANGSANE XS-6001AU SHORT Speaker Terminals Gold-Plated (Set x4) Xangsane's XS-6001AU SHORT speaker terminals are ideal for mounting on enclosures and/or loudspeakers with wall thicknesses from 2mm to 4mm maximum. They...
Mauvais choix - Très déçu !
Très déçu par ce produit, la partie filetée arrière présente un jeu boulon/écrou trop important, l'écrou ne se serre pas car il saute du filetage, inutilisable. J'ai donc modifié les borniers pour les fixer différemment et en les usinant (taraudage), je constate qu'ils sont en laiton et non en cuivre. C'est la première fois que je suis déçu avec un produit vendu par Audiophonics... je changerai ces borniers par des vrais "cuivre" plus tard. Dommage !
Excellent résultat à un prix contenu
Le WiiM Amp est associé à des enceintes bibliothèques Sonus Faber Lumina II, et Qobuz est la source audio principale (connexion filaire Ethernet).
Le son obtenu est excellent avec de nombreux styles de musique, en particulier après activation et réglage de l'EQ (equalizer). J'ai trouvé le son un peu trop "clinique" à mon goût avec l'EQ coupé.
Mes enceintes étant en 4 Ohms, il y a une grande réserve de puissance et l'ampli ne chauffe guère à volume d'ambiance ou soutenu.
L'application WiiM Home est facile et agréable à utiliser. Le pilotage "Chromecast" depuis le Web Player Qobuz sur ordinateur fonctionne également parfaitement.
Très bien !
Petit appareil très peu encombrant avec interrupteur marche/arrêt qui s'en sort très bien !
Pas de souffle ni de bourdonnement, gain élevé, tout pour plaire entre une platine vinyle et un amplificateur.
Prix bas et livraison ultra-rapide en attendant que je reçoive mon préampli phono à tubes qui coûte 50 fois plus cher et encore d'occasion.
Livraison rapide, top Audiophonics.
Les condensateurs Jantzen de la série Z-Cap Superior sont vraiment excellents, aussi bien pour le filtrage des haut-parleurs que pour améliorer les circuits électroniques hifi de tout type.
La musicalité progresse nettement, n'hésitez pas à les utiliser.
Livraison rapide, bravo Audiophonics.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 0.47µF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
Jr S.
Kwalteitsprodukt!
Aangesloten op mijn transportpi van ian canada.. meer details nu te horen en betere plaatsing. Printplaat ziet er degelijk uit! Aanbevolen!
Radek P.
Jirka Vopicka
Why does this cable smell so bad? Like a coal mine. It's been out for two days and it's not helping. I've never seen that before. Is this even genuine Japan?
Livraison rapide et conforme, merci !
Emmanuel A.
Très très bon
Rendu très fin sans brillance sur un ampli marantz et enceinte b&w
Martins R.
XANGSANE XS-DIY1 Pure Silver Wire 99.99% FEP 0.08mm² Ø0.62mm The Xangsane XS-DIY1 is a high-end cable with 99.99% pure silver as the conductive material. This ensures maximum electrical conductivity for optimal audio signal transmission....
Perfect headphone cable
This is perfect quality pure silver cable. Phenomenal sound, pretty much no microfonics perhaps a bit on the stiffer side, but that's alright. Compared to silver that used before( which was 3n purity 0.2mm from silversmith) this has a lot better clarity, coherence of sound, and picks up almost no interference. Also a lot sturdier. Can recommend. Wil actually but again.
Douwe v.
FOSI AUDIO LC30 Audio Selector Switch for Amplifiers / Speakers vu-meter Yellow With its LC30, Fosi Audio unveils an amplifier and speaker selector. In other words, it allows you to switch easily and quickly between two power amplifiers and two pairs of...
Good switcher but disappointing VU meter sensitivity
Unit was delivered with a loose screw inside. Not very nice but quickly fixed with permission of AudioPhonics support.
Build quality is rather decent especially from listening distance.
Remote control: great/logical layout. Yes it's light and a bit plasticy but it functions well. A more classy remote like the Apple Tv's aluminium remote would've been nicer at this price point.
Auto-on or Audio passthrough when the unit is switched off is not advertised or mentioned but it can be done. This unit seems a bit of a clone of the Douk VU3 and that one has powered-off passthrough:
Connect your main speakers @ Speaker 2 terminals and your main amp @ Amp B!
Then the VU meters..
Well, as mentioned everywhere: they're NOT sensitive, even at their maximum sensitivity. I am running quite sensitive Klipsch speakers and it's about 25 dB behind. So even with less sensitive speakers, I don't think you'd get a lot of swinging meters. They look nice though!
Dominique V.
LED Bulb 6V Warm White This LED bulb offers a warm white light. It is powered by 6V and will find its place in many DIY projects.
Pour magnétophone Akai
J'ai commandé cette ampoule pour un remplacement sur un magnétophone à bande Akai qui a une cinquantaine d'années, pour l'éclairage des VU-mètres.
Elle fait parfaitement le "job" . Aucun problème d'adaptation de taille, elle fait le même diamètre et la même longueur que celle d'origine, une petite soudure à l'étain et le tour est joué. Dommage que je ne peux pas joindre une photo pour voir le résultat.
Dominique.
Matt H.
The best spade I’ve used
Really high quality spade. The construction with the 2 half’s of the spade work like a spring and help clamp in the binding post much better than a solid spade.
Matt H.
Very good quality
Good value too and the solderless termination is perfect for the best sound.
Très bien !
Pour le prix, il est très bien !
Je l'ai commandé en express car j'attendais un préampli phono MM à tubes, clone d'un Audio Note (1 tube ECL82 + 1 tube 6z5p + 2 tubes 12au7 + 2 tubes 12ax7).
Il s'en tire très bien, avec interrupteur marche/arrêt en plus.
Livraison ultra-rapide de la part d'Audiophonics, bravo !
Excellent, vraiment !
Toujours aussi excellents ces condensateurs, que ce soit pour du filtrage HP ou pour remplacer des condensateurs dans des éléments électroniques haute-fidélité.
Celui-ci remplace un condo MKP chinois 0.22 µF dans mon préampli phono MM à tubes (1 tube ECL82 + 1 tube 6z5p + 2 tubes 12au7 + 2 tubes 12ax7) clone d'un Audio Note et le résultat est là.
Livraison express, félicitations à Audiophonics.
Excellents, vraiment !
Celui-ci remplace un condo MKP chinois 0.47 µF dans mon préampli phono MM à tubes (1 tube ECL82 + 1 tube 6z5p + 2 tubes 12au7 + 2 tubes 12ax7) clone d'un Audio Note et le résultat est là.
Romain G.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 2.7μF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
Meilleurs rapport qualité prix
Ses condensateurs (avec les mundorf suprême) sont le minimum à essayer si vous voulez entendre une véritable différence en terme de définition et à condition d'avoir un tweeter haut de gamme derrière, comme souvent je ne modifie qu'une enceintes sur le 2 et je fait des comparatif sur un signal mono (enceintes côte à côte) et la il n'y a pas de doute ce condensateurs apporte une scène sonor plus grande plus de définition, sont grand frère le allumen va plus loins surtout sur des compressions, chez mundorf la montée en gamme est moins significative je trouve
Romain G.
Enfin une connecteur non magnétique
Pour avoir essayé pas mal de connecteur rca la plupart sont magnétique lorsque qu'on approche l'aimant sur la partie centrale (donc pas du cuivre) celle ci est donc le meilleur rapport qualité prix même si c'est possible que ce soit tu laiton elles reste abordable et cran au dessu des concurrents
Patrick A.
Accord parfait
Je ne trouve pas de mot plus approprié que "parfait". Cet ampli est le parfait mariage avec mes Tannoy System 800 (monitor). Le son est chaleureux, détaillé, la scène est ample, remplit tout l'espace. Ce son me plait beaucoup, je verrai à l'usage s'il s'améliore après quelques heures de rôdage.. Je destinais initialement l'ampli à mes Tannoy Mercury V1i (bibliothèque), pour remplacer un vieil Alientek D8 dans la chambre, qui donne pourtant toujours un effet WOW sur des pistes haute définition et bien mixées (couplé à un DAC Topping D50), mais après avoir testé l'ampli en XLR sur un Eversolo DMP-A6, d'abord sur les monitor 800, puis sur les V1i, je dois avouer que les 800 sortent gagnantes, le son est ample, enveloppant, chaque instrument à sa place selon le mixage initial de la musique. L'ampli SMSL AO200 MKII est très transparent, surtout en mode SDB sur l'égaliseur, il reproduit le son tel qu'il le reçoit. Pour le prix, n'hésitez pas, si comme moi vous aviez un petit ampli qui rendait déjà service (type Alientek ou Topping) et qu vous voulez un son qui monte en gamme, sans se ruiner, c'est l'ampli parfait! Les gros + : entrée USB, les entrées XLR, l'entrée bluetooth (quand on a un vieux DAC non équipé), les 2 sorties subwoofer, le réglage EQ maison SDB. Les petits - : pas de auto On/auto Off comme sur l'alientek (bien pratique pour que l'ampli se mette sous tension à la détection d'un signal audio) et pas de prise casque (mais je ne le destinais pas à un casque). Bref très content de cet achat, merci Audiophonics pour la rapidité du traitement de la commande!
Vladimir p.
Rectifier Gold Lion GZ34
Got this particular order the very next day (!) though the distance was few thousend km !!! Not only I did not expect delivarance this fast but I could never imaging this would be possible. Bravo, Audiophonics!
About rectifier GL GZ34 for my Muzi x7... It was very good right from the box - good separation, much more to hear in the Mids, good bass but Highs just a little rolled off. I knew that rectifiers need about 50hrs of burn in and after few days of use - voila! - Highs are comme il faut! My x7 never sounded better, and I have not even tried to roll power tubes yet (KT88)! But the most remarkable thing about GL GZ34 is that it is very musical: it takes notessounds and makes of them music. Love it! Can't wait to see what Mullard GZ34 will do (aph.fr has just shipped it to me).
So now I have 3 different very dicent rectifires to use - stock Muzi (very "tasty" sounding, slightly coloured but not too much), GL GZ34 and Mullard GZ34 (which is on its way home).
And thnx to aph.fr for excelent service, if I need something that they have I certanly will order from them. thnx.
alain l.
Produit très pratique quand on n'a pas les moyens ou la place pour acheter une machine à laver les vinyles. Par contre la dernière fois que j'en ai acheté dans un magasin parisien le flacon contenait 500mL. Pour un prix équivalent maintenant on a droit a 360mL. Il y a un peu de shrinkflation comme disent les américains.
Jean-Baptiste C.
EVERSOLO H1 DAC Portable Headphone Amplifier ES9281AC Pro MQA 32bit 384kHz DSD256 EVERSOLO offers with the H1 a compact and powerful portable DAC and headphone amplifier combo. With a USB-C input, it is an ideal companion for use with a current smartphone. It...
Excellent petit DAC
Sur les conseils de David Aubert (que je remercie au passage), j'ai acquis ce petit DAC pour y connecter mon smartphone et des écouteurs Sennheiser IE200. Le son est bon et assez puissant. En y connectant un casque plus gourmand, c'est un peu faible mais ce n'etait pas mon objectif donc je suis très satisfait. Le DAC est petit et n'est pas génant dans une poche.
Jean-Pierre D.
Avis complémentaire (usage avec préampli Gustard P26)
J'utilise l'ampli en mode Hi-Fi avec un préampli compétent le Gustard P26, j'ajoute donc un complément à mon précédent avis. Je confirme l'extrême qualité de la transparence et de la transparence sonore, cela n'ajoute rien et n'enlève rien. Cela ne pourra pas plaire à des personnes qui recherche quelque chose de "flatteur" moins rigoureux et plus indulgent. Par contre, par exemple le réalisme des instruments et des voix est surprenant. Je vois ça par mon utilisation avec des enceintes colonnes Triangle (gamme signature juste en dessous du haut de gamme Magellan) où rien n'est enlevé, ce n'est pas agressif dans l'aigu par exemple. Je dispose d'un second système avec un Denon PMA 110 de caractère différent que j'utilise avec des enceintes Focal. A mon avis, il est intéressant d'associer cet ampli de puissance avec un préampli au traitement raffiné et le résultat pour le prix est sans concurrence sur le marché.
BENOIT D.
HIDIZS S9 PRO Portable Headphone Amplifier DAC ES9038Q2M Balanced 32bit 768kHz DSD512 Hidizs offers with its S9 Pro a revised version of the already excellent S9. The DAC and portable headphone amplifier combo is now based on the use of a high quality ES9038Q2M...
J'ai donné mon S9 à mon fils, je l'ai donc remplacé par le S9 pro. Je n'ai malheureusement pas pu les comparer en direct, de toutes manières je ne pense pas avoir les oreilles assez affutées pour percevoir la différence. Mais je suis ravi par la qualité du S9 pro. Je l'utilise principalement connecté entre mon smartphone Samsung et mon casque Grado SR325x. Parfait. Livraison parfaite par Audiophonics que je remercie pour la qualité de leurs produits.
BENOIT D.
Très bonne qualité, la fixation du jack est très efficace. Livraison très rapide, comme d'habitude.
Daniel P.
J'ai d'abord regretté mon achat.
Montés sur un vieux Cayin A-88T le son son était vraiment mauvais, les anciens tubes étaient meilleurs et mon ampli Yamaha à transistors bien mieux. J'ai modifié plusieurs fois le bias, aucun changement, très décevant. Ce n'est qu'après trois semaines d'écoutes sans grand plaisir qu'un jour tout à changé, tout s'est mis en place, d'abord la scène sonore puis les basses et le reste, et maintenant c'est vraiment excellent. Très content.
Pierre F.
FIIO BR13 Bluetooth 5.1 Receiver QCC5125 DAC ES9018K2M aptX-HD LDAC 24bit / 96kHz The FiiO BR13 is a Bluetooth receiver equipped with a high-performance DAC. KEY FEATURES: Bluetooth 5.1 QCC5125 receiver chip SBC, AAC, aptX, aptX adaptative, aptX...
fait le job pour moderniser une chaine HiFi qui n'avait pas d'entrée Bluetooth ou USB.
rappel : la qualité de la transmission dépend de la source (mp3, CD, qualité studio, ...)
entrée Bluetooth :
il faut une alimentation externe (prise USB)
appairage sans difficulté avec le smartphone
appairage plus compliqué avec le PC (w10) : il m'a fallu aller dans la gestion des services windows (prise en charge Bluetooth) et basculer la sortie audio du PC de "haut-parleurs" vers "audio FiiO BR13" pour transmettre le son vers la chaine.
entrée USB :
la source (PC) fournit à la fois les données et l'alimentation (USB Type-A)
Pierre F.
produit conforme mais attention
le câble livré avec, est un Type-A _ Micro-B
Jérôme P.
Hexagon Socket Cylindrical Head Wood Screw M5x35mm 8.8 Steel Black (x10) These hexagon socket cylindrical head screws are in M5x35mm format. Made of 8.8 steel, they guarantee a high durability.
Vis de très bonne facture, et difficile à trouver sur internet !
La tête CHc donne un super look PRO, parfait pour faces avant, planches de bord, instrumentation de cockpit, etc..
Eelco R.
It actually works
I also was sceptical about what to expect but the cable actually makes a difference. It’s huge (my son was jokingly calling it the water-hose) and you have to purchase appropriate plugs.
Once connected, I immediately noticed a difference in detail and clarity. Also the spacing seems improved. The highs are a bit more prominent and that’s getting used to. But only used the cable for about 8 hours so have to see how this progresses.
Bettinger F.
Fi-03 or vs FI-03 rhodium
J'avais initialement remplacé la fiche iec de mon intégré à tubes par le modèle identique mais plaqué or. Les deux variantes sont plus performantes que la prise d'origine, mais elles ont des caractères différents.
Si votre système est sec/agressif, et que vous cherchez à calmer les choses, ou si vous cherchez un peu de chaleur, optez pour la version or.
Si au contraire vous voulez améliorer le niveau de détail, les transitoires, tout en conservant un équilibre tonal neutre, je vous conseillerais plutôt la version rhodium. Sur un système à tubes, après 300h de fonctionnement le gain est évident.
Pensez également à tester les deux sens du fusible, eh oui cela a aussi une influence !
GUSTARD R26
GUSTARD DAC-R26 is an excellent R2R DAC, I used to have SMSL D1s, they are quite decent, however, GUSTARD is far away in sound, has stronger dynamics, clear highs, solid bass, full mids, settings are simple, then I did not try RJ45, nothing USB works great, I probably wouldn't use Roon, it's a parody of Audirvan, everything can be set much better there and with good tuning it gives excellent performance. Of course, it plays even better with the HQ player, which I would recommend. The conversion to DSD 512/1bit is fantastic. MQA also has very good results in presenting the sound space. You will then receive an excellent signal into your amplifier. This DAC is an excellent choice for more advanced connoisseurs. I recommend listening to the album Jean Guillou – Orgue et Percussions. You will get excellent space, wonderful acoustics, perfect dynamics, of course it depends on the type of your amplifier and speakers. This DAC is so good that I am considering buying another one. I can definitely recommend
Stéphane L.
Très bon DSP
Excellent rapport qualité prix. Utilisé dans une config 2.1. Le jour et la nuit avec mon ancien filtre passif sur le caisson. Sorties analogiques de bonne qualité (genre DAC à 300/500€). Manque juste un trigger 12v pour en faire un produit parfait.
David L.
Trés sympa mais calibrage limité
Petit appareil tres bien fini, solide, design simple et propre.
L’idée etait de juste en tester un pour éventuellement en prendre 4 pour mon 4.1 haut rendement.
C’est surtout un watt metre et selon le systeme ça va swinguer plus ou moins.
Dans mon cas, oú en plus je ne cesse de réduire la puissance suite aux mesures de tensions en utilisations diverses, ben ça bougeait presque pas.
J’ai bien tenté de l’ouvrir pour voir si on pouvait le modifier pour étendre la plage de calibrage, mais c’est au dessus de mon niveau.
Du coup en fouillant un peu les interwebs, “Z review” proposait une bonne idée pour palier au calibrage trop limité : carrément lui dédier un ampli.
Cad ne brancher qu’un ampli supplémentaire en source, sans hps, une sorte de circuit parallele et plus facile á calibrer du coup, pour swinguer les aiguilles sans se péter les feuilles.
J’avais un canal libre sur mon master dsp donc facile, un ptit v3 qui trainait et hop on branche.
Ensuite réglages niveau dsp / volume ampli / calibrage lc30 pour atteindre un comportement plus vivant.
Au final c’est tres sympa, d’ou le long retour ici.
Ça bougeotte a peine pour les ecoutes tranquilles, ça swingue bien pour le pêchu, mais bien sûr ça sort du cadran pour le vraiment fort, pas grave c’est rare de toutes façons.
Selon Fosi l’ampli voit quand meme 390ohms, en tous cas il ne chauffe absolument pas, et consomme rien.
Le top serait le meme genre d’appareil mais branché en digital sur la source, sur le -0dbfs.
Un step de plus en 25% sur les leds serait pas mal aussi, voir choisir la couleur elle meme, ça je vais ptet le bricoler.
Aiguilles tres reactives, a chacun de juger moi ça me va.
Ha, et il est assez gros et vide pour y mettre une TPA, j’dis ça comme ça Audiophonics hein ;)
Robert C.
Must try cable for speaker cables
For my DIY amplifiers with output power up to 40W per channel this cable is absolute favorite. Easy to assemble, flexible and more important absolutely transparent.
Robert C.
Incredible discrete OPAs
Everything is written and said in the online reviews on the web.
Natural, transparent, never harsh and with very good sound stage width and depth. Outstanding for the OPAs. Bravo Sparkos!
super génial
très bon produit le seule bémol les taxe de douane pour la Réunion dom 5 étoile merci
