Patrick G.
tres bonne conception
Abdoulaye D.
Soudure
Abdoulaye D.
Pince 3 in 1
Fameux w3103
Je trouve que ce câble agit sur les basses fréquences de manière a poser la musique de facon sereine sans négliger les autres fréquences . Un médium juste et pertinent, des aigus fins et mélodieux. Bref un câble un peu sombre mais très musical.
Bram D.
Really helped to dampen cabinet resonances in my speakers
Not an easy material to cut, but this really helped to dampen cabinet resonances in my speakers. So I'm very happy.
I used the thickest ones, by the way.
Frank j.
very good xlr cabel studio standard
I like double sheild in cable and core of 0.38mm
and then it sounds fantastically good
good bass, midrange and treble that is soft
it is also built as a studio cable
compare xlr cable which costs 200 euros and up
so there is very little difference in the sound
Pedro Jose T.
Very competent amplifier.
With my 84.5 dB boxes I don't need to use the 12 o'clock volume control to have more than enough volume.
Indrek K.
NEOTECH NEET-3008 Ethernet RJ45 Cable UP-OCC Copper 2m Neotech offers with its NEET-3008 an excellent RJ45 Ethernet cable, benefiting from an exceptional design. It integrates four UP-OCC Copper conductors with a cross-section...
Neotech Neet-3008
this cable has very good musicality, not dry like some silver plated cables, highly recommend!
Frederic M.
AIYIMA T9 Amplifier TPA3250 Tubes 2x 6K4 Bluetooth 5.0 2x60W 4 Ohm The Aiyima T9 is a versatile and affordable integrated amplifier, ideal for setting up an audio system without breaking the bank and without multiplying the number of devices....
Bon ampli
J'ai acheté cet ampli pour une pièce de 30m2. Il fait parfaitement le job. J'ai également acheté des tubes GE JAN5725 et des GE 5654 pour changer un peu de son. Et les trois paires de tubes apportent une couleurs différentes.
Silva R.
1877phono “The Highlands MKII” phono cable.
I like it when any new device inserted in my setup makes a difference, as happened with the “Highlands”, the music flows through the cable naturally, without compressions and with any kind of music.
I read somewhere that this cable wouldn't be the most suitable for progressive rock or heavy metal, I can't disagree more... everything I've used it for (F. Zappa, Alex Harvey Band, Colosseum, King Crimson, Slade, L. Zeppelin , Pink Floyd, Johnny Cash, J J Cale, Jean Luc Ponty, John Coltrane, Cesaria Evora, Johnny Hartman, Nina Simone, Keith Jarret, Pat Metheny, Jan Garbarek, Miles Davis, Dixie Gordon, Beethoven Symph nr II, Pavarotti, Mozart Symph nr 41) and much much more, he delivered everything resolved and naturally.
My phono stage offers a generous sound stage in its three dimensions, what the “Highlands” does is occupy the entire space in a holographic way, with space between the musicians and perfectly located on the stage. More than once, I experienced “seeing” the brass section at the back of the stage and about 1 meter above it.
This cable is fast and very resolved, it has a lot of tonal balance in the mid-range, the bass is tense without fat on the edges, the treble is top-notch but could have a little more extension here, but nothing serious. Anyway, the presentation of the musical pieces is very consistent, very natural and without showing any signs of compression even when the music become complicated. At this price this cable is a bargain.
The only thing I have to say is that “Highlands” showed the limitations of my phono stage... but I already knew that, eheheheh.
Congratulations to 1877phono for the development work
Congratulations to Audiophonics for making us known
Rui Silva – Lisbon, Portugal
Gilles C.
MOGAMI 3368 Unbalanced modulation cable OFC Copper 0.565mm² Ø8mm This 3368 unbalanced modulation cable from Mogami features an OFC copper conductor with a cross-section of 0.565mm² (AWG20). It features PE insulation and double carbon shielding.
Cable Hi End pour instrument (Guitare)
Quand j'ai commencé à m’intéresser à ce câble, il n'était pas disponible au catalogue d'Audiophonics.
Ni une ni deux, je fais une demande et je reçois la réponse que la demande était faite, Si acceptée, câble disponible peu de temps après... Et le voilà!
Le 3368 est un peu plus gros que la moyenne et rentre tout juste dans du jack Neutrik NP2X.
La gaine de masse est tressée avec du cuivre et... des fibres synthétiques, c'est juste très pénible à travailler proprement. Deux couches de PVC carbone à retirer et ce sera prêt pour le montage qui se fait sans difficulté.
Le son:
Certes, comme à chaque fois, il faudra quelques heures de vol pour avoir un avis définitif mais de prime abord, il sonne déjà très bien.
Le bas et le bas médium sont pleins et définis, le médium détaillé et les aiguës précis et pas agressif et sans être dans une douceur extrême. Je suis satisfait!
Je l'ai mis en concurrence avec le Mogami 2524 et le Sommer Câble Carbokab (masse flottante).
Le 2524 est hors course sauf si on cherche de la grande douceur et une présence discrète.
On est proche du Sommer niveau spectre mais le son est plus "beau", les aiguës sont plus naturels.
Le "+": la microphonie est extrêmement faible, ce câble est parfaitement silencieux à la manipulation ce qui apporte une propreté de son inégalable sur scène, sans que le bruit de manipulation soit repésenté dans l'ampli! Amis musiciens à bon entendeur! Il est aussi très léger!
Le "-": Vu le diamètre et sa structure, il ne sera pas le champion de la souplesse (même si on a vu bien pire) et il a tendance à faire des boucles.
Maintenant, à voir avec le temps!
Merci à l'équipe d'Audiophonics pour sa réactivité et d'avoir fait rentrer ce câble dans le catalogue.
Guillaume V.
GUSTARD H16 Headphone Amplifier Preamplifier Balanced Black With the DAC, Gustard offers a high-performance headphone amplifier and preamplifier, benefiting from careful and intelligent manufacturing. With its independent symmetrical and...
relié au dac de la même marque correspondant a ce modèle, cet ampli est vraiment a la hauteur en qualité et en puissance pour alimenter des casque hdg exigeant.
bref de quoi être satisfait sans se ruiner, je recommande sans retenue.
Guillaume V.
super dac
j'ai découvert depuis peu cette marque chez audiophonis qui ma foi permet d'avoir du matériel de qualité sans forcément faire crédit, je suis tout a fait satisfait la qualité du son est au rdv, relié a l'ampli casque de la marque correspondant a ce modèle le résultat est vraiment satisfaisant, je recommande.
Guillaume V.
décevant
acheté pour relier un dac gustard et un ampli casque de la même marque, il m'a fallu un certain temps avant de me dire que quelque chose "clochais", le son était plat et manquais singuliérement de quelque chose, aprés avoir interverti les topping avec des cables diy de marque elecaudio, je retrouve toute l'ampleur et la suavité du son digne de ce genre de matériel.
j'avoue ne pas avoir d'explication a ça, franchement décevant au vu du prix de ces cordons de seulement 25cms a priori qualitatif, les elecaudio de 2x1m ont couté a peine plus cher.
Bruno P.
RAS
Totalement transparent, aucune signature sonore autre que celle voulue par l'enregistrement.
Aussi passionnant à l'écoute que n'importe quel ampli passé entre mes oreilles, et moins pénible, vu l'âge qui se prend, que les dizaines de kilos de blocs mono réputés en classe A à tubes.
Sur des Cabasse Galion IV.
Très bien fini, aussi, sur le plan visuel.
Bruno P.
RAS
RAS est le meilleur commentaire á faire sur un amplificateur de puissance.
C'est fait, je l'ai écrit : RAS.
Je rajoute néanmoins qu'au delà de la juste neutralité sonore, l'objet a aussi visuellement de l'allure.
Didier G.
Super RPQ
Filtre secteur efficace, pratique, très abordable et peu encombrant.
Installé entre ma livebox et son adaptateur secteur (12V 2.5 A) , il bonifie très sensiblement la qualité audio du streaming. Meilleure lisibilité (surtout au niveau du grave), meilleure transparence générale...
Merci Audiophonics
Jean Michel P.
PANGEA AC-14SE MKII Power Cable Triple Shielding Cardas Copper / OFC 3x2mm² 1m Based on a mix of sale strands and Litz wires, this cable is especially designed for your audio sources. The Pangea AC-14SE MKII cable is specially designed for source...
Bon câble
Beaucoup de qualités , densité et timbres mais un cran en dessous du AC14 de base a l equilibre peut etre un peu plus creusé dans le medium mais qui offre une meilleure definition dans le haut piur une image plus précise
Iulian M.
Good but not great
The sound is a bit darker/heavier. Lots of bass and the highs are sweet, but on burson funk they have background noise from 50% volume up. In playmate 2 they seem to be more at home. OPA1656 are better in burson funk, the sound is more normal and no background noise.
Iulian M.
OPA1656 Dual OPA DIP8 (Unit) This OPA1656 OPA from Texas Instrument offers very good performances for audio use. It has a very good dynamic range and a low level of harmonic distortion. Taking advantage of...
Very nice sound
In my burson funk it sounds better than V6 (vivid or classics). Sound is balanced/sweet and has no popping noise like the V6. Also there is minimal background noise unlike ORACLE II which has background noise from 50% volume up.
Guillaume V.
HIFIMAN ANANDA Stealth Audiophile Planar Magnetic Headphone High Senstivity 93dB Hifiman’s Ananda audiophile headphones are the result of many years of development. It is a lightweight model for unequalled comfort and equipped with ultra-thin ...
un casque qui tient ses promesses
effectivement la on change de catégorie, de budget également...que dire du son, sinon qu'il est exceptionnel en tout point ?
la spatialisation est bluffante.
sur certain points la fabrication, de l'arceau par ex, peut laisser perplexe, néanmoins le confort est parfait.
seul reproche, a ce prix pas d'étui de protection, et surtout pas de cordon en 3m alors que ce casque est destiné a mon avis plutôt a l'utilisation domestique, même si le cordon fourni en 1,5m est pratique pour l'écoute d 'un baladeur.
l'écoute sur un FIIO M11 est d'ailleurs concluante, ce qui est loin d'être le cas pour bon nombre de casque que les baladeurs sont sensés alimenter sans problème (d'après les fabricants...) ceux qui ont du testés plusieurs modèles de différentes marques pour trouver le bonheur savent de quoi je parle.
par rapport aux chiffres avancées la puissance demandée est conséquente, par ex 2/3 pour le M11, je dirais de même sur un ampli.
je recommande chaudement ce casque, c'est vrai qu'il faut franchir le cap du budget, j'ai pour ma part attendu de nombreuses années...
aucun regret sur ce choix, les son est exceptionnel, c'est bien ce que l'on recherche.
Thomas V.
excellente pour un prix encore relativement raisonnable
De quoi se monter des câbles vraiment excellent. Un peu moins de définition et de transparence que la 004, mais un peu plus chaleureuse et tolérante aussi (bcp plus passe partout donc). Et deux fois moins chère aussi !
Zoltan N.
A cheap sound system with far from cheap sound.
I built myself a second mini digital system. Raspberry Pi4, Volumio and SMSL SU1 DAC connected via USB. Wow, I'm shocked at the sound. It can easily outperform much more expensive devices. Totally recommended stuff!
Helmut W.
Hervorragend
Habe seit ein paar Tagen diese Endstufe, was soll ich sagen,
diese Endstufe ist der Hammer. Alles funktioniert tadellos
kein Rauschen in den Boxen. Versorge damit meine
Klipsch 8000 Standboxen und die hören sich tatsächlich noch besser an.
Die Bestellung ohne Probleme und die Kommunikation mit dem Verkäufer 1a.
Kann diese Endstufe und den Verkäufer bestens empfehlen!
Hoffe ich konnte euch bei der Entscheidung etwas helfen.
Fidel R.
Good sound but bad usability
I bought this DAC/Amp to power my ELAC Debut 2.0 B5.2 speakers in a desktop setup. I assumed I wasn't going to need a lot of power and I was right: out of a maximum volume of 60 I usually set it 20-25, and I go up to 35 to make it loud. Sound quality is very good for me, clean and crisp, no audible background noise for me. Do note that I'm no audiophile, this is my first hi-fi setup.
I connected my computer using the USB-C port, having a USB DAC was one of the main points for me as I was using my integrated sound card until then. The provided cable is pretty short, about 1 meter, it was just enough to make the connection. I use Linux and it was recognized and configured automatically, I just had to choose the digital output profile instead of the default analog one.
I like the included EQs, especially SDB for rock/metal/electronic music and Clear for other genres.
My big complain with the SMSL AO300 is about the interface usability:
- When you use the dial to access the menu you have no way of going back to the main screen, have to wait a few seconds to adjust the volume. Even worse is that this happens even when using the remote, where you have dedicated volume buttons, but they don't work in the menu screen. You can press left in the remote to go back to the main screen, but it's one extra button press for no good reason.
- Output doesn't automatically switch to headphones when plugged, you need to manually change it through the menu. The remote has a button to change input, but not one to change output.
- The FN button in the remote only turns the screen on and off. The manual says "Define in the menu", but there's nothing in the menu to program its function, and nothing I've tried works. Maybe they forgot to code it? Very infuriating.
- A button in the remote to quickly change EQ would have been nice. If FN button could be programmed (see above) it would solve this for me.
- The remote up/down/left/right buttons do nothing in the main screen. They could've allowed mapping them to quick access to functions, e.g. to quickly change Output, EQ, Filter...
I believe these changes are not hard to implement, just a matter of having someone properly think about the end-user experience. For this reason I'm taking two stars in the hope that they release a firmware update to fix as many of these issues as they can. If they do I'd be happy to update my review to 5 stars if all issues get addressed.
michael c.
SMSL DO300EX DAC AK4191+AK4499EX Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD Black SMSL unveils, with the DO300EX, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components such as the AK4499EX DAC chip...
super
excellent DAC très bon son, merci a audiophonics pour les excellents conseil
Fidel R.
SOMMERCABLE MERIDIAN SP215 Speaker Cable OFC Copper 2x1.5mm² Ø6.8mm This robust cable is specially designed for connecting speakers and technically meets all the requirements. Its copper cores with low oxygen content ensure excellent acoustic...
I bought these cables to power my new ELAC Debut 2.0 B5.2 speakers in a desktop setup, roughly 1 meter to each speaker, a very short run.
The speakers' manual recommend at least 16 gauge, which is why I picked this cable instead of a smaller one. The double shielding was important for me as they run through the back of the desktop side by side with a lot (*a lot*) of other cables.
They sound great and I'm very happy with the purchase, can recommend.
Iulian M.
1 iron plug in 3 sets
Ordered 3 sets and 1 plug contains iron (even looks different), the rest are great. Bad quality control.
Iulian M.
Sharp sounding
They have a sharp (forward) sound and more details in the treble region.
LME49860 sound much better (more natural).
Iulian M.
BURSON AUDIO Aluminum Remote Control This Burson Audio remote control is compatible with their products. It will enable you to control the volume and select input sources on your Burson Audio Hi-Fi equipment.
Works but kinda useless and expensive.
It does not have a button to change from headphones to rca, but has the button to change inputs. Works in a very narrow window as it requires to be in front of my playmate 2 to work. Arrived with battery preinstalled and almost empty.
Jean-Pierre D.
VIABLUE NF-S1 Mono Female XLR Femelle to Male RCA Cable 1m (Pair) The ultimate goal of any high-end HiFi cable is to transmit the audio signal in the cleanest and most efficient way to provide the most faithful audio message possible. To...
Un câble avec un son clair, ouvert et dynamique
Le rapport qualité/prix est bon avec ce câble (un peu cher quand il est monté en version au mètre, c’est plus attractif), la qualité de fabrication est très bonne, le blindage est excellent.
Le Viablue NF-S1 XLR-RCA a une tonalité légèrement claire, ce n’est pas sombre ou trop lumineux. Il présente les voix de manière assez forte. Celles-ci sont également plus proches et moins douces que certaines autres références (je pense à Néotech ou Cardas). Les chansons sont restituées de manière assez émouvantes. Les basses sont puissantes. On peut dire que Viablue a donné un coup de boost à ma musique. La basse est profonde et épanouissante. La dynamique est également satisfaisante.
C’est un câble intéressant pour présenter un son spacieux et crédible dans tous les styles de musique. Ce n’est pas artificiel, il crée une atmosphère riche entre les chanteurs et les instruments. Le son relativement doux et arrondi malgré une certaine vivacité garantit une expérience d’écoute agréable. Il modifie peu le son original, c’est neutre. En négatif, par rapport à des câbles plus haut en gamme, on peut regretter des hautes fréquences manquant d’expressivité et davantage de transparence.
Gérard T.
très bon câble acheté sans conviction, mais à la sortie aucune perturbation entre le PC et le DAC, signal parfait malgré un environnement plutôt défavorable, beaucoup de câbles, un décodeur Internet à quelque centimètres et une installation électrique un peu chaotique
Gérard T.
Fait son taf et la fabrication est sans reproche
Gérard T.
TOPPING DX9 DAC AK4499EQ Headphone Amplifier NFCA Bluetooth 5.1 AptX LDAC 32bit 768kHz DSD512 Black To celebrate its 15th anniversary, Topping unveils a high-performance DAC / Headphone Amplifier: the DX9. In addition to its very high performance, Topping has given it a...
enfin un DAC musicale
dès la première écoute le plaisir, on oublie la technique et on ouvre grand les oreilles. Bien sûr j'aurais aimé que le paramètres soit en Français, peut-être à la prochaine mise à jour du firmware…
Audirvãna le reconnais comme décodeur MQA, même si noté nul part.
jean-jacques D.
[GRADE B] XDUOO XP-2 PRO Portable DAC Headphone Amplifier Bluetooth 5.0 aptX AK4452 32bit 384kHz DSD256 Refurbished product  - Grade B The xDuoo XP-2 Pro is a portable amplifier and DAC that is easy to carry and offers great performances with your high definition audio...
Petit et performant
J'ai un Xduoo XD-05 qui me donne satisfaction mais comme les câbles OTG sont courts il arrive que ça provoque des faux contacts si on bouge la source.
Ce XP-2 est aussi puissant, beaucoup plus petit et plus léger, facilement utilisable en Bluetooth .Il alimente aussi bien mon AKG K702 que mon Grado.
Infime rayure, quasiment invisible mais le revêtement en plastique brillant semble fragile, un métal aurait été moins fragile. J'ai trouvé un petit étui qui permet de l'emporter sans crainte.
Comme toujours, livraison rapide et bon conseil.
Gérard T.
juste à brancher et déguster sa musique préférée sans ce ruiner.
Gérard T.
fabrication de qualité
un peu plus encombrant que je ne l'avait imaginé, mais a la sortie quel merveille, ne chauffe pas même après une journée d'écoute et le son est tout simplement parfait !
j'éprouve a nouveau le grand frisson
Merci Audiophonics
Steven H.
Cable pour Clear MG
J'ai réalisé un cable pour relier mon casque Focal Clear MG à son ampli Pathos Aurium et c'est nickel
Carlos N.
La Rolls Royce des condos
Ces condos distillent la moindre info qui passe dedans et la sublime. S'est duveteux , les voix sont sublimées, la texture des cymbales est incroyablement retranscrite. Je recommande fortement pour accompagné dans un montage tubes et ils valent leurs prix. Grand merci à Audiophonics de commercialiser de telle condos.
Carlos N.
Upgrade de très haut niveau avec lecteur Line Magnétic LM 215 CD
J'ai voulu upgradé mon lecteur cd LM 215 sans trop y croire.
j'ai modifier mes Burr Brown 2604 d'origine par ses Burson Audio VIVID V6 sur les conseils d'un ami Indonésien passionné par le DIY de très haut niveau.
J'ai également modifier les condos de sortie du convertisseur NA sur le tube Gold Lion 12au7 par des Mundorf Mcap Evo argent or et huile.
Le niveau atteint est très dure à commenté avec des mots tant il y a à dire. S'est à la fois smoothie, savoureux dans les textures des voix, instruments (cymbales, contrebasse etc etc…), scène 3D, profondeur, réverbération, dynamique…
Dans mon cas le mariage du condo Mcap Evo et de l'AOP Burson Audio Supreme Sound VIVID V6 est WOW !!!
La tessiture des cymbales sur l'album de Avishai Cohen ( contrebassiste pas le trompettiste) est une dinguerie !!! La voix de Patricia Barber est d'une sensualité hors du commun, les solo de batterie atteint un tel niveau en texture, 3D, dynamique.
Je vais laissé rodé tout ça tranquillement.
Fabrizio R.
On Lenco Ptp6, dsp Xilica and Powersoft amplifiers for 4 subwoofers...very good cable.
I have this interconnect cable for connect my Preamplifier Audio Note M5 phono with this turnable, dsp and classD amplifiers and work very well in all conditions,highly recommended.
Matej J.
In my opinion, very clean sound, especially at high frequencies, of course, the other bands do not fall behind in any way.
I have tried many capacitors with identical capacity, this one seems to be the best, and the price is also OK.
I highly recommend.
Martin S.
Great Product
I am genuinely impressed with this amp.
Purchased to power some small bookshelf speakers in my office, I was impressed the first time I turned it on.
Okay, in my opinion, this is obviously not a contender for a main system. However, that said, for €220 it really does a lot right. Very surprising midrange, most of what is on the recording can be heard. What the amplifier lacks is control and refinement. But the system I generally listen to, cost rather a lot more than this. I am giving 5 stars as at this price point it is a lot better than I had expected.
If you are looking for a small low cost amp. Then I think this product will satisfy. The most important thing is to enjoy the music you are listening to. I am certainly enjoying the music in my office using this amp.
jean michel G.
Utilisé pour un câble DIY. Sertissage parfait.
jean michel G.
Très bonne pince, maniable, facile à utiliser.
SHANLING EC MINI Portable CD Player and DAP Sanyo 680 2x ES9219MQ Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD256 MQA-CD Silver The Shanling EC Mini is a CD player and DAP combo that's as compact as it is versatile and high-performance. Its high-quality design allows you to enjoy your music in every...
MOYEN
J'ai acheté ce lecteur principalement pour le lecteur cd pour ma chaine secondaire . En lecture cd les timbres médium aigu ont une tendance simplifiés et synthétiques légèrement frustrant à l'écoute . L'équaliseur est de qualité moyenne et ne corrigera pas ce défaut . Dommage car les détails sont présent et le suivi mélodique est agréable . En Bluetooth ce phénomène disparait et le liaison LDAC est bonne .
François G.
Remplacement haut parleur
J'ai déjà utilisé ce haut parleur sur une enceinte que j'avais développée il y a une quinzaine d'années et j'en avais un bon souvenir.
Aujourd'hui c'est pour restaurer des enceintes JMlab dont les tweeters Focal T101 ont rendu l'âme, j'ai réalisé avec une imprimante 3D une plaque d'adaptation pour les DT28N et après simulations et contrôle, il s'adaptait parfaitement en réponse en fréquence, phase, impédance.
Après écoute, aucune modification sur le filtre n'a été nécessaire. Les enceintes ont retrouvé leur jeunesse.
HERVE H.
EVERSOLO DAC-Z6 DAC 2x ES9068 XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA The EverSolo DAC-Z6 is a powerful DAC based on a neat technical structure. It embeds high-end components with notably two ESS ES9068AS digital/analog conversion chips and a XMOS...
Popularité méritée
Dac Z6 reçu rapidement(comme toujours
Pierre E.
Suitable for Fosi Audio BT20A Pro
Installed in a Fosi Audio BT20A Pro. Works well, I did not compare with the original op amp as I changed them right away.
Fast & efficient delivery by Audiophonics
Sasha B.
perfectly made and correctly packaged
Sasha B.
Sasha B.
2 ème avis
Voici une quinzaine d'heure qu'il fonctionne... Quelle amélioration !
Superbe basse, détail , la separation des canaux se fait de plus en plus précise.
J' ai autant de plaisir qu' a écouter mon tube de 10 fois le prix.... Autrement recommandé.
