Section (mm²)
0 mm - 6 mm
Diameter (mm)
Conductors material (Cable)
Conductors Plating (Cable)
Number of conductors
Insulation material
Ground / Shielding
Shielding
Andrzej W.
Dobry Dual-Mono DAC
Świetna płytka Dual-Mono, w połączeniu z IAN CANADA IVSTD MKII a wszystko pod kontrolą Reclocer Pi MA daje wspaniały efekt....
Léo S.
Pas de soucis
Super produit, intégration facile dans REW ou sur l'application Wiim. Envoi soigné et expédition plus rapide que les...
Igor B.
Great cable for the price
In biwired setup, I use this cable for high frequencies, along with Melodika Sky Blue for the low frequencies. They work great...
Mono conductor
Here you will find all of our single conductor cabling wires, sold by the metre, for the internal wiring of your appliances and DIY projects.
  • Ref : 18219
    In Stock
    This wire is ideal for internal wiring on DIY projects. It consists of a 0.5mm² silver-plated OFC copper single-strand conductor. This cable is therefore protected against corrosion and oxidation, and offers a high level of conductivity. It has a PTFE sheath for insulation and a total diameter of Ø1.3mm.
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 18218
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 17789
    In Stock
    The Xangsane XS-DIY1 is a high-end cable with 99.99% pure silver as the conductive material. This ensures maximum electrical conductivity for optimal audio signal transmission. This makes it ideal for the internal wiring of a high-fidelity DIY audio project or for the manufacture of high-performance cables.
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 17790
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 17791
    In Stock
    The Xangsane XS-DIY1 is a high-end cable with 99.99% pure silver as the conductive material. This ensures maximum electrical conductivity for optimal audio signal transmission. This makes it ideal for the internal wiring of a high-fidelity DIY audio project or for the creation of high-performance cables.
    39,90 € 33,25 €Ex.
    In Stock
