The ALSOZONE PAM253 is a three-channel power amplifier designed to power a 5.1 home cinema system. It delivers up to 260W per channel and relies on TPA3255 chips, which integrate MOSFETs in their output stage. The PBTL architecture increases the available current, while the PFFB technology helps control distortion and stabilize the amplification behavior.
Each channel features two independently adjustable gain levels, in order to adapt the amplifier to the sources and speakers of the installation. This multichannel design centralizes the amplification of the different channels and allows their level to be adjusted according to the home cinema configuration.
The ALSOZONE PAM253 is a multichannel power amplifier designed for 5.1 home cinema installations. Part of the PAMX series, it delivers 260W per channel and can reach a peak power of 450W per channel at 2Ω. Its amplification relies on TPA3255 chips, which integrate the MOSFETs of their output stage, combined with a PBTL architecture and PFFB feedback in order to increase the available current while controlling distortion.
In PBTL mode, two half-bridges operate in parallel on each channel, which increases the available current and reduces the output resistance of the power stage integrated into the TPA3255 chips. The PFFB technology complements this architecture by contributing to the stability of the amplification with different loads. The GaN switching power supply is designed to deliver high power in a compact format; the TDK, ELNA and Rubycon capacitors, as well as the flat-wire inductors, contribute to the stability of the power supply and to the operation of the whole unit.
Each channel features two gain levels, which allows the amplification to be adapted individually to the characteristics of the sources and speakers. The trigger input and output allow coordinated power-on with other compatible devices, while the Auto On/Off function activates the amplifier when an audio signal is detected and turns it off after 20 minutes without signal. A front-panel control retains priority for operation independent of the automatic trigger.
| 1 | Power button |
| 2 | Power indicator (red) |
| 3 | Clip indicator (green) |
| 4 | Trigger input and output |
| 5 | Trigger/Auto mode selector |
| 6 | Input selector |
| 7 | RCA input |
| 8 | XLR/6.35mm TRS Jack input |
| 9 | Gain selector |
| 10 | Speaker output |
| 11 | IEC mains power connector 100-240V |
| 12 | Power switch |
Technical specifications
| Specifications | |
| Product type | Power amplifier |
| Number of channels | 3 |
| Inputs | 3x RCA 3x Combo XLR/6.35mm Jack |
| Outputs | 3x Output on speaker terminal |
| Amplification chip | TPA3255 |
| Amplification type | Class D |
| Output power | 3x 450W @ 2Ω, THD+N = 1% 3x 260W @ 4Ω, THD+N = 1% 3x 150W @ 8Ω, THD+N = 1% 3x 320W @ 4Ω, THD+N = 10% 3x 200W @ 8Ω, THD+N = 10% |
| THD+N | Unbalanced input: 0.0007% @ 4Ω/ 0.0006 @ 8Ω Balanced input: 0.0006% @ 4Ω / 0.0005 @ 8Ω |
| SNR | Unbalanced input: 121dB Balanced input: 124dB |
| Dynamic range | Unbalanced input: 121dB Balanced input: 124dB |
| Frequency response | 20HZ-30kHz |
| Noise | Unbalanced input: <20µVrms Balanced input: <15µVrms |
| Crosstalk | Unbalanced input: -100dB Balanced input: -110dB |
| Gain | Unbalanced input: 23/29dB Balanced input: 17/23dB |
| Input sensitivity | Unbalanced input: 2/1Vrms Balanced input: 4/2Vrms |
| Recommended speaker impedance | 2Ω-16Ω |
| General | |
| Supply voltage | 100-240V AC 50/60Hz |
| Dimensions | 267 x 262 x 91mm |
| Color | Black |
| Package | 1x ALSOZONE PAM253 8x Banana Plug 1x AC power cable |
| Input | XLR |
| Input | Jack 6.35mm |
| Input | RCA |
| Output | Speaker terminal |
| Color | Black |
| Channel | 3 |
| Class | Class D / T |
| Amplifier chip | TPA3255 |
| Power (W) | 260.0 |
| Remote Control | No |
