By buying this product you get 44 loyalty points
The Arylic LP100 is a streamer that uses high-quality components to provide access to various audio streaming protocols and platforms. Its architecture includes an AKM AK4493 SEQ DAC chip combined with a CT5302SL chip and an AK7735 ADC/DSP. The combination of these three chips offers superior high-resolution stream processing quality up to 24bit 192kHz PCM. Compatible streaming protocols including WiFi, AirPlay 2, Google Cast, Spotify Connect, Tidal Connect, Roon Ready, DLNA, and UPnP provide access to numerous sources. In addition, it features Bluetooth 5.4 and support for SBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LDAC, and LC3 codecs. The LP100 can also be controlled in a number of ways, including via an infrared remote control, a dedicated mobile app, or voice control via Siri or Google Assistant. Its sleek design and extensive connectivity make it a device of choice.
The trio of AK4493SEQ DAC chips for high-resolution playback, SRC CT5302SL for refined conversion, and AKM7735 ADC/DSP for precise signal processing delivers a high-quality musical experience with support for up to 24bit 192kHz PCM.
Stream music directly from your iPhone, iPad, or MacBook, and listen to it with other AirPlay 2-compatible devices. You can also add LP100 to the Apple Home app and easily control it with your voice via HomePod.
Stream music directly from your Android device, YouTube, or any other Cast-compatible app. The LP100 works seamlessly with other Google Cast speakers for multi-room playback, voice control with Google Assistant, and supports high-resolution streaming up to 24bit 96kHz via Google Cast.
Listen to your playlists and collections directly from the Spotify app. With Spotify Connect, LP100 streams your music over WiFi for superior quality and stable playback. Even free accounts can enjoy it, without interruption from phone calls.
Stream high-resolution music directly from the TIDAL app to the LP100 via Wi-Fi. Enjoy your personalized playlists and lossless sound with exceptional clarity, and continue listening to your music even when you receive calls.
The Arylic LP100 streamer's Bluetooth 5.4 supports wireless connection streaming reception and transmission, allowing for many different configurations. In addition, it supports many high-resolution codecs such as SBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LDAC, and LC3, as well as Auracast and LE Audio features.
The Go Control App offers numerous features, including an equalization system to adjust the sound output according to the type of music being played or the user's preferences.
Take full control and customize your personal settings.
Quick reading, equalizer, access to preset content with remote control.
Convenient voice control with Siri and Google Assistant.
| 1 | Reset |
| 2 | GND Phono terminal |
| 3 | Trigger 12V output |
| 4 | USB-B input |
| 5 | RJ45 Ethernet LAN port |
| 6 | USB-A Host input |
| 7 | HDMI eARC CEC input |
| 8 | RCA phono input |
| 9 | RCA input |
| 10 | Coaxial SPDIF input |
| 11 | Toslink optical input |
| 12 | RCA output |
| 13 | Subwoofer ouput |
| 14 | Toslink optical output |
| 15 | 5V 2A power supply via USB-C |
Thanks to HDMI CEC technology, the LP100 integrates seamlessly with your TV. Turn on your TV and the LP100 will automatically start up. You can control the volume and playback using your TV remote control.
| Specifications | |
| Product type | Audio streamer |
| Chipset | DAC AK4493SEQ + SRC CT5302SL + ADC/DSP AKM7735 |
| Inputs | 1x USB-B 1x RCA 1x RCA phono input 1x HDMI eARC input 1x Coaxial input 1x Toslink optical 1x USB-A host Bluetooth |
| Outputs | 1x RCA line output 1x Subwoofer output 1x Toslink optical output Bluetooth |
| Other connectors | Trigger out 12V Port Ethernet RJ45 (LAN 10/100M) |
| Supported sample rates | PCM up to 24bit 192kHz |
| WiFi | IEEE802.11 b/g/n 2.4GHz, 5GHz |
| Bluetooth | 5.4 |
| Supported Bluetooth Codecs | SBC, AAC, aptX, aptX HD, aptX AD, LDAC, LC3 |
| Supported streaming protocols | WiFi, AirPlay 2, Google Cast, Spotify Connect, Tidal Connect, Roon Ready, DLNA, UPnP |
| Broadcast | Auracast 10m |
| Frequency response | 20Hz-20kHz ±1dB |
| THD+N | ≤ 0.001% |
| SNR | ≥ 80dB |
| Crosstalk | ≥ 80dB |
| Phono compatibility | MM / MC, RIAA EQ built-in |
| Supported USB Host Formats | FAT16, FAT32, exFAT, up to 128GB MP3, WMA, M4A, AAC, FLAC |
| Application | Go Control App |
| Compatible voice assistants | Siri, Google Assistant |
| General | |
| Power supply | 5V 2A via USB-C |
| Dimensions | 167 x 167 x 43.5mm |
| Weight | 550g |
| Color | Black |
| Package | 1x Arylic LP100 1x RCA cable 1x USB-A to USB-B cable 1x USB-C cable 1x AC adapter 1x IR remote control |
| Input | Optical |
| Input | Phono |
| Input | HDMI eARC |
| Input | USB |
| Input | SPDIF |
| Input | Bluetooth |
| Input | WiFi |
| Input | RCA |
| Output | RCA |
| Output | Bluetooth |
| Output | Optical Toslink |
| Output | Subwoofer |
| DAC / ADC Chip | AK4493SEQ |
| Max sampling rate | 192kHz |
| Color | Black |
| Remote Control | Control app |
| Remote Control | Yes |
| Streaming services & Network protocols | Spotify Connect |
| Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
| Streaming services & Network protocols | UpnP |
| Streaming services & Network protocols | AirPlay |
| Streaming services & Network protocols | Tidal Connect |
| Streaming services & Network protocols | Chromecast |
| Streaming services & Network protocols | DLNA |
