DENAFRIPS ARCAS Streamer Digital Transport Silver
The Denafrips Arcas is a high-end streamer featuring carefully selected components to deliver exceptional sound quality. Its components include a UPOCC O-Core transformer, a custom oven-controlled crystal oscillator (OCXO), a unique proprietary streamer module with an ARM Cortex Quad-Core processor, and an FPGA/CPLD chip with galvanic isolation.
By buying this product you get 239 loyalty points
Reference : 21325
2 390,00 €tax incl.
1 991,67 € tax excl.
Denafrips Arcas Streamer Digital Transport Roon Bridge HQPlayer NAA Airplay DLNA 32bit 384kHz DSD512 Silver
Denafrips Arcas picture
The Denafrips Arcas is a high-end streamer featuring carefully selected components to deliver exceptional sound quality. Its components include a UPOCC O-Core transformer, a custom oven-controlled crystal oscillator (OCXO), a unique proprietary streamer module with an ARM Cortex Quad-Core processor, and an FPGA/CPLD chip with galvanic isolation. The Arcas is compatible with numerous protocols such as Roon Bridge, HQPlayer NAA, Airplay, and DLNA to offer a variety of configuration options. The network connection is made via an RJ45 Ethernet port, while the signal output can be made via numerous digital ports: 2x AES/EBU, coaxial SPDIF, Toslink optical, or I2S LVDS via HDMI or USB-B. Other connectors allow you to connect an external clock or play local files via USB Host or TF card slot. This network player is capable of delivering up to 32-bit 384kHz and DSD512 via its I2S outputs, providing ultra-high-resolution streaming to the DAC in your Hi-Fi system.
The Denafrips Arcas does not support standalone network playback (it cannot directly access streaming services) and requires the use of a third-party application (such as BubbleUPnP, Mconnect, Roon, or Audirvana, for example) for music control and playback.
The architecture of the Denafrips Arcas
L'architecture du Denafrips Arcas
Streamer
Proprietary streamer module developed by Denafrips with AMR Cortex quad-core processor and high-quality quartz oscillator.
AC input
Deliberate design aimed at removing the EMI filter for sound quality adjustment exclusive to the new Denafrips product.
O-CORE Transformer
O-Core 60VA shielded transformer, manufactured in-house by Denafrips using high-purity copper.
TCXO clock
Temperature-compensated crystal oscillators for digital signal processing.
DSP
Benefit from Denafrips' years of experience in digital signal processing, integrated into an FGPA chip. Galvanic isolation via optocoupler.
Capacitors
OEM electrolytic capacitors compliant with Denafrips specifications. High-bias linear power regulator.
Denafrips Arcas overview
Denafrips Arce overview
12x AES/EBU output
2I2S output via HDMI LVDS
3I2S output via USB-B
4Toslink optical output
5Coaxial output
6External clock input 49.152M
7External clock input 45.1584M
8TF card slot
9RJ45 Ethernet port
102x USB Host Port
11AC power input
Product typeStreamer
Digital transport
EthernetRJ45
InputsEthernet
TF card slot
2x USB Host ports
Outputs2x AES/EU output
1x I2S via HDMI LVDS
1x I2S via USB-B
1x Toslink optical
1x Coaxial
Supported sample ratesOptical Toslink, SPDIF coaxial, AES/EBU outputs: PCM up to 24-bit 192kHz, DSD DoP64
I2S output via HDMI: PCM up to 32-bit 384kHz, DSD DoP64, DSD up to DSD512
Supported streaming protocolsRoon Bridge, HQPlayer NAA, Airplay (16/44.1kHz), DLNA (16/44.1kHz)
Power supplyAC115V/60Hz, AC230V/50Hz
Energy consumption≤ 20W
Dimensions215 x 230 x 45mm
Weight3.5kg
Color Silver
Package1x Denafrips Arcas
InputMicro SD
InputRJ45
OutputOptical Toslink
OutputCoaxial SPDIF
OutputUSB
OutputI2S LVDS via HDMI
OutputAES/EBU
DAC / ADC ChipNC
Max sampling rate384kHz
Max sampling rateDSD512
ColorSilver
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsHQPlayer NAA
DENAFRIPS ARCAS Streamer Digital Transport Roon Bridge HQPlayer NAA Airplay DLNA 32bit 384kHz DSD512 Silver
The Denafrips Arcas is a high-end streamer featuring carefully selected components to deliver exceptional sound quality. Its components include a...
