ARYLIC LP20 Streamer
The ARYLIC LP20 is a Hi-Fi network player designed to add wireless streaming and high-resolution digital-to-analog conversion capabilities to an existing audio system.
By buying this product you get 22 loyalty points
Reference : 22476
229,00 €tax incl.
190,83 € tax excl.
Shipping date: 24-11-2026.
ARYLIC LP20 Network Player AK4490EQ WiFi Bluetooth 5.4 Airplay 2 Google Cast DLNA UPnP 24bit 192kHz
ARYLIC LP20
The ARYLIC LP20 is a Hi-Fi network player designed to add wireless streaming and high-resolution digital-to-analog conversion capabilities to an existing audio system. It features an AKM AK4490 DAC and supports streams up to 24-bit / 192 kHz, with comprehensive connectivity based on dual-band 2.4/5 GHz Wi-Fi, 10/100M RJ45 Ethernet and Bluetooth 5.4. The LP20 is compatible with AirPlay 2, Google Cast, Spotify Connect, Qobuz Connect, TIDAL Connect, DLNA and UPnP, allowing it to access numerous network music sources or operate as part of a multiroom system. It also features an analog RCA input, an optical input, a USB port for file playback, a USB-C DAC input for PC, as well as RCA, optical, coaxial and subwoofer outputs, the latter providing up to 3Vrms with a 250Hz crossover frequency. A 12 V Trigger output also allows synchronization of the power-on of a compatible amplifier.
ARYLIC LP20: High-Resolution Streaming and Multiroom
The LP20 provides direct access to major streaming protocols through its Wi-Fi or Ethernet network connection. AirPlay 2 allows streaming from an iPhone, iPad or Mac and synchronizing multiple compatible devices, while Google Cast enables streaming up to 24-bit / 96 kHz. The player also supports Spotify Connect, Qobuz Connect and TIDAL Connect, with support for Tidal Max up to 24-bit / 192 kHz. AirPlay 2 and Google Cast also allow synchronized multiroom systems to be created across multiple rooms.
ARYLIC LP20: AKM AK4490 DAC and Comprehensive Connectivity
The AKM AK4490 DAC, combined with the CT5302 SRC converter, allows the LP20 to process audio streams up to 24-bit / 192 kHz. Its particularly versatile connectivity includes an analog RCA input, an optical input supporting PCM up to 24-bit / 192 kHz, a USB-C DAC input for PC, as well as a USB Host port for directly playing files from a USB flash drive. On the output side, there is an RCA output providing up to 2 Vrms, an optical output and a coaxial output up to 24-bit / 192 kHz, as well as a subwoofer output providing up to 3 Vrms with 250 Hz filtering.
ARYLIC LP20: Bluetooth 5.4, App and Control
Bluetooth 5.4 offers a stated range of 15 meters and supports SBC and AAC codecs for both transmission and reception. The LP20 can therefore receive music directly from a compatible smartphone, tablet, computer or TV. Control can be carried out using the GO CONTROL app, which allows management of the player and its settings, as well as with the supplied infrared remote control or the rotary knob on the device. The remote control can be used to control the volume, playback, source selection and Bluetooth. The LP20 also features a USB-C 5V / 2A power supply, measures 148 × 148 × 43mm and weighs 500g.
Overview of the ARYLIC LP20
1Reset
212V Trigger Output
31x RCA Line Input
4SUB OUT
51x Toslink Optical Input
61x RCA Line Output
71x Coaxial SPDIF Output
81x Toslink Optical Output
9RJ45 LAN Port
101x USB-A Host Input
11USB-C 5V/2A Power Supply Port + PC Audio
Technical Specifications
Product typeNetwork Player
DAC chipAK4490EQ
Inputs1x RCA Stereo (2Vrms)
1x Toslink Optical
1x USB-A Host
1x USB-C (PC Audio)
Bluetooth 5.4 (15m)
WiFi
Outputs1x RCA Stereo (max. 2Vrms)
1x Coaxial Output1x Subwoofer Output (Max 3 Vrms, crossover frequency 250Hz)
Trigger OUT12V
Supported Bluetooth codecsSBC, AAC, (2 Bluetooth receivers, allowing connection of up to 2 smartphones)
WiFi standardDual-band 802.11ac 2.4GHz/5GHz
LAN RJ4510/100M RJ45
Supported streaming protocolsWiFi, Google Cast, AirPlay 2, Spotify Connect, Qobuz Connect, TIDAL Connect, DLNA, UPnP
USB HOST formatsFat16, Fat32, exFAT, up to 128 GB (mp3, wma, m4a, aac, flac)
Supported sampling ratesToslink Optical Input: 24bit 192kHz
Voice controlSiri, Google Assistant
Power supply5V 2A via USB-C
Dimensions148x148x43mm
Weight500g
Package contents1x ARYLIC LP20
1x IR Remote Control
1x Stereo RCA Cable
1x USB-A to USB-C Cable
1x 5V/2A Power Adapter
InputWiFi
OutputSubwoofer
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipAK4490EQ
Max sampling rate192kHz
Remote ControlYes
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsChromecast
Streaming services & Network protocolsQobuz Connect
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsUpnP
Streaming services & Network protocolsDLNA
ARYLIC LP20 Streamer AK4490EQ WiFi Bluetooth 5.4 Airplay 2 Google Cast DLNA UPnP 24bit 192kHz
The ARYLIC LP20 is a Hi-Fi network player designed to add wireless streaming and high-resolution digital-to-analog conversion capabilities to an...
